Discovered the high pressure pwr steering line from the piggy (which is in the process of being scrapped) is the correct fitment for the power steering pump on the M106, which has saved me having a custom one made up, due to the original one having the wrong pressure fitting for the new pump. Removed/Installed that.
Then went about trying to diagnose my no start. Pretty certain the starter motor is dead, as after all other wiring checked out, I still only get solenoid noise out of it, and no cranking. I'll jump pin 11-14 tomorrow morning to be sure, and if no bananas, rip the fucking thing out. The only thing stopping me from having this 0km motor start up for the first time in 1.5 years. Hopefully.
Good luck! I just dealt with the starter on my wife's Sienna. Pulled it out/apart, cleaned the (very worn) contacts for a temp fix, reinstalled. Pulled it out/apart to change the contacts, reinstalled. Pulled it out again, and replaced the damn thing. 80k original miles on it. My 4Runner has 175k on it's original one.Das_Prachtstraße wrote:Discovered the high pressure pwr steering line from the piggy (which is in the process of being scrapped) is the correct fitment for the power steering pump on the M106, which has saved me having a custom one made up, due to the original one having the wrong pressure fitting for the new pump. Removed/Installed that.
Drove the piss out of it.
Bombing around The Bay at 80-- listening to what sounds like a really worn TAB, bone, or SFB. It made a SQUISH when the rear left shock (new) is at its max and gets pushed further or takes another impact. I think I can duplicate it just by stomping on the gas when in fourth at ~60mph.
Otherwise, a lovely day in the bay.
Drove the M5 to work. It's only seen local trips to soccer practice and the grocery store since awakening from its winter slumber.
50 miles over hill and highway. Hammering fourth gear from 85 through 100 is a symphony. That song draws me to ever-higher speeds and wider throttle openings (and eventually some tickets, I'm sure).
Fabulous in the twisties, a perfect high-speed cruiser, and if you want to drive like an ass-hat, bobbing through a long series of left-lane squatters, it's the perfect tool.
Definitely made a big difference. The car seems to have the common coolant temperature sensor problem, so I'm going to replace that to see if it runs without randomly jerking or dying.brkinshiz wrote:Finally is an understatement. Good job lol. Make a difference?saigon535 wrote:Finally got around to doing the cap, rotor, plugs and wires.
replaced parking brakes, everything was original for the parks and dragging because it was all corroded, after 9 hours of pain I finally got the disks to fit back on by using new hardware with the old shoes. it works. everything needs to be replaced from the hubs to the diff due to corrosion. but it rolls and drives great so Im waiting to save up all the money for both sides, or until something locks up. the calipers are actually in good shape so Im just going to rebuild them (thank goodness).
- Beamter
All shimmying is gone, even through that 120 MPH wind gust I hit in 3rd just as the rev limiter kicked in,mooseheadm5 wrote:How are you liking the UCABs, Sherman?
did I mention I swapped in a 3:25 LSD for The V and RTT trip.
And no issues going the other way either.
Simply put
Not able to comment on ride difference due to front suspension being changed at the same time.
Not sure what is attributed to what, but I, like Mikey, likes it.
- Beamter
Drove it around after replacing my thrust arms... yesterday. Hey... it's Sunday and I have A FULL TANK OF GAS AND 46 POUNDS IN THE TRUNK*... LOL.
It's doing so much better than Friday. More suspension parts to follow. My bushings were made of mostly air.
*(jeff foxworthy voice) If you understand this... you might have replaced your e28 control arms!
(yesterday)
Did the csb, guibo, tranny/engine mounts, and the shifter bushings(except for the front one, it was getting damn dark). Glad I did cause the guibo as it turns out was a ring of nylon reinforced with what appeared to be dust, the motor mounts were more or less three pieces each, and the tranny mounts had all the structural integrity of a squeezey toy.
couldn't have done it without Mtnman533 and Saigon535, freakin life savers!
