MT2500?
the red brick will not scan our cars. actually nothing will scan our cars unless you have a late 87-88 production 528 with the motronic 1.1. The motronic in the e28 535 does'nt store codes or give its information out. the only way to diagnose a problem with our cars is good old fashioned testing with a d.m.m. and a trouble tree if you can find one.
hope this helps.
hope this helps.
You can adapt the later Motronic used in the E32/34 and late E24 6er to the E28. You need the ECU, appropriate sensors, and the engine harness from a late production E24 635csi.
Shouldn't cost you much more than retrofitting a Megasquirt. You just won't have the same tuning capabilities. You're still stuck with a chip.
Rich
Rich
