Hey Now............
paul burke
Hey Now............
Post by paul burke »
Beamters, how come when I search my own name nothing comes up anymore ? Searched others and their still active so its not a malfunction on my part, What Gives?
Paul
It all seems to work for me. What sort of error are you getting?
paul burke
Hi Jeremy, if I search "key words" I get "no terms meet this description" or something along those lines. If I pull up "author" it works but not the same amount/topics as before.
Paul
If you're looking for your own posts/threads, your best bet is to use the links on the main screen in the upper right hand corner.
paul burke
No, I'm more interested in other peoples posts where my name is mentioned. I have searched "paul burke" many times using the "key words" box and never had this problem before.
I get this phrase only when I search my name , others still work fine.
" No topics or post met your search criteria"
Paul
phpBB search is sometimes less than reliable. Try the "Google Search" at the top of the search screen search for your name with quotes:
"Paul Burke"
This should give you what you're looking for.
Justin_FL
MyE28 IT Guru
MyE28 IT Guru
Post by Justin_FL »
Try again in the morning. The search index is being rebuilt overnight following some optimizations.
