I Have A new 335is
bmw335is turbo
I Have A new 335is
Post by bmw335is turbo »
I found a 335is that was in need of fine tunning.
Needs a little work but it runs! I will get pic's as soon as I can
the m30 is a e34
Awesome! Glad to hear you are back in action!
bmw335is turbo
"O" Ya the car runs ok, But needs some work.
Lets put it this way just to kick back and drive "MY" 335is feels great.
I can't wait to get started on it but it will just have to wait until after the first of the year.
Craig -535i- Seattle
Post by Craig -535i- Seattle »
Did you buy Devin's car?
bmw335is turbo
Craig -535i- Seattle wrote:Did you buy Devin's car?
Ya it was.
so you know of it.
Not directly, but I'm local to Devin and have interacted with him on the local board occasionally. Seems like a nice kid.
bmw335is turbo
Craig -535i- Seattle wrote:Not directly, but I'm local to Devin and have interacted with him on the local board occasionally. Seems like a nice kid.
I do not know him he had a lot of good idea's he just never finished them the car should not be on the street. until it get's fine tuned.
but its my problem now and I will get to work it is just going to take an allinement shop most of the day getting everything to work with eachother.
bmw335is turbo
Well the alinement is done their were a few thangs that were installed 180 degrees off but the car kind of run's and is pretty quick BUT it handles like a race car man they found some pretty neat thangs done to this car.
Here is a few. (this is the prevous car owners writeup)
1986 BMW 325 2 DOOR (M30 SWAP)
1991 535i M30 Engine (3.5l inline 6)
• Turner Motorsport Jim Conforti Performance Engine Chip ~235hp at the crank
• Bosch Design II (4 nozzle) 19lb/hr Injectors
• New Water pump, Thermostat, Spark Plugs
• Ireland Engineering Urethane Race Motor Mounts
• e30.de M30 -> E30 Motor Mount Brackets Engine Position III
• Fully Custom Dual 2.25” Exhaust with High Flow Magnaflow Catalytic Converter and Stromung e30 M3 Rear Muffler Section (Very European Sound!!)
• Brand New E28 535i Radiator
• Zirgo 16” 3600cfm Electric Fan
Drivetrain
1991 535i Getrag 260/5 transmission (5 speed) 190k mi
• JBRacing Lightweight Flywheel
• SPEC Stage 3 Clutch Kit
• UUC Urethane Racing Transmission Mounts
• New Driveshaft from Driveline Services of Portland
• Understeer.com Short Shift Kit
Suspension
• Ground Control Coilovers
o Spring Rates: 425F/450R
• Koni Sport Adjustable Shocks
• Ireland Engineering Race Fully Adjustable Front Camber Plates
• Ireland Engineering 25mm Front Sway Bar and Mounts link links bushings
• Ireland Engineering 22mm Rear Sway Bar and Mounts link mounts bushings
• Ireland Engineering Urethane Race Rear Subframe Mounts
• Ground Control Rear Shock Mount Reinforcement
• Urethane Rear Trailing Arm Bushings
• E30 M3 Offset Front Control Arm Bushings
• New Control arms and Tie Rods
• H&R Hubcentric 4x100 15mm Spacers
• Genuine SSR GT1 17x7” Wheels (4x100) 17lbs each Lightweight Race Wheels
• Tires are Bravus Bavarium in the rear and Bridgestone RE750 Fronts (215/40/17)
Brakes
• Brembo Rotors Front Rear
• Stainless Steel Braided Brake Lines
• ATE Racing Super Blue Brake Fluid
• Pagid Front and Rear Performance Brake Pads
Misc
• Prolumen HID Kit 6000k H1 Bulb
• European Ellipsoid “Smiley” Projector Headlights
• Viper Alarm
• Kenwood 9102 Amp (1700 Watt)
• Sony 1502 Amp (760 Watt)
• 1991 535i Stock Speakers
• Sony CD Deck
• Alpine Type R 10” Sub in Custom Ski Pass Enclosure
• Schucks Auto Supply Leatherette Racing Seat in Driver’s Side
• Tucked Front and Rear Bumpers (Front is Color Matched to Body
T_C_D
Post by T_C_D »
Email me a picture and I'll host it for you. Sounds like a good platform. We you able to save the engine from the previous car?
Todd
bmw335is turbo
T_C_D wrote:Email me a picture and I'll host it for you. Sounds like a good platform. We you able to save the engine from the previous car?
Todd
everything but the chell,driveline,tranny good news I have extra parts such as 2 Chells 91 and now a 1986, 3 trannys 265's and 260's costom moter mounts and now de stage 3 motor mounts.
Todd you need to call me when you get a chance I have doubled my colliction.
