Minerva: The S54 powered, better than new, E28
jjcarr
Re: Project 'Blue': Yet another S54 powered E28
Post by jjcarr »
That's not bad for that many items, thanks.
Prices may have changed but last year, from Richard at Arrow:
Pricing is $0.30/lb $30.00 minimum. This is for barrel plating of the fasteners. If you have brackets or other parts besides fasteners then that is rack plating and fall under the same pricing but cannot be combined with the fasteners for the lot charge, it is a different process hence the separate charge.
Whiskey tango foxtrot Charlie? Where's my daily inspiration to waking up?
lloydse28
Post by lloydse28 »
I don't think he's in the country right now.
86GT635
Post by 86GT635 »
I thought about bombing this thread about a hour ago, purely out of friendly narcissism.
Maybe one day.. SMH. *Finger wag* Get to work boss. ;)
bkbimmer
Post by bkbimmer »
leadphut wrote:Whiskey tango foxtrot Charlie? Where's my daily inspiration to waking up?
The best part of waking up is buttceks in your two guys one cup.
Bite me.
EventuallyAyrton
Location: Wherever the E28 happens to be parked- Morrisville, NY
Post by EventuallyAyrton »
cek wrote:Bite me.
Don't tempt us
:poke:
Needs more photo content :zzz:
:popcorn:
In your-up. Nothing to report except Ivo's Zobelbraun M5 is an inspiration.
puma1824
Post by puma1824 »
How's it coming along? Finally got mine started this past week.
In my head, swimmingly.
Dont hate on me, but I'm gonna be using my checkbook-wrench more than originally planned.
EventuallyAyrton
Will you at least post pictures of the progress accomplished by the other guy? What will they be doing?
bkbimmer
Post by bkbimmer »
Checkbook wrench, I like that.
:yawn: Are you done yet?
How about now?
I'm going to need to borrow a wrench. Will you hand me that Checkbook Wrench please? :banana:
EventuallyAyrton
oldskool wrote:I'm going to need to borrow a wrench. Will you hand me that Checkbook Wrench please? :banana:
I know you can do better than that...
byf_42
Post by byf_42 »
Damn, I need one of them fancy 'checkbook wrenches'! Us poor folk gotta make do with a regular-type wrench! :rofl:
Dubs
Post by Dubs »
UPDAAAAAAAAAAAAAAAAAATES
please
bkbimmer
Post by bkbimmer »
You need to hire Chuck Fist, he'd do you right.
Got a crack-free dash. I'm still undecided on whether to go naked or covered. If I cover, then this one will go in Vlad since it has some tiny cracks that will cover well. If I go naked, then...
I have been working on my wiring harness. I've decided to use my checkbook wrench and pay a guy on R3V for the harness adapter. The E46 S54 harness is too short to reach into the glovebox. The Z3 M harness is longer, so I sourced a new one of those via Ivo. I goofed around with both today measuring and trying to figure out how I'll mount stuff.
I've decided to go with an E36 terminal block (after seeing joel323's S52 car again this weekend and seeing how sharp it looks). Ordered the parts. This also settles how I'll be running the power cables to the trunk-mounted battery...instead of doing the M5 way, I'll do what Joel did and run them down the passenger's side. Battery will be mounted on the pass side of the trunk ala the M5, but slightly more compactly.
I don't think I mentioned this before, but I have everything regarding the ECU figured out. I even have my custom flash ready to be programmed once I have the right cable and the ECU is in the car. I've also figured out how to make cruise control work using the standard E28 stalk!!!
Here are the M50/M52 mounts I purchased. Nobody seems to know if these will work on an S54 or not, but I can always sell them...
I also ordered a 3-turn M5 steering box.
With that, I think the only major components I don't actually have are:
- Seats
- Diff
- Exhaust
Still a lot of little parts missing, and things that need to be modified...
