Oil feed hardware
Oil feed hardware
Hey guys,
I'm piecing together a DIY turbo build for my e28 and I'm wondering where is the best place to get an oil feed from on the m30? Also what pieces do I need?
Edit: Also some pictures would be nice of some of your oil feed setups.
Thanks,
Jess
Thanks,
Jess
ok so where do I drill and tap exactly?
Reason I thought there would be part numbers involved is on my e30 I used some hardware to T-off the stock oil sensor to feed the turbo. I was assuming there was something similar on the m30. Anyone have any pictures of this oil feed setup?
Also would TCD sell just the oil feed lines and fittings?
I would say yes based on my experiences/dealings with them. Just because they sell a full kit doesn't mean they won't help you with parts for yours.Mark 88/M5 Houston wrote:Flip_Side_the_Pint wrote:Also would TCD sell just the oil feed lines and fittings?
Why don't you call and ask?
As Mark said give them a call.
http://home.mindspring.com/~scrappycrow ... nders.htmlFlip_Side_the_Pint wrote:ok so where do I drill and tap exactly?
Shawn D. wrote:http://home.mindspring.com/~scrappycrow ... nders.htmlFlip_Side_the_Pint wrote:ok so where do I drill and tap exactly?
thats just what I needed...
Thanks Shawn D.
And it looks like I don't need anything. Everything I need was left over from my e30 or I already had it in my garage....
