Megasquirt Users
Maddog
Megasquirt Users
Post by Maddog »
For all of you megasquirt users on the forum, what is your AFR at idle? I am trying to get an idea of what kind of good results other people are getting. I am running about 13.5:1 with 12 degrees of advance and my engine is very happy. I am curious to see if anyone has been able to get their engine to idle at 14.7 without the engine "hunting" at idle.
T_C_D
Re: Megasqquirt Users
Post by T_C_D »
Maddog wrote:For all of you megasquirt users on the forum, what is your AFR at idle? I am trying to get an idea of what kind of good results other people are getting. I am running about 13.5:1 with 12 degrees of advance and my engine is very happy. I am curious to see if anyone has been able to get their engine to idle at 14.7 without the engine "hunting" at idle.
We run 14 degrees at idle.
These motors typically do not like 14.7 at idle. I tune idle for smoothness not economy. 900rpm and high 13s do it for me.
FirstFives Dictator
Post by FirstFives Dictator »
That sounds good; it's all about making the motor 'happy'.
My worn-out m30 idles at about 35KPA warm.
Is yours similar?
Maddog
Post by Maddog »
I have been idling around 40kpa. This was a bit higher than I wanted, but I haven't been able to get it lower.
Maddog
Post by Maddog »
FirstFives Dictator wrote:That sounds good; it's all about making the motor 'happy'.
Is yours similar?
What RPM are you idling at and what advance are you running to be able to run at 35kpa?
rs4pro3
Post by rs4pro3 »
my m20 either idles at around 12-13 at a low rpm real ruff idle, or 15-16 at a 1300 rpm idle
FirstFives Dictator
Is yours similar?
14 degrees and 900-950
It's an e12 so I'm used to a little higher idle and no idle control
OldgreenE34
Idle MegaSquirt
Post by OldgreenE34 »
I just got my car to pass Ontario Emissions with:
12 degrees advance
14.8:1 target and 3% authority to the wideband closed loop
47 KPa
1000 RPM
measured mixture - from 14.9 to 15.2
Emissions measured
CO% = 0.00
HC ppm = 10
the car idles like a stock E34 535 in terms of solid and smooth.
Dave
OldgreenE34, are you using MS now or are you still using the Perfect Power SMT?
OldgreenE34
MS on the TCD 1988 M6
SMT-6 on the TCD 1990 535
Dave
