best turbo cat
best turbo cat
What brand of aftermarket cat holds up the longest in a turbo application? Assuming the tune is proper...
Re: best turbo cat
I'd go for the Random Technologies metallic substrate catalyst.
Re: best turbo cat
This image was highly rated:
Re: best turbo cat
A gutted cat. Interpret that as you will.
Re: best turbo cat
Whatever one TCD uses on his turbo exhausts was excellent for me. Held up to abuse and passed CT emissions easily. Magnaflow 3" center-center. Probably the 93509 unit, but I don't know for sure.
Re: best turbo cat
I smoked a Magnaflow sometime during my street/dyno tuning process . My recommendation would be to get the tune as close to correct before installing it then once installed, you can dial in for emissions if required.
