M30B35 Swap FAQ
- Beamter
I am doing a Motronic 1.3 swap on a 3.0CS for someone and he has picked up an E34 535iA harness. I have done that swap before (it has been about 8 years, though,) but I had a manual harness and a B35. He is running a bored B30. Do you think it will be fine to use the auto harness (I'll probably strip it of unnecessary wires/connectors) or would it be easier to get a manual TPS and harness or a super eta harness? Does anyone know if the wiring box fits under the old log type manifold (I believe that it does, but it has been so long I don't remember.) Think there will be any issues with the B30? What happens if you run 1.3 in open loop? I suggested that if the ECU overfuels the car due to the smaller displacement that we could run a smaller (or adjustable) FPR or smaller injectors to compensate. Alternatively, we can go for a Miller MAF and WAR conversion if we are dissatisfied with the stock tune, but he doesn't want to deal with tuning it himself.
Suggestions?
Suggestions?
- Beamter
OK, I'll make sure that he knows that he must run an O2 sensor. Should not be a problem for him since an AFR gauge would be handy (he plans to make a drop in custom gauge panel and hold on to the old cluster.)
I know that it is not EML (I have the harness in my trunk.) If there is time in between work I'll see if we can snap pics of the conversion this Spring.
M30B34 to M30B35 swap in an 87 E24
Hi new to the forum, but have found it to be an excellent resource even though have a 635, I am looking for some knowledge and insight. I have an 87 E24 stick that I am swapping an M30B35 into. The donor motor is out of a 92 E34 stick. I am just looking for any insight ,foresight, tricks, problems etc so I can be as ready as possible when I finally get into the Project. Thanks in advance for any help.
Most of the info can be found in this thread for the most part, and will take some amount of good common sense and cross referencing. The best thing you can do is triple check everything you have before you start the swap so you dont have any hiccups or missing parts.
You can use your existing driveline because its already an m30, a E28 M5 flywheel/533i flywheel is a good upgrade to do while the motor is out, everything else can stay the same in that area.
Forgot to mention that the engine has Ireland 10:1 pistons and a 284 Deg cam. Is this going to need a little more fuel delivery i.e. larger bore throttle body, 24lb injectors, MAF, etc? Also will motronic 1 be fine with this or is 1.3 or even some kind of aftermarket engine management going to make better or perhaps mandatory?
Those upgrades aren't necessary to run your motor. If you are going through the trouble swapping in a B35 it would be a waste not to use the newer 1.3 motronic. I suggest sticking with the motronic 1.3 and after you have the motor installed and running properly then you can start to think about stand alone engine management systems.Heathcliffe wrote:Forgot to mention that the engine has Ireland 10:1 pistons and a 284 Deg cam. Is this going to need a little more fuel delivery i.e. larger bore throttle body, 24lb injectors, MAF, etc? Also will motronic 1 be fine with this or is 1.3 or even some kind of aftermarket engine management going to make better or perhaps mandatory?
This list should clear up just about every question of which parts you need, after using realoem and autohausaz for picture references, there should be no more excuses not to know which parts you need.
Air box-you can use the factory elbow going from the air flow meter, and the factory air box with valve cover support from the e28 535i if you do not wish to use the longer m30b35 air box (part number13711707727) and elbow (part number 13711707767) from the air flow meter to air box.
You can still use the boot that goes from the air box to the headlamp ducting (part number 12311710514) but you must cut it, and make a bracket for the air box to mount to the inner fender.
Air flow meter elbow-from m30b35 (part number 13711707767)
Air flow meter-same as the m30b34 air flow meter (part number 0280203027)
Air flow meter rubber isolators-m30b35 only (part number (13621707790) and clips.
Intake boot-m30b35 intake boot, non EML (part number 13541722847)
Valve cover breather hose-same as the m30b34 (part number 11151276485) with nipple on the side
Valve cover breather hose to intake bellows plastic elbow-same as m30b34 (part number13541272473)
Idle control valve-same as m30b34 (part number 0280140509)
Idle control valve vacuum tube-same as m30b34 (part number 13411710793). Use only the BMW brand hose, and not the contitech brand aftermarket hose since it is not reinforced.
Throttle body-the m30b35 throttle body (part number 13541726609) is the same as the m30b34 throttle body, the only difference is that there is
no nipple on the bottom of the throttle body. You cannot use the fly-by-wire throttle body from cars with EML.
Throttle position switch-if using an automatic m30b35 harness, use 6 pin variable TPS (part number 0280120406) from E34/E32, if using a manual harness, use m30b34 manual TPS or manual E34 TPS (part number 0280120302).
Intake manifold-from any m30b35 (part number11611717405), there are a few differences however, one being the big vacuum port for a brake booster vacuum hose, you will need to cap that off if the car you are putting it into was a 535i, and leave it alone for a 528e that runs with a vacuum booster. Also there were manifolds with one less vacuum nipple on the bottom, one goes to the valve cover breather tube, cabin temp sensor, fuel pressure regulator, the medium sized one is the purge valve, and big one is idle control valve.
Valve cover-the m30 valve covers are interchangeable but the b35 one (part number11121710974) is cleaned up quite a bit and has a designated bracket for the air flow meter.
Cylinder head-use any m30b35 cylinder head (part number 11121707150), but use the water neck at the back of the head (part number 11121253208) from the m30b34 instead of the block off cap.
Block-any m30b35 bottom end (part number 11111720650), preferrably one from a E24 with the b35, since they have the dual mounting bosses, or the earlier E32/E34 with the dual mounting bosses. Its not that big of a deal because Koala makes the mounts you need, and affordable too.
http://www.koalamotorsport.com/proddetail.asp?prod=m30l
http://www.koalamotorsport.com/proddetail.asp?prod=m30r
Oil pan-from b35 (part number 11131708345), since both b34 (part number 11131278878) and b35 pans fit, no reason to change them, unless you want to use the b34 alternator and power steering pump with mounting bracket. If you do want to change the pan to the m30b34 pan, then you will need the b34 oil pump pickup (part number 11411286468) instead of the m30b35's pump (part number 11411317100)
Motor mount arms-all from m30b34 (part number 11811175990 and 11811175591).
Motor mounts-m30b34 only (part number 11811175735)
Fuel injectors-same bosch19 lb/hr as m30b34 (part number 13641726988) or m30b35 lucas (part number 13641730292)
Fuel rail-m30b35 only (part number 13531719916). The FPR side uses a molded hose (part number 13311748689) which you must use or you have a kinked hose, you can just use a longer BMW line instead if you choose.
Fuel pressure regulator-same as m30b34, 3.0 bar FPR (part number 13531722040)
Purge valve-m30b35 only valve (part number 13901726705) that goes between the charcoal canister and intake manifold vacuum lines for emissions, which is held on by a rubber mount (part number 13901717292) and bracket (part number 13901717023).
Exhaust-you can use the stock e28 b35 exhaust, but the better choice is the b35 manifolds (part number 11621289275) and downpipes (part number 18301437358) which will need to be cut and welded at a different angle to clear the frame and sway bar. You can slip the b35 exhaust over the b34 exhaust once you get it under the car and bolted up.
Starter-the small case m30b35starter (part number 12411720664)is about half the weight of the large case m30b34 starter (part number 12411272150) and has the proper terminal connector for the 1.3 harness. The b34 starter will work, but the b35 starter is much easier to take out since you have a straight shot to the bolts.
Flywheel-use a single mass 19 lb 535i flywheel (part number 11221289244), or the 14 lb 533i/M5 flywheel (part number 11221271463)
Clutch-use e28 535i from sachs (part number 1861931033)
Pressure plate-use e28 535i from sachs (part number 3082147032)
Throwout bearing-use e28 535i from sachs (part number 3151231031)
Ignition wires-from m30b35 (part number 12121722253)
Ignition coil-you can use the m30b34/early m30b35 coil (part number 12131286087), but the m30b35 coil (part number 12131742925) is better
Distributor rotor-same as m30b34 (part number 12111734110)
Distributor cap-same as m30b34 (part number 12111725070)
Distributor dust shield-same as m30b34 (part number 12111288167)
Oxygen sensor-m30b35 oxygen sensor (part number 11781720537) if using the m30b35 wiring harness, super eta oxygen sensor (part number
11781714772) with an extension if using a super eta wiring harness.
Wiring harness-you can use a super eta harness (part number 12511714294) and just extend the 4 AFM wires, 3 TPS wires, 3 ICV wires, and oil pressure switch wire. The other option is to use a m30b35 1.3 harness (part number 12511724670) and use an adapter If you use the super eta harness, you must use the m30b34 oil level sender (part number 12611276183) since the m30b35's sender (part number 11131708345) uses a different connector.
ECU-179 dme from E32 and E34 (part number 12141748258)
Cooling hoses-use every hose from the e28 535i:
coolant hose: water pump to thermostat housing (part number 11531266459)
coolant hose: thermostat housing to water tee (part number 11531274210)
upper radiator hose (part number 11531276647)
lower radiator hose (part number 11531289859)
expansion tank hose to tee (part number 11531278529)
coolant hose: expansion tank breather (part number 17121119294)
coolant hose: breather hoe from expansion tank to breather pipe (part number 17121712136)
heater hose: inlet from cylinder head/heater core to heater valve (part number 64211363470)
heater hose: inlet from cylinder head to heater valve (part number 64211368714)
heater hose: outlet from heater core to thermostat housing/water tee (part number 64211368715
Water tee: distribution tee for cooling system, same as m30b34 (part number 11531272866)
Water pump: same as m30b34 (part number 11519070761)
Water pump pulley: m30b34 and later m30b35 share the same pulley (part number 11511706781) the early pulley (part number 11511271423) on the b35 is 14mm bigger
Thermostat housing-same as m30b34 (part number 11531268650 and 11531710959)
Thermostat-80C thermostat, same as m30b34 (part number 11531713040)
Fan clutch-use m30b34 only (part number 11521740962)
Clutch driven fan-use m30b34 only (part number 11521271846)
Engine temperature sensor to ECU-same as m30b34 (part number 13621709966)
Temperature sender to cluster-use 88 528e(part number 12621710512 )
Harmonic balancer-m30b35 only (part number 11231722723)
Crank trigger bracket-m30b35 only (part number 11141717127)
Crank trigger sensor-from m30b35 (part number 12141720853)
Crankshaft pulley-see accessories below
AC, power steering, and alternator-You can use your m30b34 power steering pump (part number 32411133969), 90A alternator (part number 12311466087), and AC compressor if you use the m30b34 mounting brackets (part number 12311708343 and 64521284953), adjusters, crankshaft pulley (part number 11211258274), and power steering belt (part number ), alternator belt (part number 11221706788), and AC belt (part number 64521711056).
You can use the m30b35 power steering pump (part number 32411141058), 140A alternator (part number 12311735706), AC compressor, mounting brackets (part number 12311707194 and 64521284953), adjusters, crankshaft pulley (part number 11231716270), and power steering belt (part number 11231709636), alternator belt (part number 11231706668), AC belt (part number 64521722371) from the m30b35, but you will have to do something to the lines for the AC, everything else will work and bolt up however.
m30b34 to m30b35 swap
Ummmm... wow... extremely detailed, helpful and a bit overwhelming. Thanks for all the info.
Some pics.
M30B32
Early M30B35. Head is stamped '87
M30B35. Head is stamped '89
As you can see the early b35 looks almost identical to the m30b32/m30b34. Aside from the obvious differences, it has virtually the same block casting design. It uses the same oil pan along with the alternator/power steering mount as the b32/b34. Notice the block of the later b35, it's a different casting design with a different oil pan. I thought this was interesting.
M30B32
Hey Don!...hope all is well.sfdon wrote:The question I have is will a m30 b34 HEAD fit on a m30 b35 bottom end? What will the c/r be? Anyone done this"?
Scroll down on this link for m30 compression ratios (excel calculator):
http://www.mye28.com/viewtopic.php?t=50038
-Kevin
They're not;LA wrote:Thanks bimmerguy for the excellent post. I just keep learning differences - I did not know the AFMs were different.
Is the internal dia different? What other things are different?
Bimmerguy2002 wrote:Air flow meter-same as the m30b34 air flow meter (part number 0280203027)
Thanks! Sorry I missed that in Matt's post.CSBolger wrote:They're not;LA wrote:Thanks bimmerguy for the excellent post. I just keep learning differences - I did not know the AFMs were different.
Glad to know I don't have to rundown a new AFM.
this is gonna be a great swap.
I just picked up my M30B35 out of an E32 last week. Going to start stripping it down soon and sending parts off to get hotanked/beatblasted/powdercoated etc. for $250 including the AC and alternator I can't go wrong
The biggest thing I wanted to know what was 1.3 harness to use, as mine was a bit dryrotted and beat up (not to mention my friend cut it when they yanked it out of the donor car he had, they used it for body panels to resurrect his own E32), so im most likely going to purchase it brand new from the dealer (always helps to have a sick discount there too)
im going to run that part number tomorrow and see what price it comes up with..
Re: M30B35 Swap FAQ
So, I have a b34 in my e30 with B34 specific swap mounts..If I get that adapter I can re-use them with the b35??
Sounds so...simple! Im so doing it!
Re: M30B35 Swap FAQ
anyone can give me the dimension for the engine moust adapter?I am not in US,so I have to make one by myself.
thanks for your help
Hello! I bought an m30b35 engine with "all" electrics and 4hp22 automatic. Engine is from E32 it`s the newest 1.3 motronic and the car where i am mounting it is 518i.
We made the motor brackets last night, and now we are making the gearbox bracket.
Problem is joining m10 fusebox and other electrics with the e32 harness together. i am wondering if the roundconnector to engine is same in all m30b35 engines so i can wacth the pin places from pic what is ment for e34 change to e30 318i..
Or is here anybody who has done same job what i am doing.
Regards . Suni
Sorry my bad english
Regards . Suni
