E28 Shifter FAQ
E28 Shifter FAQ
This FAQ has moved to the WIki: Shifters - The E28 Wiki
I've found with my sheet metal consoles that if you use one of the rubber bushings that hold the airbox (part number 13711259818) instead of part number 15 (stop buffer) it is much easier to install and far less likely to fail than that silly little rubber piece. I've also used transmission mounts if I've had one lying around. They work well.Big Bronze Rim wrote:I have added clarification to the sheet metal console info as well as added some of the information from Ron Stygar's excellent research on shift levers.
Question:
on the aluminum console why are the yellow washers and circlips at either end of the select rod different sizes and part numbers (as shown by real oem) ? the color photo shown above calls them generically 'yellow washers, circlips' are they interchangeable or not?
I can't find part numbers for the pieces 14, and 16 at autohausaz.... irritating.
Thanks fellas
ALSO:
I have part (25 11 7 501 309) 13/9, guy that attaches to the trans select shaft for sale.
I have about 10 of them, If you need one let me know. Cheap.
What's fair-- $9?
Thanks fellas
ALSO:
What's fair-- $9?
e28 shifter FAQ
I have an e28 M5 with the 265 conversion. Which means it has the sheet metal console. I'm using the stock M5 shifter which is fairly tight but has a long throw especially to 2nd. Anyone know the ratio of that shifter so I can compare it to the others above?? Alternatively has anyone used any the shifters above with that console and if so which one and what were the results?? Thanks John
Any of the above shifters CAN be run with the sheet metal console. It requires a small modification of the upper shifter bushing but it is very easy. I've got a G265 w/sheetmetal console in my car and am using a Z4 3.0 shift lever and it works great. I think I have a stock shifter laying around that I can measure.
e28 shifter faq
Thanks. Based on the pictures above which/where is the "upper" shifter bushing??
e28 shifter faq
Thanks I see it perfectly now. Sorry about the late reply my daughter is getting married next Friday and my house is nuts.
John
John
I actually got the C clip out from between the upper and lower shifter pieces, pulled them apart and installed the upper bushing/cup without cutting. I'm cutting it the next time....An HO railroading saw is great for cutting that bushing. It's razor thin and incredibly sharp.
And yes the yellow O rings/bushings are all the same size. I have plenty of spares.
I know that then e39 m5 shifter is exactly the same as the ie short shifter and that the e39 530i is a different ratio to that, for the worse.CSBolger wrote:I wish my bored posts were full of awesome information!Big Bronze Rim wrote:I shouldn't have hastily posted it from work but I was bored.
Does anyone have the lengths of the E39 shifters? I have one out of a 530i, and I'm guessing it's around the same as the 1.9 Z3's.
Yup. According to Brad's post the ratios are identical. One thing I do like about it is that it's just a bit shorter than stock - hardly noticeable until you drive a stock E28. I'll be going with something else soon though.derrith wrote:I know that then e39 m5 shifter is exactly the same as the ie short shifter and that the e39 530i is a different ratio to that, for the worse.CSBolger wrote:I wish my bored posts were full of awesome information!Big Bronze Rim wrote:I shouldn't have hastily posted it from work but I was bored.
x 2. Maybe add some info on the how-to of gaining access to the parts for rebuild/replacement. Could always start with some of the helpful hints I received to my dumb questions about the process of rebuilding the shift linkage.Paul in N FL wrote:Sticky?
http://www.mye28.com/viewtopic.php?t=59341
http://www.mye28.com/viewtopic.php?t=62489
http://www.mye28.com/viewtopic.php?t=69656
In short, it helps to get the driveshaft out of the way, but to do so you've got to loosen the center bearing, but to do so you've got to at least loosen the exhaust & catalytic converter.
You should be able to figure out all the part numbers you need from what is described above, and order them from autohausaz.com, pelicanparts.com or bavauto.com (or even your local dealer if you want to pay dealer prices).BigMac wrote:Is there a place to purchase all the items needed for the Z3 shifter upgrade?
Friend of mine mentioned that when he did it he called up Steve Haygood and he knew everything needed, but apparently he's no longer in business.
Thanks.WVe28 wrote:You should be able to figure out all the part numbers you need from what is described above, and order them from autohausaz.com, pelicanparts.com or bavauto.com (or even your local dealer if you want to pay dealer prices).BigMac wrote:Is there a place to purchase all the items needed for the Z3 shifter upgrade?
I actually feel like an idiot right about now. When I originally looked at the diagram I didn't even realize that it specifically told me which parts I should replace.
There's a lot of good info in that thread. Also, do a search on something like shifter rebuild and you'll find a lot of great answers to dumb (and otherwise) questions that I and others have asked about the rebuild process.BigMac wrote:Thanks.WVe28 wrote:You should be able to figure out all the part numbers you need from what is described above, and order them from autohausaz.com, pelicanparts.com or bavauto.com (or even your local dealer if you want to pay dealer prices).BigMac wrote:Is there a place to purchase all the items needed for the Z3 shifter upgrade?
I have a thread that I refer back to when I have a question about mine and it has been alot of help.
Thought this might be a good contribution.
http://www.mye28.com/viewtopic.php?t=68339&highlight=
