head bolts and other misc quesstions
zundfoldge
Post by zundfoldge »
are bmw factory head bolts able to hold up on a turbo m20? and if not who do i go to for some stronger ones?
Tjn182
Post by Tjn182 »
They are but
most people go with the ARP head studs, they provide a much better seal and make head gasket replacement easier.
zundfoldge
can i put two head gaskets on my car to lower the CR ? and if so is this safe to do?
Just get a freaking Multi-Layer Steel (MLS) gasket!!! They can be ordered in several thicknesses and can easily lower the CR.
FastFiver
Post by FastFiver »
Kyle in NO wrote:Just get a freaking Multi-Layer Steel (MLS) gasket!!! They can be ordered in several thicknesses and can easily lower the CR.
But thoooooose cost money! I want a cheap turbo systemmmmmmm..... waaaaaaaaahhhhh!
zundfoldge
it dosnt have to be cheap>>>>>> i did some experimental head work. and if i could just put two head gaskets together for a trial run to see how she goes then it will save the cost of buying two gaskets at the price of i think the are about 200 usd each. i may be wrong.
I seriously doubt the fire rings will seal properly for long, if at all.
Yellow2
Post by Yellow2 »
Jeremy wrote:I seriously doubt the fire rings will seal properly for long, if at all.
i second that. go MLS or go home. save a few bucks( and you are only saving a few) will come back to haunt you later.
For "test run" purposes it will probably work fine. I just wouldn't beat on it set up like that...
Mark 88/M5 Houston
Post by Mark 88/M5 Houston »
Seems to me that you could calculate the needed thickness of the head gasket for any (within reason) compression ratio. All that will cost is a bit of time and a few tools.
Here are a few links:
http://www.csgnetwork.com/compcalc.html
http://www.rbracing-rsr.com/compstaticcalc.html
http://www.circletrack.com/techarticles ... mpression/
Bill in MN
Post by Bill in MN »
MLS can be used more than once. I'm on my 3rd go around and have experienced no issues at 15+psi.
M635CSi
Post by M635CSi »
zundfoldge wrote:it dosnt have to be cheap>>>>>> i did some experimental head work. and if i could just put two head gaskets together for a trial run to see how she goes then it will save the cost of buying two gaskets at the price of i think the are about 200 usd each. i may be wrong.
I wouldn't run two head gaskets even for a trial run. I don't even like the idea of a thick head gasket but it seems to work OK. What is the compression ratio of your engine?
zundfoldge
right now with milling the head and polishing the chambers after wards umm lets see .........8.75 to 1 cr i would like to be just below 8-1 cr
zundfoldge
Mark 88/M5 Houston wrote:Seems to me that you could calculate the needed thickness of the head gasket for any (within reason) compression ratio. All that will cost is a bit of time and a few tools.
thanks this was help full . i think im just going to go for what would be if i have if figured right realy close to 8to 1 cr. i gotta get my calculator to make sure.
zundfoldge
how low comp ratio is to low?
