Euro OEM M5 springs
GaAlpinaOwner
Euro OEM M5 springs
Post by GaAlpinaOwner »
Has anyone used these Euro Springs with Bilstein Sports?
Europe E28 M5 Sedan
31 33 2 225 115 (Front Coil Spring-Points up to 18)
33 53 1 125 315 (Rear Up to 2/86 Production)
33 53 1 130 723 (Rear From 2/86 Production)
:dunno:
Standing by awaiting discussion.
GaAlpinaOwner
research has determined these are only decent with Boge struts and shocks that were oem....
Mtech Red are much better although they are somewhat undersprung
cgraff
Post by cgraff »
GaAlpinaOwner wrote:research has determined these are only decent with Boge struts and shocks that were oem....
Not necessarily, the Bilsteins can work well with the M5 springs.
Why would you say the M-tech reds are somewhat undersprung? Compared to the M5 springs?
-Chris
GaAlpinaOwner
-Chris
thanks for responding -
Sorry my mistake, the OEM M5 springs are slightly undersprung the MTech Reds are around 263 rate from what I am being told.
cgraff
Post by cgraff »
-Chris
That rate is incorrect.
However, the spring rates are basically like so:
Softest: stock 535i / US M5
Medium: Euro M5, and with a slight decrease in ride height, as per automotive literature at the time, of roughly 10-15mm
Stiffest: M-technic springs, with a decrease of approximately 1 inch over the stock 535i and US M5.
Both Euro M5 and M-technic springs come in a variety of lengths and/or rates to count for different options on the cars such that the result is a more similar ride height.
-Chris
GaAlpinaOwner
Chris thanks for the feedback -
cgraff
Post by cgraff »
GaAlpinaOwner wrote:Chris thanks for the feedback -
If you want more information, you will have to contact me offline.
Thanks
-Chris
rcbmw
Post by rcbmw »
I want to caution against generalizing the name of coil springs and shock absorbers. Users must be explicit in stating the full names and part numbers of parts because there are many versions of "Bilstein" absorbers, "M-Tech" coil springs, etc. this is how owners have ordered the wrong parts. In this case, "Bilstein" refers to the B8-Sport version and many OEM BMW coil springs are not suitable to be used with these absorbers.
Best,
RCBMW
cgraff
Post by cgraff »
rcbmw wrote:I want to caution against generalizing the name of coil springs and shock absorbers. Users must be explicit in stating the full names and part numbers of parts because there are many versions of "Bilstein" absorbers, "M-Tech" coil springs, etc. this is how owners have ordered the wrong parts. In this case, "Bilstein" refers to the B8-Sport version and many OEM BMW coil springs are not suitable to be used with these absorbers.
Best,
RCBMW
Which OEM coil springs are you referring to?
From what I've seen, you could in fact use both the Bilstein HD or the Bilstein Sports on the euro M5 coil springs (there's 3 different front spring PNs). It's in the 'grey' zone with regards to the metric that Bilstein says which is for "shortened" springs; although personally I'd probably use the Sports. The M-tech springs (2 different part numbers in front) should be used with Bilstein Sports, not the HDs. They can be paired with the BMW Bilstein that was also available and matched to those springs.
EDIT:
I note you mentioned discussing this offline. That is fine. If I discuss this any further it can only be offline. Needless to say on these forums information has to be more generalized.
-Chris
rcbmw
Post by rcbmw »
I will only discuss this offline.
Best,
RCBMW
I would like to discuss this further. I'll be behind the old railway station at 0200. Make sure you aren't followed. Your sign is "the dog barks at midnight". If you don't get ''The daffodils should do well this year" as a countersign, RUN!
GaAlpinaOwner
All I know is that both Chris and RC helped me figure this mess out. Thanks guys
There must be history here on this particular subject, that I do not care to stir/start up....offline it is and thanks again.
David Frankel
