E28 Alpina B7 Turbo/1 #0083
skip535i
Post by skip535i »
No joke when you do it right! I admire the dedication, Chris. I hope one day you'll actually like the car :laugh:
Brian D
Post by Brian D »
Chris, let me know if you need help getting it moved. I'm off work until Friday.
Updates, man! Updates!
:D
Please? And Thank You.
Jake D
Post by Jake D »
That looks like fun wrapped up in a nice, snugly nightmare. Thanks for sharing your progress!
Keep up the good work. ;)
I guess I should give an update.
I got all four doors in Polaris from a local yard a couple miles from my house. They delivered them so I wouldn't have to put them in the touring (BTW, four doors, a trunklid and a tail panel will fit in an E34 touring - did that for the E12). I was happy they let me have everything in the doors too, as they'd usually pull the regulators, glass and latch mechanism, etc. Anyway, they showed up and I saw they didn't unplug the wiring and pull it through. Instead they just cut the harness. :( So, I spent a couple hours and completely stripped the doors:
Things were a go for Wednesday, November 7th. Tuesday night, I was ready to just let the car sit in my garage for another five years or whatever, but I had already paid $2,000, so I guess I had to go through with it. :roll: Mike's friend Mike came to pick the car up. We got it loaded on the trailer.
This sucks also because now I have to strip out the innards from the doors on the car once they come off, then run the wiring into the "new" doors before they can go onto the car. On top of that my nearly-endless searching and emails back and forth with people all over the world has netted absolutely nothing in the way of replacement rubber conduit for the wiring. :(
No shot of the car on it's way up as I was pushing helping the winch to put as little stress as possible on the front of the car.
I followed in the touring.
And we arrived at Flores Performance. Sorta.
The car came off the trailer and I pushed it into the bay on the far end of the shop. It was dicey for a moment since I pulled the fuel tanks, but I got him settled down once he realized how much more room he has at his new shop (an inoperable car would have been a nightmare at his old shop).
Here's the '55 Chevy he had just finished for a customer:
And here's a '64 Nova that he painted a while back that was there getting something done before the Good Guy's car show:
So, I made sure Mike had all of the parts, we went over a couple more things and then I left. He told me I was welcome to come by whenever I like - open door. He's not exactly close, but it's not a bad drive.
The following Thursday, I was working in Chandler and was able to break away from that to go to my guitar lesson in Gilbert, so I swung over to Mesa on the way to bring him the shims from the doors I brought as I left them in my cupholder when we delivered the car. To my surprise, work had already started:
This door had a couple spots of rust behind the seal, but lacked the hole that is in the door currently mounted to the car.
The reason I searched out Polaris doors was so I could avoid painting the door jambs. I wanted to avoid painting the door jambs since they looked nice and I also had a perfect tire pressure sticker:
To my surprise, Mike had determined that he didn't think the paint on the doors was nice enough inside - not a wear thing, rather he didn't think they looked that great from the factory, so he decided to prep them to paint the entire door, something I wasn't expecting. I was a bit surprised, but am still glad I got the Polaris doors, as the last thing I want under my new paint is a blue or Bronzit door. I picked up everything they took out of the doors, and I guess I'm supposed to clean it up and bring back the parts I want to use from either set of doors. I still forgot to give him the shims.
On the 21st, I stopped by again as I was again working in Chandler. I had to rebuild a shifter and reinstall a reman driveshaft for a friend in Tempe while he had lift access, before the shop next door closed for the long weekend, so I left work early. On my way, I swung by the shop to see my car and drop off a couple of critical pieces while I still had the touring.
He first showed me that they stripped the roof down to the sealer. He still needs to weld up the hole in the roof from the antenna that was mounted there. Obviously, this cannot be done until the windows are out and the headliner removed. They cut the seals back and the bit of bubbling under the left corner of the rear window was indeed a hole, as I had expected, so now we know that.
They had removed the front fenders. I wasn't expecting that.
He did it because we had to move the antenna back up front, where it was originally. When the car was painted last, they patched that hole and put one in the stock location in the rear. That's stupid since the spoiler would hit it if it was extended while opening the trunk. I had noticed a slight bit of dieback in a circle on top of the fender, so when I first pulled the inner fender liner while checking for rust, I saw the patch that was applied to the underside of the fender. He is going to remove the patch and put the hole right where it's supposed to be. Once I heard about all of this work, I was figuring I should have just gotten fenders too. Fortunately, they're not rusty. Tad bit of surface on the very bottom, but that's taken care of now.
Once I looked at the car, I was very happy he pulled the fenders.
Fortunately, right now, this is just surface. He's going to blast it and treat it. It's very common - something I've seen on lots of E12s, but unless the fenders are off, you can't see it until it's too late and this is pretty thick metal, too. Whew. Just one of those things I won't have to wonder about in the future!
Inner fenders look nice. All of this will be painted as well, which makes me feel better about not doing all the suspension and subframe work before paint.
Another shot of his M3 (please don't comment on the wheels - I only care about the quality of the paint):
Look what finally showed up (after I ordered it 16 months ago):
I showed it to Mike and I thought it looked pretty nice. He said he would make it straight. :up:
Mike told me that he has been getting several people who ask what is so special about the car. They cannot believe it when he tells them what it is and how many are in the US. He appears to understand how special the car is and while he says he cares about every job, it's nice to see him take an interest in it. I had shown the car to people who made reference to it simply as "an import" or another guy who said, "all I see is metal - I don't care what the car is." Him and the "I ain't hangin' no doors" guy were real award winners in this process.
I also decided that I could get a reproduction of the tire sticker made, as a photo of my sticker was used to make reproductions already. I contacted my contact who contacted his contact and I've got three on the way. I decided to ask Mike about doing the door jambs on the car as it would make for a better finished product. I've found before that what looks great now will look not-as-great once everything else looks amazing. He told me that he's not charging me extra to do the doors themselves. I said I really appreciate that. How much extra to do the jambs on the car? He told me and I said, "do it."
I was in a hurry and again forgot to give him the shims.
Thursday, I stopped by since I was out that way and I wanted to see what was going on.
When I showed up, I saw my front valance. Sweet.
It looked like this when I got the car:
Used Jon's picture as I think I had already pulled it out with my hand some as it looked like shit.
Anyway, now that Mike had the airdam, he straightened the valance out. You might be wondering..."a new valance is something like $270. Why didn't you just go with a new one?"
That's a super question. The reason is that Alpina modified the valance so that a charge pipe to the intercooler could run through it, in addition to the holes for the airdam (shown on the left side of the photo, right side of the valance). I figured since this one really isn't that bad, maybe it could be saved. I told him what a new one would cost and what we'd have to do to it and he said not to bother.
Now that he had the spoiler, he was able to make sure everything fit properly.
The hood and fender in the background go to the '67 Impala sitting there. They were a righteous mess when I saw them last week. Now they're practically perfectly straight. No reproduction sheetmetal for those cars, so Mike straightened that stuff out. Quite amazing.
Then I saw the car. Hmmm. Looks lighter.
He says he's blocked out the quarter on the left side, and much of the one on the right except for the damage, which still has to be fixed. Of course, I can't remember what numbers he told me for the paper, so I need to make sure as to the steps followed on the blocking of said quarters and what is still to be done. Most of the jambs have been prepped except for the drivers as he doesn't want to do anything until I have the sticker in my hand. I told him it's coming from the UK. Hope it gets here soon.
They cleaned out the channel where the trunk seal goes, so that's looking good now. Still haven't done the rear panel. The carpet is getting dirty. It will clean up fine, but really wish I could have removed it but the wastegate control valve prevented that.
And my hood showed up! Had to come from Germany, but it's here safe and looks great.
I made sure to hand him the stack of shims.
I'm still stressed out.
johnnye23
Post by johnnye23 »
That car is in good hands ! Looking fantastic Chris , please keep the pictures coming.
Thanks for the update. Lookin' nice. It seems you found the right shop.
It takes much less to stress me out. :(
L_N_Love
Post by L_N_Love »
Thanks for the update Chris! I am enjoying following this project.
:alright:
BMWJustin
Post by BMWJustin »
Great progress on an amazing project. I look forward to seeing updates.
Best
Justin
Dinan e28
Post by Dinan e28 »
It is nice to see some one who care's about his work that much. Its also cool that you saved the front valance.I'm excited to see the finished product.
bkbimmer
Post by bkbimmer »
Very cool, Chris.
austin8753
Post by austin8753 »
I'm loving the progress so far. It should look nothing short of fantastic when it's all done. That E30 M3 looks pretty rad, too.
Excited to see the end result, Chris!
Splondike
Post by Splondike »
Great work :D
Pedi
Post by Pedi »
You are lucky with the painters attitude. I wish Norwegian painters could have the same "good workmanship" attitude, but it is a long way between those guys here...
I assume you are gonna pull the front/rear windshield (only there due to transportation issues I guess).
But why did you not pull the engine, so that you could have a full respray?
Regarding the floor carpet, it is no problem to take the boost-adjuster knot off. The rest (read: the valve) remains in the tunnel, and you could pull the carpet out. I guess you have more problemos with the internal heat radiator box obove the carpet.
I am looking forward to see this car back in business.
hubble1953
nice progess!
Post by hubble1953 »
Chris: You have a great painter, wish I could find someone here that was that interested in 'import' cars:). Going to look so good. Did I miss what you are going to do with the suspension?
john
The windscreens are coming out of course. Right now, they're still in though the seals are cut back. They should be coming out sometime soon as there's some rust to fix.
I'm not pulling the engine. Easy for some people to spend my money. I don't have the facilities to do it all and don't want to open up another can of worms. This is an original car and I'm not doing a complete restoration. The paint is nice under the hood and there's no rust.
In addition to the boost controller, there are other brackets in the floor that go through the carpet and prevent it's removal. It's a nice carpet and it doesn't need replacing. I'd have preferred to remove it. I tried and it was apparent I was going to damage it, so I stopped.
The suspension is simply going to be refreshed. The subframes will be refinished and all new bushings and rubber bits installed.
That's a fantastic set of updates. Sure you are stresses, but are you excited yet? Looks like you found the right painter for sure.
gray635
Post by gray635 »
Chris:
This is very exciting. I know it's a lot of work but you'll be happy when it's finished and you can actually ENJOY the car. :banana:
This car certainly found the right home and I'm glad you finally bought one that was deserving of your time and talents - unlike those old strays you usually take in! :laugh:
Regards,
Mike
pldlnr
Post by pldlnr »
Thanks for sharing the updates, Chris. A painter convincing you to create more work for him is the guy you want painting your car. It looks like things are progressing nicely.
This thread is delicious.
Eddie in TO
Post by Eddie in TO »
shagrath wrote:This thread is delicious.
+1
yummy! :banana:
Looks like it's going well. Brings back memories of when I had my car done - I hope your checkbook isn't smoking as badly as mine was. ;)
Jelmer538i
Post by Jelmer538i »
Pics like this are nice to look at! Keep the pics coming!
RoyW
Post by RoyW »
Nice to see the progress Chris. I'm sure you're looking forward to getting the paint work completed and everything put back together. Keep up the excellent work :)
-RoW
GaAlpinaOwner
Post by GaAlpinaOwner »
To Roys point, congrats Chris...she will be sweet when finished.....great to see another one saved....keep the pics coming...
David
Post by unt0uchable »
Chris, this is awesome progress! Your painter really sounds like a through and through car guy, not just a body guy. I was glad to see when you decided to move forward with this and with everyone else, I'm enjoying all of the photo updates! Keep it coming. This is the kind of stuff that keeps ya comin back.
:popcorn:
Thanks. I'm stressed out.
Small update, no photos. Car doesn't look any different.
I picked up the four original doors on Saturday morning. I have to strip them down to get the wiring out to transfer to the new ones. Fortunately, I don't have to do it immediately since he's decided not to paint the jambs separate from the rest of the car. All removable panels will be painted off the car. When they're ready to go on, I'll run the wiring then.
Also received my reproduction tire pressure decal. It matches the original perfectly in size, shape and color. The text is sharper than the original. I'm disappointed we have to destroy the original decal, but it's the only way to do it right.
Right now, he's been working on other stuff, but he's just about ready to start the body repairs.
