I'm assuming this means perpendicular to the earth and not in a straight line with the O/T mark on damper and front case.Camshaft and crankshaft TDC position.
Camshaft sprocket mounting bolts should be straight up and down with the locating pin in the lower left-hand corner (A).
O/T mark on vibration damper should align with mark on front case (B).
Accuracy? With a level or is eyeballing it good enough? (Eyeballing is of course before the beers.)
Just wanting to be 100% sure.
Thanks...
