m30b28 rebuild and turbocharge
soldier322573
Post by soldier322573 »
Hi peeps i just aquired a 2.8 m30 motor i am looking to swap it in my e28 518i and rebuild and turbocharge it one time.
i would like to achieve anywere around 300+ hp but i also have a Nos and Water inj Kit from my previous car so i am gonna put those on my motor.
Any suggestions and info on how i should build the engine would be appreciated.
PS: we dont get the 3.5 motor here in Barbados we mostly have 2.8's so i gotta work with what i have
Mark 88/M5 Houston
Post by Mark 88/M5 Houston »
Research Turbo Charging Dynamics. http://www.turbochargingdynamics.com/
"TCD" , Todd, is a member here and knows as much about turbocharging BMW motors as anyone.
soldier322573
Thanks will look into it
Xenocide
Post by Xenocide »
If you were going to do a full rebuild, it may be worth boring the block and swapping pistons to increase displacement. Of course that'll potentially add many more hundreds of USD to your budget.
Check here for a little more information, but Todd is likely going to be your best resource, as Mark said.
soldier322573
i was doing some research and i see d 3.0 has 89mm pistons as apposed to the 86mm in the 2.8 so i will bore the block to fit the 3.0 pistons
BATESY
Post by BATESY »
Not 100% percent of this, but usually with BMW blocks there the same just different bore size, keeps cost down on making them all.
soldier322573
From what i gathered the 2.8 and the 3.0 have the same stroke but different piston size.
That may mean same block same crank just different bore size.
BATESY
Post by BATESY »
correct.
Mark 88/M5 Houston
If you are boosting the engine the 200 cc's aren't going to make a whole lot of difference. If you can hone and re-ring what you have...
Just thinking the dollars might be better spent on the boost hardware or engine management system.
soldier322573
Fair enough i was just exploring my options
BATESY
Post by BATESY »
Probably take more boost on a low liter engine anyway.
soldier322573
Noted thanks
marc79euro645
Post by marc79euro645 »
head gaskets like to pop right between the cylinder,that's why I did'nt want to turbo my original m90 w /like 92mm bore iirc. It was really thin between the holes.
marc
soldier322573
Noted
soldier322573
what is a good turbo to use on my application
T_C_D
Post by T_C_D »
soldier322573 wrote:what is a good turbo to use on my application
What manifold are you using?
soldier322573
thinking a TCD manifold cause i am not really seeing manifolds online for the m30's i am only seeing for the m20 engines
T_C_D
Post by T_C_D »
soldier322573 wrote:thinking a TCD manifold cause i am not really seeing manifolds online for the m30's i am only seeing for the m20 engines
T04e, 60 trim compressor wheel, S4 turbine and .58 exh housing.
soldier322573
i take it that this is the best turbo and trim to use
T_C_D
Post by T_C_D »
soldier322573 wrote:i take it that this is the best turbo and trim to use
It's the correct size for your engine and HP goals.
soldier322573
Thanks alot. what size waste gate should i use on my application and what kind of blow off valve etc ?
T_C_D
Post by T_C_D »
soldier322573 wrote:Thanks alot. what size waste gate should i use on my application and what kind of blow off valve etc ?
Tial 38mm WG and 50mm BOV
soldier322573
sounds great. And what about injector sizing?
i have also seen some head gaskets from mls i think it was but i am only seeing for the 3.0 and 3.5 can these work with my application and also would i have to use strengthened head bolts etc?
sorry for all the questions but i wanna be sure before i go and start ordering parts like crazy
T_C_D
Post by T_C_D »
soldier322573 wrote:sounds great. And what about injector sizing?
I can have Cometic make a gasket for the appropriate size for your engine.
soldier322573
thats awesome thanks a million champ really appreciate that.
what would the price be including shipping?
T_C_D
Post by T_C_D »
soldier322573 wrote:thats awesome thanks a million champ really appreciate that.
Send me an email and I'll quote you for everything you need.
tcd@turbochargingdynamics.com
Thanks,
Todd
soldier322573
Thanks
Let the fun begin :D
soldier322573
M30b28 test fitted in E30 over the weekend.
Unto the pull down and rebuild stage :alright:
soldier322573
Oil Pan And Oil Pickup Problem
i test fitted the engine in position 3 but the oil pan is resting on the steering rack which isnt good so i changed the sump pan to the b35 pan to get more clearence but now i also have to change the oil pump pickup problem is we dont have any on island and i dont wanna use position 1
shocka
Post by shocka »
Maybe put a WTB ad in the for sale section im sure someone in the southern states has one. Lets see the car already :D
