So exactly what else would I need to make this work...
efreak
Post by efreak »
http://www.craigslist.org/eby/pts/168480396.html
Links to any suppliers would also be nice. Thanks guys!
Yellow2
Post by Yellow2 »
From what I can see,you need the following.
1) Lots of beer.
2) Longer 8mm exhaust studs to attach e.manifold to the head.
3) A pipe to get from the turbo to the intercooler.
4) Maybe a custom motor mount depending on model.
5) No ABS if you decide to use that intercooler
Cant think of too much more. Maybe in the morning.
efreak
Post by efreak »
Yellow2 wrote:From what I can see,you need the following.
1) Lots of beer.
2) Longer 12mm exhaust studs to attach e.manifold to the head.
I also have a 533i so I don't have ABS from the factory (bonus?).
What about the fuel and timing requirments?
Any idea about the block?
Yellow2
Post by Yellow2 »
I am running the same 008 ECU and I maintain stock boost (8psi) with the wastegate. I have stock 533i injectors. The no ABS is a plus as the IC pipes right there. Here is a pic of my IC through the front. Stock fuel pump, fuel filter change, premium gas, stock block but its changed from an '87 m30 535iS motor. I see no problems running stock boost levels. If yo uwant to run higher, get an 059 ECU and get larger injectors + rrfpr or talk to TCD about getting a made kit. A little more and you get great help. Here is how mine is setup.
http://usera.imagecave.com/tjn182/intercooler12121.JPG
russc
Post by russc »
Theres no electronics in the pic to run the fuel enrichment you'll need. So a FMU is in order as yellow said.
Tjn182
Post by Tjn182 »
1) Lots of beer.
12mm studs - Are you high?
They're 8mm.
and to add-on to #4 - a 533i passenger's side mount works well too.
Yellow2
Post by Yellow2 »
No but we did get a keg..... :banana:
