Euro 535i LS Turbo Build Thread - 7/10/19 Dyno update
Those are only to keep you away from the cave if you approach within 100ft of the entrance.Duke wrote:You will need one of those to shoot the tires out on the Tiger as that will be the only way you can catch it.T_C_D wrote:Sweeney reminded me to post a picture of the alternative high speed drilling tools.
- Beamter
Made some progress Saturday. We have been able to determine where the engine will sit. Careful consideration must be made with the placement due to the addition of the turbo. We will be modifying the frame rail brace in order to lower the engine and move it back. We will need as much clearance in front of the engine as possible.
We have chosen an alternator and power steering package as well as exhaust manifolds (CTS-V). The packaging is going to be much tighter than I expected but it's going to fit.
Picture of the foam block with the tranny attached sitting on mounts but it's going to go a little lower and back once the exhaust manifolds are mounted so we can be sure of the final clearances.
BTW, the master cyl clears without modification.
That will help your front/rear weight ratio too.T_C_D wrote:We will be modifying the frame rail brace in order to lower the engine and move it back.
Shelby did the same with the Tiger as the engine is so far back I have to go throught a hole in the firewall on the drivers side to change spark plug #8.
Looking good!
A/C was removed a few years ago. keeping a/c with this setup would be difficult.rundatrack wrote:Good stuff todd
Do you think that you will be able to fit creature comforts in that engine bay as well?
Air conditioning? Yay or Nay
Those in the warmer states completely understand why I am asking. No way your driving a car without AC in muggy Florida weather.
This is a awesome project.
i should've worded it better but yes, that is what i meant. i'm glad somebody still cares about our e28s. you sir rock.T_C_D wrote:We plan providing some LS/t56 swap parts. Mounts, driveshaft, PS lines, and some odds and ends. I have not thought about the turbo kit because I thought the demand would be minimal.InkaCola wrote:question Todd, will you be making a kit available to the public?
Exhaust manifolds
Can you post a picture of the Exhaust manifolds. I have an LS1 in my E28 with a 4 to one collector that I am looking to improve upon.T_C_D wrote: We have chosen an alternator and power steering package as well as exhaust manifolds (CTS-V). The packaging is going to be much tighter than I expected but it's going to fit.
Bob
Re: Exhaust manifolds
I am turbo charging my LS so the manifolds are going to be turned the opposite side direction.robertt wrote: Can you post a picture of the Exhaust manifolds. I have an LS1 in my E28 with a 4 to one collector that I am looking to improve upon.
Bob
I have three sets of manifolds enroute and will try them all to see if any off them fit for your purpose.
Any pictures of your car?
Todd
Had a good day working on the car. Removed the diff, swapped centers on the wheels from style 19 to style 5. finalized the position of the engine and tranny. Prototype motor mounts and tranny mount finished.
The engine is as low as possible and moved back so that the shifter is in the center of the center console not the center of the opening in the body. It's about 1.5" further back than the center of the body opening so we'll need to cut sheet metal to allow the shifter to operate correctly.
We tried three sets of exhaust manifolds fitted backwards on on opposite sides. None fit the driver's side so we will be building the manifolds.
Also removed the PS reservoir and coolant reservoir bracket. It really opens up the engine bay on that side.
Sorry I'm late on this thread Todd. May Eddie and I please have a ride in this monster when you get here to Tedfest with it? I just love Frankenstein E28's. Perhaps you should invite Sweeney along for the ride to Tedfest so he can enjoy some Canadian hospitality as well. The HP wars have begun and there is no better place like Tedfest to enjoy and share the wealth of such great minds in this business of building great HP cars with BMW heritage. Good luck with the build and looking forward to seeing you,Harper and Sweeney at Tedfest this year. Tedster
With the kit being just the LS swap and not the turbo. Would A/C fit then?T_C_D wrote:A/C was removed a few years ago. keeping a/c with this setup would be difficult.rundatrack wrote:Good stuff todd
