MS guys - Which TPS for m20 TB?
Pat
Post by Pat »
This isnt for my e28, but im MSing my e21 and i have an m20 throttle body for it. Which is the easiest TPS to use, e34 525i m20? E36 m50?
turbodan
Post by turbodan »
The e36 M50 works with a simple adaptor plate, and plugs right into the stock harness. Thats what I chose.
altus22
Post by altus22 »
A Kia or Hyundai TPS is also the pot type that you need. Again, simple adapter plate to make it work.
Pat
Post by Pat »
OK, so you gotta use an adaptor either way. And my car doesnt have a harness, its CIS right now so ill just make the wiring anyway. Thanks
turbodan
Post by turbodan »
I see. I should have said it plugs right into the Motronic harness.
///ARINUTS...
Post by ///ARINUTS... »
e32 and e34 automatic m30 cars have the perfect TPS, bolts right onto the throttle body
Pat
Post by Pat »
Bolts right up to an M20 throttle body? Perfect thats exactly what i was lookin for. I could use an adaptor but id really like a nice clean installation.
bmw4aaron
Post by bmw4aaron »
Pat wrote:Bolts right up to an M20 throttle body? Perfect thats exactly what i was lookin for. I could use an adaptor but id really like a nice clean installation.
Are you putting MS on a 323i? I just finished doing this. Used an m50 tps, with adapter plate, once tb is installed you cant even see the tps.
Pat
Post by Pat »
No, the MS is goin on a 320i with an M10, but i am using an M20 throttle body
