Larger valves
745turbo
Larger valves
Post by 745turbo »
Anybody know where to get larger (+1mm) valves for b35 head? Can't find them anywhere. I've know several places that have m10 39mm and 48mm valves, but I'm not sure if they fit M30!
JV
Skeen
Post by Skeen »
I can't say with certainty, but I would guess the M10 valves would fit.
90e34535i
Post by 90e34535i »
I remember Korman having a good price on Stainless oversize Valves for the m30 a litte while ago.
745turbo
Post by 745turbo »
Sent email to Korman. Will see what they say.
Any other possiblities?
JV
Azure
Post by Azure »
Ireland Engineering:
http://www.bmw2002.com
Catalog > BMW E28 > Engine > Page 2
745turbo
Post by 745turbo »
A while ago I tried to buy h-beam rods for M30 from IE, but somehow they didn't bother to answer me on e-mails. Also, they list only larger exhaust valves, don't see 48mm intake.
Anyway, will try again with them.
JV
Ken H.
Post by Ken H. »
cgraff
Post by cgraff »
745turbo wrote:A while ago I tried to buy h-beam rods for M30 from IE, but somehow they didn't bother to answer me on e-mails. Also, they list only larger exhaust valves, don't see 48mm intake.
JV
In short, 48mm intake valves are very tough to fit, although doable. The problem is you'll need custom machined valve seats, and to machine the head to fit them as well. The amount of material left on the stock 47mm valve seats is probably enough to do 47.5mm, but not any bigger.
I've had this discussion with Top End which does a lot of M10s and M30s. They also said that with bigger valves you'll want to check your cam duration and lift to make sure you have clearance during the overlap phase.
Again, doable, but difficult. 47/39 (intake/exhaust) is probably the easiest to with minimal effort (see: 80/20 rule). Stock valve seats, custom (inexpensive though) stainless steel valves, and so on.
-Chris
Jimmie G
Post by Jimmie G »
Topend performance seems to be a good source for the exhaust valves they have a very good price also.
Jimmie
