88 528e valve adjustment
briand
Post by briand »
Can someone tell me how to adjust the valves and to what spec. They are getting very loud.
Techboy
Post by Techboy »
Start on #1 cylinder with the rockers on the "heel" of the cam (both cam lobes pointing down, lowest spot on the cam), rotate engine to the next cylinder in the sequence where the cam lobes point down and the rockers are on the low spot and keep going to the next cylinder in the sequence of the firing order until you are done. Valve clearance spec. (intake and exhaust) is .011" DEAD COLD.
tacm
Post by tacm »
sorry.....not being a dic.....but ita a German car .011" aint right what is the real spec????? :p
Gee whiz, don't they teach math in school anymore? :D
1 inch = 25.4 mm.
.011" = .279 mm.
Use your metric feeler gauge that's closest to that number.
tacm
Post by tacm »
dude when i said not being a dic........I WAS BEING A DICK.......but in a nice way.....steve :D
Post by C.R. Krieger »
[QUOTE="tacm"]dude when i said not being a dic........I WAS BEING A DICK.......but in a nice way.....steve :D [/QUOTE]
You're gonna have to take it easy ... we're losing track. :~
Techboy
Post by Techboy »
[QUOTE="tacm"]sorry.....not being a dic.....but ita a German car .011" aint right what is the real spec????? :p [/QUOTE]
The real spec is .011" dead cold (and that came from a BMW employee, specificly a senior technical instructor) what is the real question?
dasMafia
Post by dasMafia »
as long as the vast majority of north amereican residents possess offset feeler gauges in standard measurements... the spec is .011"
I'm tempted to crank mine down to that on my B34... but have too many other things to do first.
Techboy
Post by Techboy »
[QUOTE="dasMafia"]as long as the vast majority of north amereican residents possess offset feeler gauges in standard measurements... the spec is .011"
I'm tempted to crank mine down to that on my B34... but have too many other things to do first.[/QUOTE]
B34 valve clearance should be .013" dead cold.
dworthy
Post by dworthy »
Should be....
Could be...
Would be...
To his each his own. It is always best to start with factory spec then as time goes by you can adjust that to match what you want. I do mine a .010" cold, of course go with factory setting or the bently numbers.
briand
Post by briand »
So I put the feeler gauge between the rocker and the cam or the rocker and the valve?
dworthy
Post by dworthy »
Go with the valve side, later when you get real good go for the cam side.
Techboy
Post by Techboy »
[QUOTE="dworthy"]Should be....
Could be...
Would be...
To his each his own. [/QUOTE]
I would agree with that UNLESS someone is trying to learn something. There are some VERY knowledgeable people on this board who have been around these cars a very long time!! In that case, there might just be a better way than the one we are used to! All it takes is an open mind and a willingness to learn...
dworthy
Post by dworthy »
I don't mind being quoted, but please read my post completely.
I said to go with the factory setting FIRST and then as time goes by, you can adjust them as you see fit. Each motor has it own personality, so the factory setting won't just do, that is where you adjust the valves to the smoothes and quitest that you can find.
