90e34535i
Post
by 90e34535i »
I need 4 studs to bolt the Turbo to the M30 Turbo Manifold, What size are the studs? (they look a little bigger than the stock exhaust studs)
Thanks!,
-RJ
Tjn182
Post
by Tjn182 »
I'm pretty sure the TCD manifold uses your stock 8mm studs... no need to replace them.
The 745i manifold on the other hand is different
90e34535i
Post
by 90e34535i »
Im going to use the stock studs to mount the Manifold to the engine.
But the 4 bolts that hold the Turbine Housing to the Manifold is what I need.
Tthe stock exhaust manifold studs are too small, its some size a little bigger.
Thanks,
T_C_D
Post
by T_C_D »
3/8-16
90e34535i
Post
by 90e34535i »
Thanks!!
Gonna go pick some up tommorow and finish up my cheap looking intake+charge piping.
