I just purchased a 87' 535is with 208K on the clock. The guy I bought it off said the car will need a starter.
The starter spins when the vehicle is cold or has been sitting for a while. It seems to fire up when warm or used awhile.
Do I still need a starter or is there something that can be fixed with the current starter?
Thanks
Starter spins some of the time.
You could have it overhauled and that would be cheaper than a new one.
If you do decide to replace it I would highly reccomend a later model reduction gear starter. MUCH easier to install.
Mine came off of a 318is, fit great and works great. I did have to change the trigger wire terminal from a female spade to a ring terminal.
[Edit by Dave_in_VA on [TIME]1110148929[/TIME]]
