It may even be worth a thread of its own.
TMPS RANT TIME!
For only the third time in 6.5 years and 60K miles I have a leaky tire on the Tundra. And for the third time the culprit is.....
A LEAKY TMPS SENSOR!
So the sensor part of the system that's supposed to tell you when you have a problem is the part that is causing my problems. Nice!
I get it - most people that drive cars are morons and would drive around on a flat tire all day long. Ignorance truly is bliss. They need TPMS, and it's a requirement since the 2006 model year. BUT....
I'm a guy, like many of you, who can actually SEE when a tire is low, and actually checks his own tire pressures on a reasonable schedule. Before last summer I didn't even *know* that my stripped-down base-trim Tundra had TMPS. And then the light came on. What the heck is that light? Oh, well, I do have a lowish tire (they were set to trigger at 29lbs, which isn't very low visually). Those tires were basically shot anyhow, so I ordered up a new set and had them installed.
Mavis brings in my new tires and mounts them. They tell me that two of the TMPS sensors are cracked, not just the one leaky one. They glue one back together and replace the other. Unfortunately they are unable to sync the new sensor with the truck's computer, so while I no longer had a leaky tire, I do have a perpetual TPMS light on the dash. Did they mention that they were selling a part that they could not properly install and sync to the computer? Of course not. Morons. They told me that I'd have to go to the dealer for that. :roll:
Another 10 months later and I've got yet another sensor that's leaking. This time I'll go to the dealer. Time to bend over! Oh well - it's time to do the transmission fluid, and that's not a tranny I want to play with.....
Micah,
Several years ago I had a new '06 Tacoma with TPMS. I put 18" XRunner wheels on it, with the correct sensors. I wrote down all the numbers the dealer asked for prior to having the tires mounted.
They quoted me an hour to sync them.
It ended up taking most of the day, they had to dismount all the tires and get different numbers off the sensors I guess.
They only charged me the quoted hour though. :alright:
e28Sean
Post by e28Sean »
I bought this '96 Exploder to use as a 2nd car, so I can have more opportunities to skin my knuckles working on the e28. In the week since buying it, I have:
- torn out the carpets (they were beyond saving)
- removed, washed, and replaced the seat covers
- fitted new headlights, front fog lights, and front turn signals (old ones were cracked and faded)
- questioned my sanity on several occasions
This should probably be in Tech Talk, but because it's $38B36 content...
Anyway, it's all about proper tools and techniques.
http://youtu.be/1aU6lLhvHvw
P.S.
Pavel Vasilev, Technical Director.
RonW
Post by RonW »
Fixed the leaking windshield washer pump on the E46. Apparently this is a common problem with these cars. The problem was a leaking rotary seal around the motor shaft. It looks like a 5-cent rubber part, and can be replaced in about a minute without using any tools - assuming you can find a replacement seal, which you can't.
So I put some silicone in the seal's shaft hole to reduce its diameter so it would seal around the motor shaft, some more around the hole in the housing that the seal slides into, and some above the seal once it was in place so the motor would be sealed to the housing. This means that if the seal fails again, the only way for washer fluid to leak into the motor is through the shaft bushing, which I covered with grease. (I also greased the shaft itself so it wouldn't wear out the rejuvenated seal.
The weird thing is that aside from the electrical connector, the pump looks just like the E28 pump, and similar to the pump on most cars. So why does the E46 pump fail after a few years, while the pump on my 578k mile E28 may be original?
Finally changed out the burnt reverse light bulb on the e30 that decided to break into tiny shards mid-turn. I now have a gaping 1" cut on my thumb and my forefinger isn't pretty either. Anyone wanna kiss my boo-boo?
As the ZHP approaches 200K miles, there were a number of preventive maintenance jobs to take care of. In addition, I've had a bit of a bonk-a-donk coming from the front end and as ambient temps climbed above 50-60F, that noise became a permanent fixture. In this thread on April 21 I noted that new sway bar bushings had suppressed the noise....um, no. That only lasted a day.
On subsequent weekends I did new brake rotors and bled the brake fluid (maintenance not related to the bonking) and swapped the OE front sway back onto the car - no change. Then I did new front control arm bushings and ZHP control arms - no change. Then last Monday I drove back and forth over the entrance to the driveway with my son feeling the top of the strut. "OH YEAH! There's a lot of vertical movement!" Okay - I ordered the parts plus new spring pads and other hardware.
Replacing the strut mounts - for some reason I had been dreading this job. In reality, it was a total piece of cake. The pinch bolts came out with a little Deep-Creep and the persuader. The PSS10's mean it's a very short strut/spring package so none of the ball joints had to be disturbed. And it's a LOT LIGHTER than the e28/e34 strut assembly, so it's an easy one-man job to lift into place. I swapped out the driver's side Friday evening while I was still in my Hawaiian shirt. The passenger side I did Saturday morning, plus an oil change, and had the car buttoned up by 9:00AM.
Next day edit - unfortunately it bonked on the way home last night. Same bonk. I'd swear it's a swaybar endlink bonk, except that I've swapped them twice now in the past 6 weeks, *and* the swaybar bushings, *and* the entire swaybar. I should probably drive it with the swaybar entirely removed. The problem is that the bonk only seems to happen when the car is hot - which points to a soft-tissue thing like a bushing or a mount, maybe a balljoint. 56F this morning and no noise at all. I'll have to wait for more permanent warm temps for better diagnostics.
In any event, the car feels freaking great with all the new parts up front.
Post by slammin_e28 »
slammin_e28 wrote:https://www.youtube.com/watch?v=SaNiK_QBxIU
Hehehehehehe!
:cool:
Fu*k yea!!!
Hehehehehehe!
:cool:
Fu*k yea!!!
Dittos.
jdgnzlz
Post by jdgnzlz »
Installed my new all aluminum radiator from wizard cooling on my e28 m5 along with new oem water pump, oem t stat, All oem hoses and clamps, oem fan clutch, oem expansion tank, continental belts, and a cool red euro fan I got from sherman. Gonna change the fuel filter and oil tonight and I'll be ready for the trip to bimmerfest.
I finally got around to replacing the front bumper wiring harness in the e32 and got my fog lights working again. Also got all four of the side marker lights working, put a new A/C belt on (finally found one that fits) and did some general cleanup on it. Why do I put up with all these niggling little problems on my cars until it's time to sell them? :cry:
yodman
Post by yodman »
1990 Jetta VR6 - Drove it to work, loving every minute of this car again. I've had it for four years now, it's been totally gone through, and I pound the hell out of it because that was the intention. I did get bored for a little, then I bought slower cars... ;-)
1987 325is - Stared at it with sadness in the backyard as the big tree craps all over it, awaiting my motivation and a helping hand to jack it up and change the clutch. Literally all that needs done. I'll make sure I know the skill level of people driving my cars from now on. Clutch was ridden for 5 miles without my knowledge, and is now toasty. 25% or greater throttle leads to massive slippage.
1987 535is - Decided it was time to tackle the suspension overhaul it so desperately needs. It's on jack stands with PB blaster coating everything so I can get it apart tonight.
1972 Super Beetle - Will be working on this later, installing an electric fuel pump for reliability's sake, as well as wiring in some new gauges for the dashboard, including a tachometer and oil pressure/temp gauge.
Hehehehehehe!
:cool:
Finally. :D
funfunfer
Post by funfunfer »
E12: Verified clutch slave cylinder rod movement of 23mm, so ......
Dropped transmission , then...
Removed bolts from bell housing, but....
Bell Housing not moving, oh crap, does this mean....
I have to remove the starter, too?
davintosh wrote:... the e32... it's time to sell... :cry:
How much?
Hehehehehehe!
:cool:
Finally. :D
IKR?
Just need to make my shift linkage.
Then cooling system, make it less ghetto.
....and I need a new core support.
yodman
Post by yodman »
Drove my '72 Beetle for the first (and second) time on the road! Only went about 200 feet before I turned around in hopes it wouldn't die!
Needs a tune up, and will get one tonight along with a tachometer, voltmeter, oil pressure, and oil temp gauge.
Wasted another hour trying to bleed the air out of the weird e39 heater part of the cooling system.
Also, replaced the hood shock on the e30 (it only has one). Since around 1852, I had always heard "things" about replacing the pressurized /shocklifter (or whatever you call them) but except for the manual Sport Seat versions, I never had any problem.
Did an oil change and hit 260,000 miles on the piece of shit.
Drove the Rat to my brother's place.I picked up the Super E down pipes he had repaired for me. I filled up th front tires and put 25$ worth of gas into it.
Micah I LOL'd at the Hawaiin shirt link. That has to be frustrating as hell to try to find that bonking.
Washed the E46 325xiT for the first time since getting it 2 months ago. It's kind of nice having a BMW I don't obsess over.
I know, some people like having the high beams on automatically during the day, at reduced voltage like a POS Saturn. I don't. But the most recent addition to the fleet was programmed that way and while I got the software and cable, I haven't been able to make it work yet. Not unusual I hear. So I took a lower tech solution, and installed relays in the high beam circuit. I use the high beam signal to switch the relay, reduced voltage while plenty to be irritating on the high beams, is still low enough not to operate the relay. But full voltage is. So now I, not someone who has never driven the car, have full control over the headlights. :banana: A pair of relays from Amazon, a couple of pigtails from Pick and Pull, a few minutes work and Bam, fixed!
Mike W. wrote: I got the software and cable, I haven't been able to make it work yet.
Mike, which software are you using?
It's a suite of things from a guy in England dba Cable Shack.
USB Cable driver
BMW tools
VM Player
DISV57
Progman/sss
I spent all of one night trying to load and get it working but got nowhere. I'll try more later, he's supposed to be very good on support.
Maybe I should try generic, I think it's out there. Reportedly it doesn't work well with too new and too fast a laptop, but it's possible mine is too old and slow. :laugh:
Maybe you should get the thing Charles has. It's a repurposed rice cooker controller, but it gets the Duke seal of approval since it can even reprogram your car's VIN.
wkohler wrote:Maybe you should get the thing Charles has. It's a repurposed rice cooker controller, but it gets the Duke seal of approval since it can even reprogram your car's VIN.
Bazinga. Kohler is still ROLLING!
Ouch.... Zinger.
Mike I had a biotch of a time getting my pa soft working and recognizing the cable. But it was so worth it to turn off the damn DRL's and reprogram the cooling temperature gauge.
Adam W in MN wrote:Ouch.... Zinger.
I'll go at it again and again if needed, but I just wanted to shut the damn things off for now. I did strip the insulation on the ground to solder a wire to it, but I didn't cut a wire. Very reversible for when I do get the programing down.
