a few pics of my good & tight manifold
JesterMX6
Post by JesterMX6 »
I started getting it ready to bolt on and i've been taking pics as i go.
September 7, 2014
I'm getting antsy. It's time to prep parts for install. Yesterday I started coating the exhaust manifold.
2014.09.07 coating the manifold by jestermx6, on Flickr
2014.09.07 coating the manifold 2 by jestermx6, on Flickr
2014.09.07 coating the manifold 3 by jestermx6, on Flickr
Once i get the coating cured, i've got some titanium exhaust wrap to cover the manifold. Gonna be tight between some of those runners though, so hopefully i don't have to many gaps in the wrap.
September 11, 2014
Started work on wrapping the manifold. This is a lot tougher than i thought it would be.
2014.09.11 wrapping the manifold by jestermx6, on Flickr
plastic zip ties will be replaced with stainless ones before i spray a coating over the wrap. the plastics are just there to help with the wrapping process and keep the winds tight.
JesterMX6
Re: a few pics of my good & tight manifold
Post by JesterMX6 »
ZenitramNaes
Post by ZenitramNaes »
Dude, looking good! I've got a good N tight manifold lined up, hopefully it will be mine soon enough.
Good & Tight
Post by Good & Tight »
Looking good..!!!
528KC
Post by 528KC »
Where do you find said Good&Tight manifolds? And what's about did it cost ya? If you don't mind me asking.
Edit: Do you maybe get them from ^^that guy^^? :lol:
TheGraye28
Post by TheGraye28 »
What Turbo? HX40?
JesterMX6
Post by JesterMX6 »
H1E, which i think is similar. just older.
TheGraye28
And wastegate has to be a 44
Mm vband right? Kinda screws up my plans to use a synapse
JesterMX6
Post by JesterMX6 »
yes it's 44mm vband. can always run an adapter in between, but you may run into clearance issues.
