backfire megasquirt turbo
charofire
Post by charofire »
After searching around, it looks like I did not wire my wasted spark correctly according to DIYautontune. I need to make sure I have coil power going through a relay that is switched with the fuel pump relay output. Where would I found the fuel pump relay output in the engine bay? thanks
Mark 88/M5 Houston
Re: backfire megasquirt turbo
Post by Mark 88/M5 Houston »
Both the main and fuel pump relays were originally installed on the engine side of the fuse box. You will want to locate the 4 pin/connection relay with a 1.5mm GN/VI wire coming off pin 87. Or you could tap the fuel pump circuit inside the fuse box at F1 again at a 1.5mm GN/VI wire.
Download an ETM from here: http://wedophones.com/BMWManualsLead.htm
