It may be problematic to copy the weird cutouts in that third unused panel but it would be easy to make it the same as the other two. What is it used for anyway? Let me know what the preference is so I can discuss with the shop.RonW wrote:Is it difficult to cut the extra holes for the unused panel? It would keep the look authentic, and those panels conceal most of the bracket which would mitigate paint or texture issues. Also, it would allow the use of whatever went in that third panel.
Laser cut light switch surrounds. - None left
Re: Any interest in a laser cut light switch surround?
I'll take one, I've purchased several over the years due to cracking, would love to have a steel one
Third hold is for the headlight beam adjuster. Not many cars have this and I believe the retrofit kit is nla.
I use that space to install a blank as our cars came with but modified to add a switch to allow changing from dual brake lights to rear fogs as conditions require. Extra brake lights get the most use.
I'll take one, please!
Nice option. So what dimension does the third opening have? Should I make it the same size as the other two? Or should there be no opening so you can modify as needed?Blue Shadow wrote:Third hold is for the headlight beam adjuster. Not many cars have this and I believe the retrofit kit is nla.
I'd take two! Great idea Jim.
Here's the list,
MicahO - 2
atibbitts
Philo
Rich in Tupelo - unpainted
cibie - 2
russellrh72
flywheel86
Bimmerman
dsmith
Sam 84, 533i
ma.jomaa
TCBimmer - 2
Can you guys update to mention your preference for a painted or unpainted version.
MicahO - 2
atibbitts
Philo
cibie - 2
russellrh72
flywheel86
Bimmerman
dsmith
Sam 84, 533i
ma.jomaa
TCBimmer - 2
demetk wrote:Here's the list,
MicahO - 2
atibbitts
Philo
cibie - 2
russellrh72 - painted
flywheel86
Bimmerman
dsmith
Sam 84, 533i
ma.jomaa
TCBimmer - 2
The 3rd hole should be sized to allow the cover to fit properly. I don't think there is a need for the fancy tooling to make the additional holes in that area, just the same type hole as the other two. You do have a cover to use for measurements, don't you? It clips in place so size needs to allow this.
OK let me check on that cover and see how it fits.
Man am I glad I hoarded some of the reinforced versions of this piece...They are so much stronger.
russellrh72 wrote:demetk wrote:Here's the list,
MicahO - 2
atibbitts
Philo
cibie - 2
flywheel86
Bimmerman
dsmith
Sam 84, 533i
ma.jomaa
TCBimmer - 2 - painted
Thanks, here's the updated list,
Here's the list,
MicahO - 2
atibbitts
Philo
cibie - 2
flywheel86
Bimmerman
dsmith
Sam 84, 533i
ma.jomaa
Sam 84, 533i - painted
Here's the list,
MicahO - 2
atibbitts
Philo
cibie - 2
flywheel86
Bimmerman
dsmith
Sam 84, 533i
ma.jomaa
demetk wrote:Thanks, here's the updated list,
Here's the list,
MicahO - 2
atibbitts
Philo
cibie - 2
flywheel86
Bimmerman
dsmith-2-unpainted
Sam 84, 533i
ma.jomaa
MicahO - 2
atibbitts
Philo
cibie - 2
flywheel86
Bimmerman
dsmith-2-unpainted
Sam 84, 533i
ma.jomaa
matchgrade - 2 - painted
MicahO - 2
atibbitts
Philo
cibie - 2
flywheel86
Bimmerman
dsmith-2-unpainted
Sam 84, 533i
ma.jomaa
I'm in for a painted one.
MicahO - 2
atibbitts - painted
Philo
cibie - 2
flywheel86
Bimmerman
dsmith-2-unpainted
Sam 84, 533i
ma.jomaa
MicahO - 2
atibbitts - painted
Philo
cibie - 2
flywheel86
Bimmerman
dsmith-2-unpainted
Sam 84, 533i
ma.jomaa
matchgrade - 2 - painted[/quote][/quote]
SlickDizzy - 1 - painted
MicahO - 2
atibbitts - painted
Philo
cibie - 2
flywheel86
Bimmerman
dsmith-2-unpainted
Sam 84, 533i
ma.jomaa
+1 painted please.
Thanks
Drew
Thanks
Drew
In for a painted one.
I'm in for one - painted.
Painted please.
Thanks, here's the updated list (26 pieces)
MicahO - 2
atibbitts - painted
Philo
cibie - 2
flywheel86
Bimmerman
dsmith - 2 - unpainted
Sam 84, 533i
ma.jomaa
afeustel - 1 - painted
Wolf1971 - 1 - painted
ma.jomaa - 1 - painted
MattC - 1 - painted
athayer187 - 1 - painted
I haven't finalized the number of pieces yet with the shop. Looks like I may do 40 pieces.
MicahO - 2
atibbitts - painted
Philo
cibie - 2
flywheel86
Bimmerman
Sam 84, 533i
ma.jomaa
MattC - 1 - painted
I'm in for one. Painted. Thanks.
What's eta on these? Mines broke. It actually might be the last broken thing in the interior plastic other than dash.
They're a week away from being made and then they need to be painted. So I would say 2-3 weeks.
- Beamter
Painted please, thanks!demetk wrote:Thanks, here's the updated list (26 pieces)
MicahO - 2
atibbitts - painted
Philo
Nebraska_e28 - painted
cibie - 2
flywheel86
Bimmerman
Sam 84, 533i
ma.jomaa
MattC - 1 - painted
MicahO - 2
atibbitts - painted
Philo
cibie - 2 - painted
flywheel86
Bimmerman
Sam 84, 533i
ma.jomaa
MattC - 1 - painted
atibbitts - painted
Philo
cibie - 2 - painted
flywheel86
Bimmerman
Sam 84, 533i
ma.jomaa
MattC - 1 - painted
I'll take a painted one - but will take one either way, painted or unpainted
1 painted
Thank you Demetk for the work, and foamy for the work too. Foamy did all the heavy lifting with the measurements and prototype. He does need to be "reprimanded" for such a heinous deed. How can I tip the inventor?
