Sell it, Park it, Swap it...
Yep. Doooo Itttt...Hutch wrote:Without a doubt, I say do this.johnnye23 wrote: I would put a good 265 behind it and stuff it all in the Touring !!! Bad-ass...
Nothing cooler then an M5T...
The E12 is not the best chassis to stuff it into. That engine in another E34, it was meant to be
Oh, then bring it on the RTT tour...
This was my thought, which is why I abstained from voting. Where is the *evilgrin* smiley?austin8753 wrote:Sell it outright. Price? I've always wanted an E34 M5...
Would be cool to swap. But the e34 is really not so far gone that it deserves to be torn down. Then again, as Chris notes, they are not worth much in the open market anyhow....
Which leaves the Park It option. That's the right thing to do. Circle back at a later date and make it right? Or, provided you have no deep emotional attachment, find a home that will follow a similar path.
I think I was the first to know about this project. I was told to "keep it under my hat" but I guess Sherman has a hard time doing that himself.
I voted "park it" only because I know of 2 S38 blocks for sale ready to be built up. 1 is a bare block perfect for a complete build and the other is mostly complete, should be missing the head and cams sometime soon , but needs a rebuild. IMO if your going through the trouble of doing a swap, might as well build a motor for it. It will add $$$ to the project but make it that much more special.
funfunfer wrote: Sherman,
... The mileage is your fault! I get 18-22.
http://www.mye28.com/viewtopic.php?t=101071
- Beamter
The reason I didn't buy this car when I was told about it (by the person you bought it from before he picked it up) was that I didn't want it to get parted out. I don't think it is right to part out a perfectly good hand built M5 just for the drivetrain, especially after seeing what Ed Locke went through to save one that most people would write off. As I said, though, if you do I am interested in the remains.
At 3K to 5K miles per year it will then be tolerable.Dave McLaren wrote:You don't like the thirst and you're concerned with the repairs coming along sometime on the S38. Those two don't look like good reasons to spend a bunch more to have them in an e12.
1st 5er wrote:... our E12, ...is relegated along with our E28 ///M5 to the occasional recreational jaunt,
I thought it'd be nice to get a bit more oomph out of its go pedal when it does hit the road.
- Beamter
What's the curb weight of an e34 Touring vs. that of an e32? I'm guessing there's not much difference. And besides; the M5 Touring has been done before, but an M7? Not so much.1st 5er wrote:That's goin' the wrong way. E32's are just overweight E34's.
I prefer lean, mean, and sexy, know what I mean?
Eddie does...
Curb weight on the e32 is about 3800lbs. The e34 528/530/535's are around 3500 I think.davintosh wrote:What's the curb weight of an e34 Touring vs. that of an e32? I'm guessing there's not much difference. And besides; the M5 Touring has been done before, but an M7? Not so much.1st 5er wrote:That's goin' the wrong way. E32's are just overweight E34's.
Eddie does...
I like the e12 idea the best...
E34 ///M5 - 3,682 lbsNicke28 wrote:Curb weight on the e32 is about 3800lbs. The e34 528/530/535's are around 3500 I think.davintosh wrote:What's the curb weight of an e34 Touring vs. that of an e32? I'm guessing there's not much difference. And besides; the M5 Touring has been done before, but an M7? Not so much.1st 5er wrote:That's goin' the wrong way. E32's are just overweight E34's.
Eddie does...
E28 ///M5 - 3,417 lbs
E12 Mnot - 3,371 lbs
Now we need to calculate the difference between the stock E12 M30 2.8 and the E34 S38-B36.
M30: 315 lbs
M88/B35: 321 lbs
B36/B38: 332 lbs
According to this: http://forums.bimmerforums.com/forum/sh ... hp?t=89822
M88/B35: 321 lbs
B36/B38: 332 lbs
E34 ///M5 - 3,682 lbsNicke28 wrote:M30: 315 lbs
M88/B35: 321 lbs
B36/B38: 332 lbs
E12 ///M5 - 3,388 lbs
- Beamter
What about the e34 Touring? Since that's what he was considering swapping the drivetrain into, the e32 was an alternative suggestion to that. Of course the e12 is going to be lighter; unique was the intent behind the suggestion, not light.Nicke28 wrote:Curb weight on the e32 is about 3800lbs. The e34 528/530/535's are around 3500 I think.
Either way, you'd be eligible for one of these.
What's the curb weight of an e34 Touring vs. that of an e32? I'm guessing there's not much difference. And besides; the M5 Touring has been done before, but an M7? Not so much.davintosh wrote:1st 5er wrote:That's goin' the wrong way. E32's are just overweight E34's.
Eddie does...
Who says nobody has made an M7?
I know of some guy named Kenny who has an e23 with an S38, pushes it around the track like a fat man in a tracksuit.
