My V8 powered M535i
My V8 powered M535i
well i'm new here, but my project is already a couple months on the way.
I'm restaurating a E28 M535i from 1986. The restauration it self is gonna be pretty normal, just get write of all the rust and give it a nice fresh coat of paint (ferrari grigio Silverstone) i will keep the outlooks original us much as possible.
The car will be running on 18inch original Alpina's rims which i bought a couple of months ago.
The only thing that's gonna be really special is the powerplant! I'm one of the guys who wants to do something really special with his e28.. Soo i'm gonna put in a V8 into the E28.
First i was planning to restaurate the car all the way and than put in the engine, but because between cristmas and newyear i had a holiday i planned to do the engine swap rightnow and go on with restaurating later on in the project.
Well let's put some pictures of my car down here.
I bought the car without an engine.
This i the british 740IL E32 which i bought on ebay. This car is my donor for the engine..and yes i know.. it's in the best shape you can imagine. soo it was a really though disision to tear down the car..but everything is allowed in love and war right?
This is where it's al about!
My 18 inch alpina rims!
I will post some more reply's behind each other soo you have a bit of a time schedule
greetings,
Meindert Bunt
greetings,
Meindert Bunt
Hello guys, My plan was to get the engine out of the 740 this cristmas, soo i started today with dismanteling the car.. I must say the're damn good build cars and its a lot of work to get the engine out of there! I'm at the stage to get the engine out of there but because we ran out of time i'm planing on doing that this weekend. (Don't want to rush it to much!)
This morning i started with dismounting the exhaust untill the cats, ofcourse i couldn't keep my self in to not start the car and it sounds super sweet!!:rule:rule
Well here are some pictures of the work:
Le Pic Electric!
groeten,
Meindert Bunt
Le Pic Electric!
groeten,
Meindert Bunt
Hello,
Lots of things happened in the mean time over here.
I've been really busy to squezze the huge V8 into my M535 and today we made the engine mounts. tomorrow i'm gonna fabricate the gearbox mountingplate soo it will hang 100% on his own.
The first thing i must say is that this will gonna be a verry though built.. because the engine is really big for suchs a narrow car... and there will be a lot of stuff i need to rethink about.. But for every problem there's a solution!
My brother made a fake engine. it's just some plates and a beam with has the same with as the engine brackets.
Here are some pictures of the build.
pretty big block for suchs a small car.....
nice and tight over here!
pretty big transmission!
the "fake"engine
just need to grained down the brackets for the better looks and than its good!
TADA!!! he's in there!
greetings,
Meindert Bunt
the "fake"engine
greetings,
Meindert Bunt
yes i sure hope it's gonna be prettyyy
because it takes some time to get at that stage..
About the brake linkage, i've found a guy who want to swap his 540 brake linkage and main cilinder for my english style exhaustheaders (i'll get his europe style headers too) because i can't do anything with the english ones because my steeringbox is in the way and my startermotor is on left side instead on the right (i need to cut out a the startermotor spacing on the right)
greets
greets
Are there a lot of differences with the euro edition and the US edition? i never seen a US one.(i think.. or otherwise i don't see the difference)
I'm gonna keep the exterieur as stock as possible(i like how it looks rightnow) expect on the rims and exhaust tips.. But meaby my taste changes before its done.
If course i will upload some video's when the engine is running because for me thats a milestone!
keep you guys updated but on the moment i'm not gonna do a lot on the car because its -12 rightnow(super cold for the netherlands) and its pretty cold in our garage.
greetings,
Meindert
greetings,
Meindert
The M535s were not supposed to be sold in the us as far as I know. There were gray market importers who were bringing them in and getting them Department of Transportation approved. My friend knew one such importer and they brough in two. A black and a white. He put up both for sale and kept the one left. THe black one sold first.
Hi there! Are you based in the Netherlands?
I'm just interested to know how bad this rust is in this pic?
I'm buying a similar car and the outer wing is rusted in the same place, I'm worried the rust could have affected the inner wing/ structure of the car like in the photo!
Is it just surface rust or is it quite bad?
Thanks. And amazing project! that is a HUGE engine to shoehorn into a small car, and it looks fantastic, shame the 740 got ripped up, but theres plenty of them, and that engine is ok in the 7, not amazing, but that engine in an e28 WILL be amazing!
Owning both an e28 and e32, while I appreciate the skill that it takes to do what you are doing it occurs to me that it really doesn't make sense to tear up a perfectly good e32 740i / iL to bastardize an M535i. Moreover, assuming tearing up a perfectly good BMW wasn't a sufficient disincentive, there wasn't a powertrain available from a wreck instead of what appeared to be a perfectly serviceable e32 740 -- wouldn't that have been cheaper? And the end result of killing the 740 is that the M535i is now going to be a heavy pig. For example, with respect to the 5hp30 transmission, did know that it was bigger than what was needed in the e32 and subsequent e38 -- BMW decided that the e38 would use the 5hp24 after US MY '95. Why not use the 6 speed manual if going through all this trouble? So while this is an interesting project, and I admire the skill and creativity needed to accomplish it, at the end of the day, I think you are probably ruining an e32 and bastardizing an M535i. And if you are going to do this, why not find a rust free car on which to do it?
Oh, and the M60 is more than OK in the e32. It's actually perfect.
Goes to prove anything can be done. Question is whether it is worth it.
Oh Jesus, Is every 740i sacred?rlomba8204 wrote:Owning both an e28 and e32, while I appreciate the skill that it takes to do what you are doing it occurs to me that it really doesn't make sense to tear up a perfectly good e32 740i / iL to bastardize an M535i. Moreover, assuming tearing up a perfectly good BMW wasn't a sufficient disincentive, there wasn't a powertrain available from a wreck instead of what appeared to be a perfectly serviceable e32 740 -- wouldn't that have been cheaper? And the end result of killing the 740 is that the M535i is now going to be a heavy pig. For example, with respect to the 5hp30 transmission, did know that it was bigger than what was needed in the e32 and subsequent e38 -- BMW decided that the e38 would use the 5hp24 after US MY '95. Why not use the 6 speed manual if going through all this trouble? So while this is an interesting project, and I admire the skill and creativity needed to accomplish it, at the end of the day, I think you are probably ruining an e32 and bastardizing an M535i. And if you are going to do this, why not find a rust free car on which to do it?
This is mye28 not mye32!
good luck with the project.
looks like your well on your way.
a 6 speed manual box would work very well,in the performance and weight stakes,but i have looked for a very long time and nothing's turning up.
either way 300nm of torque is going to move the light weight e28 body very well.
have you considered fitting a rack and pinion setup out of a e39?saves weight and space that the steering box takes up.
Anyway cheers and
groetijs martyn
Anyway cheers and
groetijs martyn
I understand, but you don't think that it would have made more sense, from the enthusiast's perspective and a financial perspective, to not tear apart a perfectly good car to accomplish these ends? My reaction would have been similar had he cut up pretty much any perfectly good BMW to accomplish this project. It's one thing if you've got access to a good M60 and a six speed transmission, and a nice BMW shell. But to cut up a perfectly good car of a newer vintage that appeared to be in better condition to put the drivetrain into what appears to be a rusty M535i? Add in the fact that the drivetrain is an automatic, which because of its size and weight is not at all suited to an e28 chassis and you get further blank stares from me.photopark wrote:
As I said, forgive me for being less than enthusiastic about the concept although, as I said, I admire the skill and expertise that it takes to accomplish such a project.
Yes but a 740i is like a Crown Victoria in Holland.rlomba8204 wrote:I understand, but you don't think that it would have made more sense, from the enthusiast's perspective and a financial perspective, to not tear apart a perfectly good car to accomplish these ends? My reaction would have been similar had he cut up pretty much any perfectly good BMW to accomplish this project. It's one thing if you've got access to a good M60 and a six speed transmission, and a nice BMW shell. But to cut up a perfectly good car of a newer vintage that appeared to be in better condition to put the drivetrain into what appears to be a rusty M535i? Add in the fact that the drivetrain is an automatic, which because of its size and weight is not at all suited to an e28 chassis and you get further blank stares from me.photopark wrote:
