Gift Or Curse???
Gift Or Curse???
Hey Guys, new guy here on the forum! I have somewhat been given a 1985 535i that has either been converted to an M 535i or a M5 (not sure which) The car ran great except for an electrical gremlin in 2003-04 and has been garage kept and not touched since it rolled in and parked. So now it is in my garage and I am going through things trying to get it ready to bring back to life!
I have been working on cars, trucks, bikes (anything with an engine and wheels) for about 11 or so years so I know my way around a wrench. However I am not familiar at all with any European much less German automobiles but nuts are nuts and bolts are bolts so I am confident I can figure it out!
I am about to go through and replace all the fluids. All the lines and rubber feels good and not brittle. The car itself is in awesome awesome shape inside and out. It has a serialized Fittipaldi steering wheel, 3 piece BBS wheels, some sort of lowering springs and various other odds and ends. The car is originally from New York and was bought as a 535 then converted to either an M 535 or M5 (I haven't read the differences and or how to tell).
Anyway I wanted to introduce myself and See if there was anyone in or near Houston that might want to stop by or anyone who has any advice and or things to look for that I might miss. Seems as my first post is a novel I will add pictures on my second post I hope to hear from yall and maybe meet a few!
Thanks
Thanks
- Beamter
My best guess says its been converted to an m535i since there are no m5 badges just an m535i badge on the rear decklid. I have been wrong before...once! I know the pictures are terrible but its all I have for the moment I will take better pictures tomorrow in the daylight for yalls viewing pleasure.
- Beamter
Well we started draining the fluids today got the oil, coolant, and about 5 gallons of gas drained Will have more progress later on...
Totally forgot I had started this thread. I will have to re-add the pictures as I have organized my photobucket account. I am back to working on this damn car as I will call it till I can drive it!
I am working on getting fuel and spark. Picking up a multimeter so that I can start to diagnose things like making sure 12v are getting to the coil. Any one want to come and help? I have beer and burgers!
Have spent the last couple of hours at Michael's trying to diagnose no spark issue.
We replaced with known working parts, the following:
Reference and Speed Sensors
ECU
AFM
Main Relay
Fuel Pump Relay
Ignition Coil
Jumpered the OBC relay several different ways.
Ignition switch is bad, so we're going straight from the battery to the solenoid, with the key in the run position, to attempt starts.
Still no spark, HELP!!!
ECU
AFM
Main Relay
Fuel Pump Relay
Ignition Coil
- Beamter
- Beamter
Mail relay terminal 30 to both terminal 87s. That should also put power to the fuel pump relay (though the fuel pump won't power up until the ECU provides ground to the FP relay.)
If still no spark, check for power at the coil. If there is power, check that the ECU is pulsing the ground to the coil (a test light across the coil + and - terminals will flash if the ECU is telling it to spark.)
