Cool pic, no pun intended. However if there was anything Bav's did worse than snow/salt/rust country, it was the desert. Early heads, cooling systems and the A/C on them was an evil mix.rmiddendorf wrote:I was going through old prints and I found this picture of my parents' old 1973 Bavaria in the winter. It was probably still running at this point, or at least was recently.
The Thread of Randomness. . .
Love the wheels on the Bavaria. I wish they could be had in the correct offset, diameter and width to run currently available rubber on the M5.rmiddendorf wrote:I was going through old prints and I found this picture of my parents' old 1973 Bavaria in the winter. It was probably still running at this point, or at least was recently.
I like those wheels a lot as well, however I may not like them quite as much as you do. They're very fitting on the E3/E9 cars.Mark 88/M5 Houston wrote:Love the wheels on the Bavaria. I wish they could be had in the correct offset, diameter and width to run currently available rubber on the M5.rmiddendorf wrote:I was going through old prints and I found this picture of my parents' old 1973 Bavaria in the winter. It was probably still running at this point, or at least was recently.
I don't usually laugh at people's misfortunes, but that right there is funny!oldskool wrote:Trying to defend a "delicate" area from vermin this morning when a hose popped off my spayer covering me in a mix of coyote urine and putrid eggs. A few choice words were said to say the least. Hope to be use to the smell by lunch as I am too far from home to change. One sad panda here, Bo.
Speaking of unwanted vermin, I finally got medieval with the cottontail that kept burrowing under my shed. Over the weekend I blocked off all of his entrances but one, and put a leg catch trap in it. Not long after I checked it Sunday evening I was in the kitchen and noticed the motion sensor light on the back of the house was on; looked out the window and saw the neighbor's cat wrestling to keep a hold on Peter's windpipe. Mr. Cat got the satisfaction of a kill and a meal, and I got rid of my problem. C'est fini.
http://www.youtube.com/watch?v=4dp4OIJ5iWwldsbeaker wrote:Okay then, riddle me this..
How do i get rid of the pigeons and blackbirds that love my driveway and cars so much?
http://www.gamousa.com/product.aspx?pro ... ductID=405
Or one of these - http://www.airforceairguns.com/Talon-SS ... s-s/38.htm - The AirForce guns keep all the pressure in the tank, ready to fire immediately, no pumping, and no leaving a CO2 canister installed. The Gamo is a really nice airgun, but you can't leave it charged up and ready for an immediate shot without putting a lot of pressure on the seals.ldsbeaker wrote:Okay then, riddle me this..
The drawback? Well, yeah, it's 4x the cost of the Gamo.....
That Talon looks sweet. While on the subject of PCP airguns, the Crosman Rogue .357 is nuts. A .357 cal airgun that they clain is good for up 100fps depending on pellet weight and good for coyotes up to 75 yards. Wicked, but way too expensive.
Holy crap! I thought a .22 cal pellet gun would be a bit of overkill. BTW, the muzzle velocity is "700 - 1000** fps"; I think 100fps would fall to the ground a few feet away.Brad D. wrote:That Talon looks sweet. While on the subject of PCP airguns, the Crosman Rogue .357 is nuts. A .357 cal airgun that they clain is good for up 100fps depending on pellet weight and good for coyotes up to 75 yards. Wicked, but way too expensive.
Was pretty much leaning this direction. I thought about calling my pest guy, but this is definitely more sporting.
Talked with my neighbors (more Marines and Border Patrol), and they are okay with me taking pot shots from across the street in the direction of my house.
I fully intend to kill everything that comes down from above.
If any are incapacitated, i will finish them off (laughing or not).
After a day or so, (after the other birds have gotten the message), I may call the proper authorities, or clean the bodies up.
I just use grocery store body bags. They're not just for groceries any more.ldsbeaker wrote:Was pretty much leaning this direction. I thought about calling my pest guy, but this is definitely more sporting.
If I won the lottery, I would buy the entire Qwest DSL "tech support" (I use that term very loosely) department and fire everyone of their tier 1 reps. And everyone who manages & trains those monkeys. EVERY time we have a connection issue where I have to call them results in a minimum of an hour of my time being wasted trying to convince them that the problem is NOT on my end. Here's the latest example of their technical prowess, as I remember it from last night... (it's long, but I feel ever so much better after letting it out.)
Me: My internet service isn't working. I've already gone through and checked the connections and the settings, rebooted the modem twice, and no success. Is there a system problem on your end that's causing the outage?
Monkey: Ok sir, I'd be happy to help. Could I please verify your phone number, your home address, and the last four digits of your Social Security number?
Me: The phone number was verified by the automated system moments before you picked up the call, but it's xxx-xxx-xxxx. My home address is xxxx S. Wherever Ave., Sioux Falls, SD, and I don't give out any part of my Social Security number over the phone.
(After a long pause) Monkey: Could you please verify your home address WITH the area code?
Me: Area code?
Monkey: Yes; the area code. City, state and area code please.
Me: OK; my ZIP code is 57xxx.
Monkey: And the last four of your Social Security number?
Me: I already told you I'm not giving any part of my Social Security number over the phone. And I don't recall ever giving Qwest my Social Security number, so I don't see how you could have anything to verify against, nor why you need to verify that in order to get my internet service working again. Please just check to see if you can do that, ok?
Monkey: Well sir, I can see in our system that your modem is connected and should be working, so I need to verify that the settings on your modem are correct. To do that I need to first verify that you are who you say you are and you are calling from where you say you're calling.
Me: First off, you didn't ask my name, so I didn't tell you who I was. And didn't your system recognize the fact that I'm calling from my home phone, which is in fact a landline, and is in fact installed at the address which you have on file and I have verified with you? I just don't see why you need to have my Social Security number in order to get my internet service working. If you're able to see that my modem is connected, then why is my internet service not working?
Monkey: Again sir, I need to confirm that you are who you say you are and you are a person authorized to be making changes to your internet service.
Me: I don't want to make changes to my service, I want it working. In other words, I want what I'm paying for; is that so difficult to understand?
Monkey: Ok, never mind the last four of your Social; could you instead verify for me the customer code from your telephone bill?
Me: Really? My wife is the one who handles that stuff and I don't know where it's filed. She happens to be in the hospital right now, and even if she were home, she would likely be in bed at this hour, so I'd be no better off. Can't we just skip that?
Monkey: I need to have one of the two before we can proceed, sir.
Me: Fine. (drops phone on counter and fumbles for ten minutes looking for phone bill; finds it) Ok, the customer number is xxxxxxxxxxx.
Monkey: Thank you sir. May I please have your name and a phone number where I can reach you in case we get disconnected?
Me: Really? I've already given you my phone number, which is the same one that I'm speaking to you on and which your system magically recognized, which is the same one that is hosted by your employer, and is the same number through which you can supposedly see that my modem is connected, even though it's not working. Is that the number you'd like me to give you? And my name is David Thornton. The name on the account.
Monkey: Ok sir; do you have a computer connected to your modem?
Me: No; I have it connected to an RJ-45 jack in my ear. It's wired directly to my brain... Of course I have a computer connected to the modem.
Monkey: Alright then, please open a web browser, then navigate to the administrative page for your modem. Do you know the address for your modem?
Me: Yes I know the address, and if you recall, at the outset of this call I mentioned that I've already verified the settings on the modem, have checked the connections, and rebooted the device twice.
Monkey: Yes sir, but I'd like to double check them again.
Me: What is the point of checking them again? I just checked them not five minutes before making this call. Plus, my internet connection was working fine 45 minutes ago, and nobody touched any of the settings on my DSL modem before the connection failed; do you think the settings spontaneously changed just so I could have the pleasure of arguing with you? I checked them because I knew if I called for help that's one of the steps I would need to go through, and I thought I'd save you some time. The problem is not on my end. Please check to see if there is an outage in my area and either let me know how long it's going to be down or fix it.
For the next 45 minutes, the rest of the call regressed in a similar manner, with the monkey going through the exact same troubleshooting steps I had gone through before, PLUS asks me to reboot my computer. How the hell is rebooting my computer going to magically complete the connection BETWEEN THE MODEM AND THEIR SYSTEM? It's now 1:40am, I'm tired & getting increasingly pissed off at this dolt who refuses to acknowledge the possibility that the problem is on their end, so tell her I'm done. She wins. I'm going to bed (so in a way I win too.)
I've got a busy day, so I'm up again by 6:30, check the connection, and it's still down. Crap. Reluctantly call the number again, furble my way through the phone map to the proper place, and am told by an automated voice that they are aware of an internet outage in my area, and that technicians are working on the problem.
Me: Area code?
Bonamassa is da bomb. I'm going to have to see if there's a recording of that broadcast online somewhere. FWIW, Joe is giving a signed Epiphone guitar away for Christmas. I don't play much more than a couple of chords, but would still love to have that box! http://jbonamassa.com/epiphone/smitty wrote:Blues alert!
Just finished watching Joe Bonamassa at the Royal Albert Hall, on a PBS broadcast out of Tacoma. A great guitarist and a decent singer.
I laughed, I cried; I had shivers down the spine! Check this guy out.
Oh, and I love my Klipsch speakers. The ears are ringing, but in a good way.
Wouldn't be at all surprised if the individual on the other end of the line was an outsource. She spoke with something other than a midwestern dialect; I'm guessing English was not her first language, but I wouldn't hazard a guess what it was.a wrote:Dave T. I feel your pain. I have been in your shoes with the phone company. However, consider this. What would your service be like if these poor miscreants were out sourced?
BTDT myself. On the outsourcing you never know, while I like to see the jobs stay here, I think it depends on the level of service they are willing to pay for, including language skills. I was working on the grandson's computer recently, had to call the service number to send it in due to a bad MB, and the customer service agent was clear, consise and helpful, and spoke better English than many native speakers. I ended up asking at the end of the call where she was from and it was the Phillipines! I thanked her and complemented her language skills.a wrote:Dave T. I feel your pain. I have been in your shoes with the phone company. However, consider this. What would your service be like if these poor miscreants were out sourced?
It all depends on what the company is willing to pay for, not just the people they get. Tech savvy people who can do more than read from a script cost more.
