Tightened up the hardware for the endlinks up front on my 535is. Clunking gone!
Took out the M-Tech II wheel and went back to the M-Tech I. Uber better.
Had my E28 M535i towed out of my driveway.
Took a photo of it out the front window.
Yesterday though I took the e32 to the tire shop & had the front end aligned. The yutz ended up breaking one of the tie rods, so it was an extra $75 for the part and labor to replace it. :roll:
Got the beater most of the way put together, then the through bolt on the UCA stripped. (Sigh)
L_N_Love
Post by L_N_Love »
ldsbeaker wrote:Got the beater most of the way put together, then the through bolt on the UCA stripped. (Sigh)
Do you have an E28 on the road yet?
PrionaceGlauca
Post by PrionaceGlauca »
Cleaned up the battery terminals and connectors this afternoon - warm water, baking soda, rubber gloves, tooth brush, steel wool... the works.
Removed negative first, then cleaned serious 'doughnut' corrosion on positive before removal of connector (faux pas?). Baking soda, then warm water... scrub, then rinse... and repeat.
Found the positive connector to be brass after the cleaning was done. Wiped off all excess water from the battery, steel wooled both posts as well as insides of connectors. Almost see my face in the reflection. ;)
Then proceeded to clean up ground contact.
All this in the attempt to "bring back" the front passenger amber (seemingly getting weak juice).
Went ahead and reconnected positive first... tightened it. Then re-attached ground and tightened negative connector.
Added dielectric grease to both terminals/connectors.
Spun her up - unreal... no prelim hesitation whatsoever; hit the windows and no change in headlight brightness as previously experienced.
Hit the lights - one amber left still going. Figured I'd go for a quick run and evaporate any excess moisture in the car's engine bay. Hit the sunroof, off I go.
On the way, started to rain. Hit the switch to close her up - just about done, and she dies - an inch before the wind deflector.
But hey... all three out of four originally working ambers are back... :rofl: :hysterical: :rofl: :hysterical: :rofl: :hysterical:
Having fun investigating this new issue.
Should have known better - what's the phrase? Let sleeping dogs lie? Or, if it ain't broke, don't fix it?
In short, I [expletive]'d it up.
ScottWL38
Post by ScottWL38 »
Coolant change, new thermostat, new expansion tank.
ScottWL38 wrote: Posted: Dec 12, 2010 9:27 AM
Somebody was up early.
bm0p700f
Post by bm0p700f »
I drove it. No maintance, thats a change.
Matt
Post by Matt »
Went outside in the -2F weather, into an unheated garage.
Put some new SS washers and 10mm acorns on the throttle assemblies. Screwed the little oil drainback fitting into the bottom of the manifold (with hose attached -- hose is too short. this sucked!)
Re-installed the airbox+afm
Attempted to fire the engine after sitting since nov of 2009. It has a reman starter in it that i put in 2 weeks ago to fix the tired starter solenoid. This new starter is serious business.
Engine fired right up! I saw the oil press light not going out so after a few seconds i shut it off. Checked a few things, refired engine. Engine was running rough and eventually it died.
Engine has not fired since, cranks for a while and occasionally stumbles, but won't fire. Guess the cold temps and year (or more) old fuel is the culprit.
Just came inside and added the following items to the "to do" list:
- tighten oil-drainback screw at bottom of intake manifold that has hose attached to it
- get longer hose for intake oil drainback
- fix wire sheathing on AFM electrical connector
- fix the coolant hoses and double-T intersection
- replace coolant bottle overflow hose
- fix the alternator B+ boot
- replace alternator bushings
- replace partially rounded off 10mm nut on intake manifold on cylninder 4
- replace the hose that goes from head to ISV (hides under throttles). it is cracked and leaking
- defroster button sticks
Also, since i swapped in drivers front seats a week or two ago, for the first time in 10 years of E28 ownership, the headrests move up and down :)
SeaWolf
Post by SeaWolf »
Adjusted and lubricated the throttle mechanism end to end. The pedal has always been a bit heavy and even after lubing everything was heavier than can be good for it.
That throttle pedal spring is a little on the industrial strength side and must put more stress than necessary on the pedal and shaft bushings, so I've replaced it with the same length spring of slightly lighter wire size ~ the difference is totally amazing.
ScottWL38
Post by ScottWL38 »
Overnight temps to be in the low to mid-teens for the next few nights. It was now or not at all!
mitch
Post by mitch »
Traded out the heater blower, rear side marker covers, sunroof switch, rearview mirror adjustment switch, and some fuses from the parts car.
Yesterday, actually. Today was 12 degrees, windy, and snowy. :evil:
1st 5er wrote:Pulled the ///M5 out and began the shifter rebuild process.
It's trying to kick my butt. :evil:
More tomorrow...
Got 'er done. :banana:
Replaced the guibo while I was under there.
New exhaust gaskets and hangers.
Took her for a test drive.
Patrick McHugh
Post by Patrick McHugh »
Installed cardinal door cards, pulled out the nasty beige carpet, installed nice black carpet, dyed most of the interior pieces black, dyed the headliner black.
fiver diver
Post by fiver diver »
Been busy in the last week or so.....
New DEC cat. & o2 sensor Got the CA version with better warranty and flow.
New CSB.
New guibo.
New clutch slave.
New flywheel sensors. (Old ones worked, but the connectors were disintegrating....)
New TPS.
New CTS.
Plugs, ignition cap, rotor.
Cleaned AFM track and de-oxidized all under hood connections.
Oil & filter change. + trans and diff.
New RS LCA
Michelin X-Ice II's just in time for snow. Truly amazing traction.
Used all OE parts except for the cat.
I love my car. Wouldn't trade it for anything BMW makes these days.....
I had my Hartges re-balanced and then I put them on the 535is.
I did something else, too, but can't remember.
made a gauge cluster from an old door card.
Ur shifter iz busted! :rofl:
wkohler wrote:Ur shifter iz busted! :rofl:
What shifter :rofl:
Das_Prachtstraße wrote:made a gauge cluster from an old door card.
That looks slick! :up:
Post by slammin_e28 »
What shifter :rofl:
Is that the fixed gear conversion? Now you just need to delete the brakes. :rofl:
ilikemybike
Post by ilikemybike »
Lent it to my girlfriend since her car had a warrant on it and it was towed. 9 fucking unpaid parking tickets going back to 2006! Now she needs a small fortune to get it back.
Steering wheel too; somebody stuck it on the wrong side of the car! ;)
Rofl, well it IS all the rage at the moment apparently!
surfdawg
Post by surfdawg »
Took the battery to be checked after getting a 68 mile tow last night.
Xenocide
Post by Xenocide »
Last night spent about 4 hours under my brother's eta doing his clutch and r&r-ing the transmission and shift bushings. The PO stripped one of the torx bolts and replaced it with a POS grade 2 Allen headed bolt, which rounded almost completely. It's a miracle we were able to get it out, slow going with a big impact saved our asses.
Then on top of that, the transmission input shaft was damn near seized in there. After about an hour of pulling and prying we had only opened up a 1/4" gap...
Bruised, beaten, and exhausted we put a couple of the bellhousing bolts back in, cracked a couple beers, and called it a night. I'm at work right now, he's working on it, hopefully he's having better luck.
The first addition I'm doing when I buy a house is to put in a lift. :lol:
Washed the ///M.
RetiredDoc
Post by RetiredDoc »
Xenocide wrote: The first addition I'm doing when I buy a house is to put in a lift. :lol:
Check this out first.
http://www.ezcarlift.com/
Discovered it on Rod Paine's web site.
http://www.mye28.com/tech/rods_pages/index.html
cfalco
Post by cfalco »
Thanked (and paid) my mechanic for installing the subframe and trailing arm bushings, brake booster. SLS system function checked out perfectly - no leaks either.
Never understood how you'd have easy access to drop the exhaust, drive shaft, and/or tranny with this unit, being that it requires the two cross members for stability.
