Cracked sport seat hinge gearbox - first prototype ready
Yojedi
Re: Cracked sport seat hinge gearbox - first prototype ready
Post by Yojedi »
tn535i wrote:Very very nice work by the OP.
I guess those plastic covers can be 3D printed by someone.
That's a really good suggestion. Since the 3D model is now available would the OP mind getting a quote for 3D printing? Could be a "possible" low-volume, low-cost option but don't quote me.
BenGerman
Post by BenGerman »
Thanks guys!
It still needs little adjustments here & there but thats why they are prototypes.
Yojedi wrote:That's a really good suggestion. Since the 3D model is now available would the OP mind getting a quote for 3D printing? Could be a "possible" low-volume, low-cost option but don't quote me.
I think we are talking about two different things here. The actual gearbox plate that I machined and the plastic covers that go on the outside to cover the gearbox. (who would want to cover some shiny aluminium anyway, haha)
I was thinking about 3D printing before but I don't think a material that will be strong enough is actually a lot cheaper than machining it.
Maybe I will find some time later to contact a couple places. For now we have all the soft jaws made up and everything in place to machine them.
Potentially by the end of summer/fall there could be a solution for the back side of the gearbox as well.
Yojedi
Post by Yojedi »
BenGerman wrote:Thanks guys!
BenGerman, nevertheless kudos for undertaking such project. As most of parts for E28 are already NLA these 3D models you are constructing will be invaluable to the preservation of these fine German specimens and our community. :clap: :clap: :clap:
BenGerman
Post by BenGerman »
Negotiations with the machine shop are completed.
I started a group buy thread here:
http://www.mye28.com/viewtopic.php?f=4&t=143376
I will keep this thread updated with pictures and a install video.
BenGerman
Post by BenGerman »
We got 14 pieces together, I'm about to place the order with the machine shop.
If you still want one, let me know until 8pm ET tonight.
tn535i
Post by tn535i »
I was looking at the gearboxes on my 6er's driver's seat last night which is out of the car and they look perfect to me. I'm unsure how the box gets so much stress to crack but I trust you that they can. I remember my driver's seat somehow the two sides were clocked wrong when I got the car with one side leaning forward of the other. It really bugged me and felt different than the passenger seat until I discover and fixed that. I'm thinking it was mostly due to things being loose.
This part is so well executed I almost want some for that reason alone. I will take a much closer look at mine tonight and decide.
BenGerman
Post by BenGerman »
Thanks for the compliments again.
If yours are not cracked, that's awesome! It probably also has to to with the previous owners: how often it was used, weight,...
I will send everybody that was initially interested a mail, since I would like to close things by tonight.
Raw material is in stock and there is a slot in 2 weeks on the machine that I would like to use.
The final part will be black anodized.
I will bring some with me to the Vintage.
I have aluminum over this (that's like wood, but more metal).
Take my money! Seriously.
BenGerman
Post by BenGerman »
cek wrote:I have aluminum over this (that's like wood, but more metal).
I can make you one out of wood for your money?! ;)
ElGuappo
Post by ElGuappo »
This is sofa king cool.
I love these modern solutions to old problems.
For a while it seemed like everything had been figured out on these old girls...
BenGerman
Post by BenGerman »
Thanks for all the good feedback. I'm glad stuff like this is appreciated!
Only because of the interest and amount of parts that we got it was possible to produce these goodies for a reasonable price.
I'm always up for new solutions on stuff like that.
I'm about to close out on the orders tomorrow, by next week I will have a anodized sample for pictures.
If something similar ever comes to somebody's mind, I can see if we can realize it again.
I will have a couple samples with me at the vintage!
BenGerman
Post by BenGerman »
All the plates have been sent out two their new owners. Again, I'm sorry for the delay caused by the plating process.
I hope everybody is happy with the outcome. Let me know if you have any issues mounting them.
Thanks again everybody for making this happen, without I would still be sitting sideways in 2 of my seats. :D
Here are the instructions. I tried to cover it in a video, but it didn't work the way I wanted int to. I think the pictures are easier to follow.
Please remember that these are tips from my side, I will not be responsible for any damages caused during the steps of this manual or afterwards.
You need:
17mm
7mm
6mm
4mm
3mm Allen
Flat head screwdriver
Knive
Plenty of rags
Cold Beer
Bring seat in a position where you can easily reach all the bolts.
Remove seat belt.
Remove plastic cover nut (that is missing in all of my cars :( ).
Pull off cover
Remove 4x7mm Hex screws
Carefully pry work your way around the front cover with a small flat head screwdriver, do not lever to hard one one side, or you will break the plate in half
Be careful not to loose any of the 4 plastic guides or the washer setup, take them off the plate, clean and place in their position. The grease will hold them.
The washers go on the worm gears in the bottom. Order: metal, rubber, metal.
Time to Press out the bushings:
Place the 17mm socket under one of the big bushings to support, use a 6mm socket from the top. A couple of gentle hits with a plastic mallet should break them loose.
Repeat for second bushing.
Place the socket below the red plastic bushing in the bottom of the plate. Using a 4mm socket, repeat as before. These usually can be pressed out by hand.
Take the new aluminium covers, place them on a soft surface (rag).
Start with the two big bushings, gently tapping them in with a plastic mallet. Make sure they stay straight. It takes a little bit of force, to get them back in.
Press the two red bushings in by hand.
Time to get the leftover grease of the old plate. The grease should be in great shape, I decide not to replace it. If you do so, please remember to take a grease with a really high drip point. It gets hot in these cars in summer and the last thing you want is grease dripping on your nice carpet.
Place the leftover grease around the seat gears, don’t forget the two little plastic gears in the bottom.
Place the new plate on the gearbox, make sure all the plastic pieces and washers from the beginning are still in place. Make sure you align all the 4 shafts that go into the bushings. Press it onto the shafts by hand. You might not be able to fully seat the front plate. No worries, the bolts will take care of this in the next steps.
Take 4 of the M4 stainless bolts out of the bag, place them in the holes and use a 3mm allen to tighten them down. As usual, don’t tighten one screw down all the way, as the plate needs to be seated. Work your way around the plates a couple of times.
Wipe out the leftover grease out of the busing holes.
Now it’s time to modify the plastic cover, probably the “scariest” step of all. Place the plastic cover on a soft rag.
Take a thin blade and slowly cut your way through the three main “ribs” of the back side. Do this in multiple slow steps, not to break the plastic cover. I modified all 12 of my covers without breaking one.
Place the modified plastic cover over the plate, make sure to align the top threaded bolt with the “guiding rod” on the back of the plate. Tighten down the nut.
Mount the seatbelt back to the seat, make sure to align the little tab with the hole in the seat.
Tigthen the bolt to spec with NM. Remember, the seatbelt is safety critical, you don’t want to realize in a crash that the bolt was not tight to too tight and the seatbelt comes loose.
Repeat 4 more times for the remaining covers.
Open Cold beer and enjoy it in your car seats. ;-)
dan101smith
Post by dan101smith »
Having almost rocked myself to sleep on the drive to Le Mans today, please let me know if you're doing another run as I'd like to order. Thanks!
BenGerman
Post by BenGerman »
I have already arranged getting a second batch made, but we have not timed it yet.
Before we do that I would like to have more feedback of the first round buyers.
BenGerman
Post by BenGerman »
Since I keep getting requests for these from time to time...
I won't have the time to organize another group sale. :(
If anybody wants to take the lead and organize a larger batch, I can still have these made at a minimum order quantity of 20 plates (10 left, 10 right). Price will be $100 a plate with about 3-4 months lead time.
TroyArboc
Post by TroyArboc »
I would be very, very interested (in a few sets) should anyone else take the over and move forward with a group buy.
BenGerman
Post by BenGerman »
Let's give this a month or two and we see how it goes.
lswoboda
Post by lswoboda »
I’d be in for a set (whatever I need for both front seats).
To be clear, this fixes the “rocking” that affects (plagues?) our cars, correct?
Btw, the “how to” by BenGerman is excellent! Very clear and well written. Thank you for all your efforts.
Thanks.
TroyArboc
Post by TroyArboc »
Bump
jayjaya29
Post by jayjaya29 »
In for 2 sets as well if it happens.
TroyArboc
Post by TroyArboc »
jayjaya29 wrote: Jan 27, 2022 1:21 PM In for 2 sets as well if it happens.
Halfway there
BenGerman
Post by BenGerman »
Might be worth sharing in the Facebook groups and on Bigcoupe?
The E24 has the same issue.
joema
Post by joema »
I'm in for a set too, if/when it becomes available.
Badger
Post by Badger »
I would be in for a set for both front seats also.
Is the rocking the entire seat assembly or just the back to the seat cushion?
TroyArboc
Post by TroyArboc »
Mike W. wrote: Feb 05, 2022 8:11 PM Is the rocking the entire seat assembly or just the back to the seat cushion?
It could be a combination of things but the most common cause is cracked motor casings.
charofire
Post by charofire »
Count me in for a set. Thanks!
elcrazon
Post by elcrazon »
Interested in two sets, if this happens
BenGerman
Post by BenGerman »
Alright, let’s do this.
Closing date for orders is 3/15/22. Write me a PN with:
Your Name
Your address
How many left and right pieces you want
lswoboda
Post by lswoboda »
Sent PM. Thank you!
BenGerman
Post by BenGerman »
Anybody else? Haven’t received a PM from everybody that was interested yet.
Chimi-Changa
Post by Chimi-Changa »
Let me know when you make manual sport seat parts! ( You know how my seats are...) :D
Northeast OH? :laugh:
SharKnows
Post by SharKnows »
I would like a set for my drivers seat . Tried sending you a message Ben but I couldn’t get it to work, maybe because I’m in my phone
Badger
Post by Badger »
Sent one earlier!
BenGerman
Post by BenGerman »
Got some PMs. Will Follow up in a few days with details.
:wave:
Keeping you on top of things. :laugh:
BenGerman
Post by BenGerman »
Time window is closing. Anybody interested should order now.
Badger
Post by Badger »
money sent, thank you
lswoboda
Post by lswoboda »
Money sent and sent address via PM.
Thank you.
joema
Post by joema »
I sent a PM on the 15th, hope you got it.
