optimal valve adjustment for M30B34....
I'm a fan of using Shawn's method of checking valve clearance at the cam and not the valve stem. I did this on my last valve adjustment and I felt I got better running and a smoother idle. Much easier, too. IIRC the gap at the cam should be 0.090.
Rich
[Edit by Rich in WI on [TIME]1110209224[/TIME]]
Rich
Thanks for the good words, Rich! For reference, here's the thread from the Roachfly archives:Rich in WI wrote:I'm a fan of using Shawn's method of checking valve clearance at the cam and not the valve stem. I did this on my last valve adjustment and I felt I got better running and a smoother idle. Much easier, too. IIRC the gap at the cam should be 0.090.
"Quiet valves at last! All I had to do was"
[QUOTE="Rich in WI"]I'm a fan of using Shawn's method of checking valve clearance at the cam and not the valve stem. I did this on my last valve adjustment and I felt I got better running and a smoother idle. Much easier, too. IIRC the gap at the cam should be 0.090.[/QUOTE]
[QUOTE="Shawn D."]Thanks for the good words, Rich! For reference, here's the thread from the Roachfly archives:
"Quiet valves at last! All I had to do was" [/QUOTE]
Damn! Why didn't I think of that?!
I use .010 to .011 as the range (at the stem, so I guess I'll go .090 or maybe .085 at the cam?). I check the adjustment 2-3 times a year, so I don't worry about them being a little tight.
[Edit by Velocewest on [TIME]1110222516[/TIME]]
0.010 on a M30B34? I *thought* 0.012 was appropriate for the big 6 - that's what I set mine to this weekend (using Shawn's method of course)
louielouie
If your going straight by the book then yes. However, as you can see, many of us use tighter setting. Some engines like the valves a little tighter, some don't.
Rich
