I have a 1984 M635csi, with the entire Dinan turbo package (stage 3). I'm planning to spin a new timing chain and replace all the rails/tensioners. Logic says do the valve guides/inspect heads while I'm in there.
Here's my conundrum:
I've read posts by Ken H around here stating the e28/e24 Dinan M turbo cars had copper head gaskets, and were cut for O-rings. I'm not scared of the O-rings, but when I call Dinan for a replacement gasket, I might as well be trying to order a custom submarine periscope from them. They seem lost without their founder. Hell, I even gave them the part number, and they tried telling me to use an E34 M5 gasket.
Where can one source a copper head gasket for the m88? A race builder I know says it can be reused if removed properly, but I'm squeemish about that idea, since any leaks will involve another tear-down, which is extremely detailed on the turbo cars.
I'd love anyone who knows the Dinan cars to chime-in. I'd like to get this process underway ASAP.
Copper head gasket for Dinan M88/3
Re: Copper head gasket for Dinan M88/3
I will check with the shop I use. The owner races an E30 M3 and seems to have a plethora of unusual resources. I also think I have a documented process of the conversion to a duplex chain in my former Euro M5 if you are thinking of going that way. I will check when I get home next week.
That would be a HUGE help! I spoke with a shop in New Hampshire about the conversion, as I thought maybe they could pull it off without pulling the cam box or heads. (Mario is the owner's name, and he's posted here a bit.)m-racer wrote:I will check with the shop I use. The owner races an E30 M3 and seems to have a plethora of unusual resources. I also think I have a documented process of the conversion to a duplex chain in my former Euro M5 if you are thinking of going that way. I will check when I get home next week.
The heads will need to come off, so all bets are off now.
Any updates? I'm about to crack-into this monster, and I'd love to have all the parts before I start.
If you are cut for orings that will help with any gasket. I replaced 6 hg in 6months,(my lack of tuning skills to blame) became way too good at it. I go with the m5. The long head can be tough to seal,especially when boosting hard. Mine has a slight oil leak on the intake side,but continues to seal otherwise.
good luck
good luck
