what to turbo.....
ke5crq
what to turbo.....
Post by ke5crq »
Hi everone, I was wondering what all I needed to do to my 87 535is so I could run about 10 lb of boost. The car is completely stock except for the conforti performance chip from turner.
Thanks for the advise.
Welcome - search the FI forum for a few days. There is so much knowledge here already and we really don't like posting it over and over again. If after that, you have questions let us know.
chrism
Post by chrism »
You'll want to loose the chip and buy a TCD stage 1 Kit.
http://www.turbochargingdynamics.com/tc ... bo_m30.htm
ke5crq
Post by ke5crq »
I love the kit, but I am hoping to spend a little less. I am planning on building all of it from scratch.
ke5crq wrote:I love the kit, but I am hoping to spend a little less. I am planning on building all of it from scratch.
OK, then - search the FI forum for a few days. There is so much knowledge here already and we really don't like posting it over and over again. If after that, you have questions let us know.
turbodan
Post by turbodan »
The big six is harder to do from scratch becuase there was no factory turbo manifold. Unless you want to make something, which is sketchy, you have to buy one aftermerket.
You could possibly build an air to air intercooled M30 turbo for 3500 if you knew exactly what you were going to need. I spend a lot more because things come up and you tweak as you go along. I could do it again for my m20 for under 3k, but figuring out everything without wasting some $$$ is tough.
M635CSi
Post by M635CSi »
If you want a Dinan M30 turbo system then let me know; there is one available...
turbodan wrote:The big six is harder to do from scratch becuase there was no factory turbo manifold. Unless you want to make something, which is sketchy, you have to buy one aftermerket.
Sometimes you're like the KC Ron of the turbo world . . . m102 and m106 were both factory turbos based on the m30 motor, so there most definitely is a factory manifold that can be used.
It's sub-optimal due to the fact that it uses an old style turbo flange and the turbo that goes with that flange is slow to spool and can't support a ton of power, but it does most definitely exist.
vance
Post by vance »
Jeremy wrote:Sometimes you're like the KC Ron of the turbo world . . .
There's a burn.
Vance
turbodan
Post by turbodan »
Shit. Thats my bad. :brick:
My apologies on the KC Ron comment. Sometimes you're wrong, but you're nothing compared to him.
I mean, we're talking about a man who insisted you could accuaretly tune a turbo without load since he could make boost by blipping the throttle while standing still. :laugh:
turbodan
Post by turbodan »
And it should be noted that the M106 wasn't installed in any US car. Except for the freaks and exceptions, it should not be here. The 524td was legit...
vance
Post by vance »
turbodan wrote:And it should be noted that the M106 wasn't installed in any US car. Except for the freaks and exceptions, it should not be here. The 524td was legit...
Now were graspin.
Vance
turbodan
Post by turbodan »
You know I knew that, I'm just not quite at operating temperature, if you know what I mean. Sitting around at work isn't exactly mentally stimulating...
Yea, but only for one model year. 8)
turbodan
Post by turbodan »
Unless you count the Lincolns and motorhomes too. All four of them...
chrism
Post by chrism »
But what a wonderfully smokey year :D
j9fd3s
Post by j9fd3s »
the kit saves you a ton of R&D too.
