NA: 1983 Mercedes 240D MT
SPF2006
Post by SPF2006 »
I have seen this car and for those who like the W123 platform (and know the limitations of the 240D but appreciate it for what it is), this looks like a pretty solid daily driver/winter beater. Engine runs well (does not shake itself to death) and the manual transmission makes a big difference. Given that most of these 80s Mercs at this price point are either significantly rusted, or if not are exorbitantly expensive, this one looks right on the money for the price. Seller just got it MD safety inspected which is a big plus.
https://baltimore.craigslist.org/cto/5862192271.html
Mercedes 240D 1983. 289,000 miles. I have owned this beauty for 9 years. This is a 4 speed manual with a 2.4L diesel engine. This car has an reliable, solid engine and could run for another few hundred thousand miles. The fuel mileage is 31 mpg. There is a manual sunroof and Am/Fm cd player. Oil changes and other regular maintenance has been performed. Previous owner kept this in the garage. The floor boards and rocker panels are solid with very little body rust (see photos). This classic has a Maryland State Inspection Certificate.
VIN WBDAB23A5DB406105.
Price: $1600.
Phone: 410-588-six, zero, zero, 7.
This car has some minor blemishes and paint oxidation, and needs some small items like idle knob, drivers side door check, and the visor mirror needs fixing. There is a small rip in the headliner and the drivers seat is splitting. There are two small splits in the dash. The a/c needs charging.
Maintenance/new parts:
-Replaced front shocks, transmission mount, inner control arm bushings, adjust valves, new valve cover gasket, ignition tumbler, - 258,000
-Replaced rear disk brake pads, calipers, flexible brake line, replaced instrument lights, painted instrument gauge needles, installed block heater- 260,000
-Replaced two door checks- 264,000
-Replaced fuel injector nozzles- 268,000
-Replaced starter- 270,000
-Replaced front and rear windshield gaskets - 270,000
-Replaced drive shaft carrier bearing - 277,000
-Replaced glow plugs - 277,000
-Replaced starter, muffler, fuel tank - 279,000
-Replaced alternator and belts- 282,000
-New front tires - 285,000
-Replaced all 4 door seals, new battery- 289,000
dsmith
Re: NA: 1983 Mercedes 240D MT
Post by dsmith »
So many times I've wanted to pull the trigger on one, but it really isn't fun not being able to get out of people's way. There were 3 nice ones available locally this year, and I almost did it. One was manual everything. These made my Ford Aspire seem like a rocket ship.
