T4 Hot side size?!
T4 Hot side size?!
What size of hot side are you guys running?
Im shooting for 500whp stock b34 block + b35 head.
Got E85 setup already done and ready to go.
Im running 44mm and RSI turbo manifold non split pulse.
3.5" straight exhaust.
Re: T4 Hot side size?!
.58 or .69
It's going to be very laggy with 7.4CR and the tubular manifold and B35 cam.
Whats the recommended CR for that power range and E85?
Probably 9.0CR. Use a b35 bottom end if avalable.smhheidari wrote:Whats the recommended CR for that power range and E85?
Which E32s have the b34 style mounting casting blocks?
I heard before 1/88, is this correct?
ETK doesnt show any difference between pre 88 and post 88.
and all 88/89 e24 635csi.smhheidari wrote:Which E32s have the b34 style mounting casting blocks?
I'm with TCD.... I would go up in compression for sure.... even if you just get back to 8:1 with a stock b34 head
To help answer your question though, I'm running a 6266 with a .81 hot side and getting full boost (20-21lb) at ~3300..... this is on a b34 with a b35 cam
how much CR i get with dirty b34 pistons/b35 head?
Borg S300 .91 twin scroll. Currently at 17.5 psi with e85. Full boost by 4kish. Stock b34 with some headwork, valves and a PB cam. Still taking it easy with the tune, I'll have more concrete characteristics when I get on a dyno. So far the car doesn't feel too laggy.
Borg S3xx is my first option, but they dont come with anything less than .88.
I found this tho:
http://www.ebay.com/itm/322199073964?_t ... EBIDX%3AIT
@M. Holtmeier
How high your engine revs?
I found this tho:
@M. Holtmeier
Stock Redline.
I would switch to a twin scroll manifold.
Where can i get one for reasonable price?
That's just it, twin scroll m30 turbo manifolds are pretty much all custom built to order.
M. Holtmeier wrote:Borg S300 .91 twin scroll. Currently at 17.5 psi with e85. Full boost by 4kish. Stock b34 with some headwork, valves and a PB cam. Still taking it easy with the tune, I'll have more concrete characteristics when I get on a dyno. So far the car doesn't feel too laggy.
Which S300 are you running? Getting a smoking good deal on a new one and can decide between the S362 and S366.
S366.
.91 A/R divided or .88 A/R open?
.91 divided.
when do you see boost start to come in? You said in a previous post is full by 4k.
also who's manifold are you running?
