ok it's time
smackmybutter535i
ok it's time
Post by smackmybutter535i »
I'm sick of dicking around with beat to death used AFM's priced out a new one- $350. Priced out a megasquirt on Ebay
350 bucks for v3.0. seems to good to be true, what else do I need? I'm hoping with a kit like this I can run coil packs. Fill me in before I step to the dark side.
Rich in Tupelo
Post by Rich in Tupelo »
Check with Steve H. regarding AFM price. I think he can beat the $350 price.
M635CSi
Re: ok it's time
Post by M635CSi »
smackmybutter535i wrote:I'm sick of dicking around with beat to death used AFM's priced out a new one- $350. Priced out a megasquirt on Ebay
The reason 350 bucks for the v3.0 seems too good to be true is because you've only got part of the truth. There is more distance between having a Megasquirt v3.0 on your bench and your car running than there is between having a BMW AFM on your bench and your car running. 350 bucks does not buy a tuneable E28 turn-key fuel/ignition management system; I wish it did.
FWIW, I would forget about the coil packs; they're not worth the expense/effort.
Keep the installation as simple as possible, I believe Kyle is putting together a Megasquirt system so perhaps if you're nice to him he will help you.
I was lucky (better to be lucky than smart :laugh: ) to find (should be here this week) a Megasquirt v3.0 system with Dinan turbo M88/3 ign/fuel maps. The tune won't be perfect out of the box but I expect it will be close.
smackmybutter535i
Re: ok it's time
ok so lets say I ditch the coil pack what else will need to be bought to run the v3.0
and yes I know it will take tuning and knowlege on my part I just need to know what esle I may need. I will be making the purchase soon. Will I be beter off with the 2.0 or the 2.2?
altus22
Post by altus22 »
Just get the v3 board. The V2.2 board will require additional circuitry.
W/o coil packs, you need:
A sacrificial harness or adapter
Lots of wire
3 relays or possibly your stock ones
The toothed harmonic balancer from a b35
The VR sensor and mount for previous
Soldering skills
Lots of time
Computer skills
A laptop with a serial port
Vacuum line
I think that's it. It's been a while since I did mine (4 years) and mine was a carb to fool injection conversion.
I suggest getting your car to run on fuel only first and then play around with controlling the stock coil or wasted spark.
For wasted spark ignition:
3 coil packs
Connectors for coils
VB921 coil drivers
Associated bits for coil drivers
MSNSExtra code
smackmybutter535i
thanks!! that is what I needed to know. I have everthing to run the MS except the B35 harmonic balancer and VR sensor.
