Mildly OT: 11.48 1/4 mile out of a 2.2 liter engine on E85
Also, that time is at colorado elevations
http://forums.audiworld.com/rockymtn/msgs/64824.phtml
http://www.mswanson.com/~jgreen/car_home.html
This is the guy i was talking about earlier that was running E85 in his turbo quattro..
This is NOT the ultra-powerful 80tq.. that belongs to Javad, at www.034motorsports.com and www.motorgeek.com. 034 is also building a bi-turbo 3.6L V8 in the same 2900 lb quattro body
well i am not an expert at this stuff...
but..
the work the engine does in heating exhaust gas isn't necessarily work that is preferrable. Ideally you might think that the engine would put out cool air because it optimally extracts all possible energy from the combustion process. Naturally that doesn't happen.
Also, I think you are right or close to right that hotter air has more "energy" but that is a mixed bag. You need a certain amount of energy to drive the turbine (but i am not sure how much of that comes from heat vs gas flow.. or how the heat changes the gas flow).. but at the same time, heat soaks through the exhaust side of the turbine into the compressor side (the compressor itself is already heating the air it compresses)
heat on the intake air side of the turbo is why aftercooling is necessary to begin with, so there must be a tradeoff between getting heat into the turbo charger and keeping heat out of the intake air charge.
in any case, in the "real world" E85 burning cooler is seen as a big benefit in turbo cars.
but..
Which means lower gas mileage. In addition, ethanol is still a net-negative energy source, meaning you expend more energy from hydrocarbons making EtOH than you get out of the EtOH when you burn it. Sweeney, pure (absolute) ethanol is hygroscopic, so the SAAB engineers were probably working with essentially 95% ethanol. But you knew that. What I'm curious about is the potential damage of water on fuel system components (thinking mostly corrosion here). Even in E85, increased water miscibility is a cause for concern.altus22 wrote:It does have a higher octane rating, but remember, it has a lower energy density which means that you have to put more ethanol in to get the same power out.
-tammer
Tammer, actually, yeah, I do know that... You're correct, corrosion due to the water content was the biggest problem in the past, but, most modern fuel systems have poly tanks and stainless or plastic wetted surfaces.
Sugar cain, man! It's all about sugar cain so you can skip the starch to sugar step that's required with corn.... silly corn...
I am far from being any kind of environmentalist, but here's my interest in E85Tammer in Philly wrote:Which means lower gas mileage. In addition, ethanol is still a net-negative energy source, meaning you expend more energy from hydrocarbons making EtOH than you get out of the EtOH when you burn it. Sweeney, pure (absolute) ethanol is hygroscopic, so the SAAB engineers were probably working with essentially 95% ethanol. But you knew that. What I'm curious about is the potential damage of water on fuel system components (thinking mostly corrosion here). Even in E85, increased water miscibility is a cause for concern.altus22 wrote:It does have a higher octane rating, but remember, it has a lower energy density which means that you have to put more ethanol in to get the same power out.
-tammer
1) cheap race gas
2) decouples cars from foreign oil
3) doesn't drastically change how cars are made, run, or "feel" (as compared with a Prius or something that is an ugly, uninspiring slug of a vehicle)
Let me explain #2 a bit more. In software design we talk about decoupling a lot because we are bad at predicting change, and tight coupling makes changes expensive later. Adding indirection gives you flexibility and gives you opportunities to make improvements surgically without affecting the overall stability of the system
So how does that apply here?
Today, cars are coupled directly to gasoline. Nobody knows of a scalable way to make gasoline apart from fractionally distilling it from imported crude oil. Making gasoline is expensive in terms of the specificity of the resources required, the actual costs of acquisition and refining, and the less tangible costs of foreign oil dependance and continued involvement in the middle east. Without getting into all the details, let's just agree that if we had an attractive alternative to gasoline, we'd use it.
Gasoline is a pretty specific thing.. the more specific a thing is, the fewer obvious ways there are to create it.
Now, ethanol.. ethanol is a much more fundamental chemical than gasoline is. If we change the game so that vehicles are running on ethanol - even though that ethanol is made from gasoline today, we've bought ourselves some future flexibility.
Just like in software, flexibility and coupling come at a price - usually efficiency. So by moving to E100 or E85, we've bought some flexibility (cars are now insulated from gasoline, and are instead coupled to Ethanol, a more general concept), but we've lost some efficiency (today, it is arguably a net energy loss to run american cars on american made E85)
Now, while today E85 might not be more efficient than just using the fossil fuels directly, we know that there are other ways to make Ethanol (i.e. sugar cane waste-products).
Because ethanol is a simpler chemical, and because we've seen demonstrations of this, we should be convinced that it will ultimately be cheaper and easier to make ethanol than it will be to continue to make gasoline.
So while today, E85 production in the US is inefficient, don't count it out. Once there is a market demand for E85, people will figure out how to make it cheaply and efficiently, and eventually the work we did decoupling our cars and thus our country from foreign oil will have paid off.. even though we don't know what that ultimate solution will look like today.. we still know that decoupling cars from gasoline is a good move..
Matt
Agile Software Developer
