I replaced a section of rotted out exhaust pipe on B6II's franken cat back. the pipe had sprung a leak where the right hanger arm was welded to it. I used the same piece from the Borman6's original Boysen exhaust. Idiot's delight with hand made couplings to graft onto a Bosal 533i muffler. The back of the muffler was punky from sitting, so I covered it with a piece of galvy sheet metal. I used tek screws, #6 x 1/2'' and gooped everything with high temp RTV. I bought brand new bolts and hardware for the flanges. Grade 2 5/16 X 2 1/2 A nut, 2 flat washers and the bolt were 80 cents times 4 for a whopping $ 3.20 There are parts from 3 different catbacks. and a little extra metal to patch it all together. W hen I carried it from the bench to the car, it felt solid. It fit fine and the tips are hanging level. The car is now ready for re-inspection. I replaced the LBJs the 2 previous weekends.
- Beamter
New M535 diff mount, new dogbones, new swaybar links front and rear, new swaybar bushings front and rear. Went Powerflex on the bushings. In a do-over, or on a future vehicle, I will do stock rubber bushings. Holee shit it's a tough fit for that stiff poly. Lots of wrangling with lumber-levers and jacks to press the brackets into place.....
Subframe bushings will wait until the winter parking conundrum is over and I can get onto the lift.
I love getting new parts. I'm like a little kid on Xmas.Eta power wrote:Yeah, I probably shouldn't get as excited as I do over new parts...slammin_e28 wrote:It's probably some condition, but I get all tingly inside!
I finally got my windows to start rolling up and down. And I went to put in a drivers side interior door handle....only to realize the PO didn't even have the screws in there.....time for a trip to pick and pull to see if anyone didn't yank the screws for the handle
Also, painted the front grilles flat black. Now they don't look so worn.
This sucks. There's another good thing about the Motronic 1.3 in my old E24- at least you get a CEL and a code to tell you what part(s) is(are) smoking crack. I know my Peake tool doesn't code anything on a 1.0- does 1.0 throw error codes at all?slammin_e28 wrote:I don't drive it much until I figure out the 15mpg issue.
Don't think so. I have a B35 swap, thus M1.3. No CEL on it though. I'm leaning towards it running in closed loop (really really rich) as the temp gauge doesn't go above 10:00. I've got a VDO temp gauge, but I'm waiting on the sender to come in the mail. Until then....it sits.rmiddendorf wrote:This sucks. There's another good thing about the Motronic 1.3 in my old E24- at least you get a CEL and a code to tell you what part(s) is(are) smoking crack. I know my Peake tool doesn't code anything on a 1.0- does 1.0 throw error codes at all?slammin_e28 wrote:I don't drive it much until I figure out the 15mpg issue.
Yeah if you don't wire the CEL into the dash you won't magically have it. It was standard on the B35 E24s. Did you swap the diag connector from the old to the new? The new one has more pins in it. If you did convert that you might be able to read the fault code and that may help you trace why your fuel economy is down even without the CEL.slammin_e28 wrote:Don't think so. I have a B35 swap, thus M1.3. No CEL on it though. I'm leaning towards it running in closed loop (really really rich) as the temp gauge doesn't go above 10:00. I've got a VDO temp gauge, but I'm waiting on the sender to come in the mail. Until then....it sits.rmiddendorf wrote:This sucks. There's another good thing about the Motronic 1.3 in my old E24- at least you get a CEL and a code to tell you what part(s) is(are) smoking crack. I know my Peake tool doesn't code anything on a 1.0- does 1.0 throw error codes at all?slammin_e28 wrote:I don't drive it much until I figure out the 15mpg issue.
Hmm....I didn't think to wire the CEL in.rmiddendorf wrote:Yeah if you don't wire the CEL into the dash you won't magically have it. It was standard on the B35 E24s. Did you swap the diag connector from the old to the new? The new one has more pins in it. If you did convert that you might be able to read the fault code and that may help you trace why your fuel economy is down even without the CEL.slammin_e28 wrote:Don't think so. I have a B35 swap, thus M1.3. No CEL on it though. I'm leaning towards it running in closed loop (really really rich) as the temp gauge doesn't go above 10:00. I've got a VDO temp gauge, but I'm waiting on the sender to come in the mail. Until then....it sits.rmiddendorf wrote:This sucks. There's another good thing about the Motronic 1.3 in my old E24- at least you get a CEL and a code to tell you what part(s) is(are) smoking crack. I know my Peake tool doesn't code anything on a 1.0- does 1.0 throw error codes at all?slammin_e28 wrote:I don't drive it much until I figure out the 15mpg issue.
The engine is from an e34, but it was in an e28 before I got it, so the harness was already cut and ready to plug-n-play. I think tomorrow I'll take it to work and see if I can get anything out of it on the scan tool.
Tomorrow I'll look into getting that CEL to work. Thanks!
