My 535is Turbo Buildup Thread! - update 11/26//09
For low boost its a matter of preference. I liked the 3.46 when the car still hooked in second gear. It depends on what you like. Once you get used to taller gears you'll probably start to like them more. The difference between a 3.46 and a 3.25 or a 3.25 and a 2.93 isn't very significant. A 3.73 to a 3.25 is significant.
In my experience, the taller gearing helps at all speeds. You still wont hook in first or second, but you have enough time to shift and retain momentum. Third fourth and fifth will pull at least as hard because the engine spends more time under load in each gear. You'll build more boost and accelerate at least as quickly and for longer than you did with shorter gears. I enjoy winding it out and watching my victims suddenly drop further and further back with each shift. I only have two shifts to hit 120. If you have the power to pull it, tall gears are great.
The only downside in wide ratios is gear selection from a roll, but since you're going to blow the tires off below highway speed anyway its not really important.
Scottinva
Post by Scottinva »
That's the problem I had when I helped my brother finish his built 240 turbo project, it was running a lot of gear. Traction wasn't an issue, but it felt like you were just running out of gear, and felt like right where it was pulling nice you would have to shift.
Well, I got a little bit of tuning done tonight on the way home. The lower boost onset region is finished and I am almost tuned to 11psi (was at 8.5). It definitely feels a lot better now and the turbo is really coming alive and it feels like it complements the diff nicely. It should be dry out tomorrow ( I found the rev limiter a couple of times) and I'll try to get it fully tuned at 11-12 psi. The amazing part is that the clutch hasn't flared yet, but if it does, I don't really care.
Scottinva
Post by Scottinva »
You should figure out who made that clutch, send them an e-mail and be like. Your shiz was epic! lol
George
Post by George »
That clutch is full of win.
cvillebimmer
Post by cvillebimmer »
It's the miracle clutch!
I've been considering dropping the e32 down from a 3.64 lsd to a 3.46 or 3.25 to get more out of first and second gears. Maybe it's just the extra weight of the e32 compared to the e28, but I can already tell there is no way I'm lighting up tires in 2nd or 3rd gear. The car stays firmly planted to the road and pulls like a train. That said, I haven't given my new TCD clutch any real exercise yet either. It's been about 500 miles now on the new block, so the car will get fresh oil this weekend. I need to put another 1,500 or so on it before I really start beating on it.
Scottinva
Post by Scottinva »
cvillebimmer wrote:It's the miracle clutch!
Road trip time, to come watch Peter and I autocross.
cvillebimmer
I'd love to go. Hit me up before the next event.
Sorry Brad, meant to PM, not clutter your thread...
No worries, I'll have some more tuning updates tonight. I popped off an IC hose this morning at 13psi...
The car is now fully tuned to 12psi, and it feels great. It feels really fast and pulls awesome on the freeway. The turbo is really starting to come into its efficiency island and hit very hard. The diff is definitely a welcome addition at this boost level. It still spins in second, but not as violently which means better acceleration. And the amazing thing.....the clutch is holding.... :haul:
Big Bronze Rim wrote:The car is now fully tuned to 12psi, and it feels great. It feels really fast and pulls awesome on the freeway. The turbo is really starting to come into its efficiency island and hit very hard. The diff is definitely a welcome addition at this boost level. It still spins in second, but not as violently which means better acceleration. And the amazing thing.....the clutch is holding.... :haul:
Have you put it through a fourth gear pull yet? If it'll handle that...
It held a full pull to redline through 4th.
George
Post by George »
Big Bronze Rim wrote:It held a full pull to redline through 4th.
~130mph?
I lifted at 6100 as I was running out of real estate and that was right about 130 indicated. It scoots. I can't imagine this thing at 17psi.
Got me :D .
Shadow
Post by Shadow »
Big Bronze Rim wrote:I lifted at 6100 as I was running out of real estate and that was right about 130 indicated. It scoots. I can't imagine this thing at 17psi.
Well imagine the fastest car on the road.
Now imagine you are driving that car. ;)
I like the sound of that.
FirstFives Dictator
Post by FirstFives Dictator »
Well done!
I would like to point out that I am able to run 0.030" gap with no spark blowout at 12psi running a MSD wasted spark setup. I know there have been people who have reported blowout at boost lower than this at this gap running the stock ignition system. Now I just need to track down a spare flywheel so I can have it machined so I can just install it when I do my clutch install.
Blowout isn't a biggie until you get up and over 1 bar. Might as well try for at least .030" at 12 psi.
cvillebimmer was getting spark blowout at something like 10psi, but he had other tuning issues, too.
turbodan wrote:Blowout isn't a biggie until you get up and over 1 bar. Might as well try for at least .030" at 12 psi.
It is at 0.030". I checked my records and that is what it's set at. Not sure why I was thinking 0.028".We shall see how it goes.
mooseheadm5 wrote:cvillebimmer was getting spark blowout at something like 10psi, but he had other tuning issues, too.
If you're running a stock gap I guess thats possible. Could be a lot of other things too.
cvillebimmer
I was blowing out spark at 9psi with a stock coil. I put in an MSD and no more blowout.
Soon after the switch to MSD, I discovered that I was one tooth retarded in my cam timing. I'm not well versed enough to provide an intelligent reason, but my hunch is that with proper cam timing and a stock coil I wouldn't have had blowout with the stock coil.
I dont remember the gap I was using at the time, but I was running over 20 psi with the stock coil back in '07. I want to say .025" but I dont think that would have been possible. I expected to be able to increase the plug gap with the MSD CDI, but I was disappointed to find I could go no larger than I was already with the stock components.
I came to the conclusion that the MSD may be able to produce more spark energy, but the stock ignition components weren't able to handle the higher voltage and would arc if you started to really push it. I'm still running the MSD because it takes the load off of the coil driver in MS, but I dont think I'd bother with it if I were to do it over again.
Blowout at 9 psi is pretty bad. I dont even think I had to gap down the plugs at that boost level. Something definitely wasn't right there.
bornagain
Post by bornagain »
i know this is kinda old but i was reading up...
Anyway my little story for over a month i was running bkr6e-11's with no blow out at 7.5 psi and gm wasted coil setup, and no blow out. I was running this til i realized i didnt grab -8's i had grabbed 11's and that is when i changed them after i realized that the -11 meant .040 gap not the .032 gap i thought i had grabbed. I almost want to put them back as the car was running stronger with the bigger gap. I just feared as they wore they would slowly degrade and then i would get spark blow out. or run too hot.
slow5
Post by slow5 »
your car looks awsome, its comin out good... im turboing mine and i was lookin for advice on fuel management
Re: a
slow5 wrote:your car looks awsome, its comin out good... im turboing mine and i was lookin for advice on fuel management
Thanks. If you haven't already I would read through the turbo FAQ and the Megasquirt FAQ. If you don't find answers to your specific questions, feel free to ask for clarification.
slow5
thanks
Post by slow5 »
also i was wondering how you ran the iacv, and i really like your collector piece yo made and was wondering if you would be interested in makin me one obviously if i paid you haha i just think yours came out awsome and i like the position that it puts the turbo....
e30-m30_kid89
Post by e30-m30_kid89 »
Sorry to bump this back up but I was wondering if you were still using the 42lb injectors @ 12-13psi and what does your duty cycle look like. I have a chance to get some 42lbers at a steal and I have a 13psi tial spring collecting dust on my shelf.. :banana:
bornagain
Post by bornagain »
do the math, we know your capable. haha i believe he is still using the 42lb'ers and running 8 - 10 psi. Still hasnt done his clutch last i heard.
Not that this is definitive or really helping but looking back on a previous data log the most i hit was 58% with 62lb'ers but with a 2.5 bar reg(makes them closer to 58lb'ers) and 10lbs of boost.
e30-m30_kid89
bornagain wrote:do the math, we know your capable. haha i believe he is still using the 42lb'ers and running 8 - 10 psi. Still hasnt done his clutch last i heard.
Nice, where did you get your injectors from? I'm tempted to just get a set of 55-63lb injectors from racetronix and be done with it, plus new parts are always a plus!
bornagain
Post by bornagain »
i got them through my friends shop and they are 62lb/hr high imp, and i think i paid about 60$ each but that was with a good deal.... and im in canada with you, so it was nice not to have to deal with shipping and duties and all that fun jazz. If you would like i can find out how much for a set and shipping and send some to you. Ohh and they are accel which are a seimens injector and are direct plug and play.
That is correct. My lazy butt (more like way too busy) still hasn't done the clutch yet but have been daily driving the car at 12 psi. I am almost at 80%DC on the 42lbers at 6400rpm. I am totally comfortable running them to over 90% which means I have a bit of headroom left in them. I could also raise the fuel pressure to gain a bit more flow. For now though they are supplying enough fuel to keep the party fun.
Scottinva
Post by Scottinva »
Vidoes or it didn't happen!
You're running severely rich on that log. You would do well to lean it out to 12.5:1. The engine would also be easier to tune with smaller injectors. If you weren't drowning it with fuel you'd be using less than half of those 62lb'ers. 42lb'ers would probably be better for you.
It also looks like you've got some enrichments kicking in under boost. Your PW and DC shouldn't have those dips. It'll be a lot smoother under boost if you get that worked out, and it'll be a lot less likely to suddenly detonate for no reason.
This is what you want everything to look like, nice and smooth:
Big Bronze Rim wrote:I could also raise the fuel pressure to gain a bit more flow. For now though they are supplying enough fuel to keep the party fun.
I prefer to run smaller injectors at a higher pressure than larger injectors at reduced pressure.
I agree. Higher pressure also yields better atomization as you already know, which is beneficial in several ways, compared to a lower pressure.
bornagain
Post by bornagain »
well the injectors were for the big picture which i have not gotten to just yet but am getting there. As for the enrichments, i was having alot of problems with noise in the wiring, that is why i have a brand new 12' foot diyautotune wiring harness with all new connectors. I have a few other plans, including new fuel pump and new regulator running atleast a 3 bar reg. And it is just richening up at the high end which i knew about but couldnt change as my friend had borrowed my tuning cable and i dont run the car that hard very often.
Scottinva
Post by Scottinva »
Proper grounding is such a major issue, i've especially encountered this with the Innovate lc-1 on multiple vehicles. Where the gauge and megasquirt would read differently due to ground issues.
