Remember the discussion about front cover
Velocewest
Post by Velocewest »
replacement for people who go with a crank fire ignition and don't need a dizzy?
This product would be useful if you decide to go with the early M30 front cover that has a conventional distributor mount.
It also wins the rip-off part price of the week award! :shock:
GregATL
Re: Remember the discussion about front cover
Post by GregATL »
You sir would be correct.
Wiseguy
Post by Wiseguy »
I don't think it's overpriced at all. Machined out of aluminum? Assuming they are having them made to their specs, that's not a cheap part to make in what are surely very small quantities.
DMNaskale
Post by DMNaskale »
There is always this:
Yes, the chunk of aluminum is pricey for what it is, but can you make one yourself for less? What is your time worth? What is it worth to have a simple, nice looking, drop in solution?
Personally, I would spend many hours and hundreds of dollars coming up with something that probably wouldn't work any better. But it is cheaper than a crack habit.
Velocewest
DMNaskale wrote:Personally, I would spend many hours and hundreds of dollars coming up with something that probably wouldn't work any better. But it is cheaper than a crack habit.
Not by much... ;)
j9fd3s
Post by j9fd3s »
while $30 is more than its "worth" it does, however look nice and its easy, and its still only $30
Velocewest
j9fd3s wrote:while $30 is more than its "worth" it does, however look nice and its easy, and its still only $30
Look again -- it's $52.50...
j9fd3s
Post by j9fd3s »
lol, yeah ok, i think id come up with somthing myself.... freeze plug maybe....
