Page 59 of 178
Posted: Jun 12, 2011 11:50 PM
Drove that bad boy some more.
Posted: Jun 12, 2011 11:52 PM
by mooseheadm5
Finally unpacked most of the stuff from Vintage. Still have a 265 gearbox in the trunk, though.
Posted: Jun 12, 2011 11:57 PM
Yesterday I finally got all the crap out of mine.
Now I can drive it like I stole it, again. :lol:
Posted: Jun 13, 2011 12:37 AM
by Gelatinous
Painted it with a roller and some Interlux marine paint..... still tacky 5 hours later..... Gonna be an interesting drive home.... Every bug I hit will stick lol
Posted: Jun 13, 2011 12:48 AM
by TSMacNeil
Drove the 533 around the block to make sure its' new odometer gears work, then put the cover over it again.
They do.
Posted: Jun 13, 2011 10:20 AM
by jdmoninger
Installed the Ireland Engineering Sway Bar kit on my '86 535i. FLAT cornering!
Posted: Jun 13, 2011 2:59 PM
by oldblackcar
Adjusted the valves on the M30 - .009 from the cam lobe. Installed a new reference sensor, BMW fuel line check valve, new rotor, fuel pump relay. Cleaned ICV. Replaced some old splice wiring on the the CTS. Put in new hood shocks.
Then I looked across the driveway at my beater 528e, shook my head and went inside..
Posted: Jun 13, 2011 7:36 PM
by Zach716
Replaced all valve eccentrics and adjusted to .012, new Sachs clutch, M5 flywheel, new sifter bushings, new/200k G260/6 and replaced other associated parts.
Posted: Jun 13, 2011 8:34 PM
by vinceg101
It's been a pretty busy couple of weeks and will continue leading up to 5erWest:
This is how you'll find the M535 pretty much every weekend:
Last weekend:
Finally finished restoring the stock Air Box as well as fixed a few body kit issues:
This weekend:
Replaced the Blower Fan (thanks to Mike in Seattle for the replacement).
Replaced the Fuel Injectors with Type III reman'd units:
Only to have to likely remove them to fix some sort of idle/fuel rich problem :brickwall:
During the weeknights, I've been working on prepping for the Audio System upgrade. Here's the new amp being fitted onto its' new mounting board:
Posted: Jun 13, 2011 8:48 PM
Looks really nice, Vince. Too clean.
Posted: Jun 13, 2011 8:53 PM
by slammin_e28
Learned how much I fucking hate hard brake lines. Up to, and including flaring, fittings, master cylinders, everyfuckingthing.
....and I think it's probably gonna leak like a siv and I'll be doing it all over again.
Also, I hate mosquitoes. If I was god I'd wipe them from the earth.
Posted: Jun 13, 2011 9:23 PM
by Franchise
small sub into the rear seat :banana:
Posted: Jun 15, 2011 1:32 AM
I drove it for the last time today. It's parked in a rather inconvenient spot, immobilized by the clutch master cylinder. I guess it's a sign. :bawl:
Posted: Jun 15, 2011 1:33 AM
by TSMacNeil
wkohler wrote:I drove it for the last time today. It's parked in a rather inconvenient spot, immobilized by the clutch master cylinder. I guess it's a sign. :bawl:
NOOOO.....!
Posted: Jun 15, 2011 1:39 AM
by mooseheadm5
slammin_e28 wrote: ....and I think it's probably gonna leak like a siv
Sieve.
Does it leak?
Posted: Jun 15, 2011 2:34 AM
by culpy
Gelatinous wrote:looked at the peeling paint and failing clearcoat and mulled over the possibility of rolling on some Interlux brightside marine paint
Im going to POR 15 my car
Posted: Jun 15, 2011 2:39 AM
Why? Is your car bare, rusty metal?
Posted: Jun 15, 2011 7:23 AM
by MicahO
Other than the swiss-cheese rear valance (winter project) the Chrome/Euro bumper conversion is done. Details, details....
Chrome door trims - check
Trim on the valance next to the fogs - check (only one screw?)
City lights wired up - check
Outer lights wired for lows/highs - check
New M5 Grille badge - check (mine sucked)
Still have to put the new wheelwell trims into the front. The old ones sucked, and it's dirty in that cavity. I'll clean that up this weekend, and get some fresh 'Complete' pictures.
Posted: Jun 15, 2011 8:19 AM
by slammin_e28
Sieve.
Does it leak?
Donno yet. I didn't have any brake fluid, and now I'm dealing with a faulty speedometer in the e30. Ugh....it never ends. On top of that, I have to get the e46's cooling system redone.... :roll: :brickwall:
Posted: Jun 15, 2011 8:24 AM
by rmiddendorf
Which one?
Posted: Jun 15, 2011 10:12 AM
Put insurance and new registration sticker on Snob.
Posted: Jun 15, 2011 11:01 AM
by Gelatinous
I only used primer on the hood and it was spray bomb primer at that.
one coat of Sea Green marine polyurethane applied with a 6" high density foam roller. No sanding or polishing or waxing.
Posted: Jun 15, 2011 8:26 PM
Safety inspection.
Promoted to DD effective tomorrow.
Posted: Jun 16, 2011 2:32 AM
1st 5er wrote:Safety inspection.
Looks like DD ain't gonna happen just yet.
Posted: Jun 16, 2011 4:07 AM
by Mr.ProjectCar535
My girlfriend came back from Disney world in FL, and came back with this for me. I'm definitely gonna be sporting it once the car is running!
Chad and I finished rebuilding my CV joints. They look so nice!
Also, finally got around to uploading the pics of my head after the rebuild.
The shop also left a note letting me know to adjust the valves before I fire it up. How thoughtful
Mmmmm, so clean you could eat off it! :laugh:
Posted: Jun 16, 2011 9:48 AM
by Das_Prachtstrasse
Mad a sub box out of an old suitcase. Added a center muffler to quiet'n things down a little, and discovered there's a large oil leak from either the rear main, or the back of the head gasket/head somewhere. Will worry about that in the morning..
Posted: Jun 16, 2011 11:57 PM
by SD45T-2
Adjusted the E brake :D
Posted: Jun 17, 2011 9:06 PM
Re-Tightened the headbolts to spec post rebuild. Also replaced the pressure sender seal, as it was pissing out oil everywhere. Installed LED interior lights, and gave it a good thrashing. Next on the list is tyres for the Hartge's, and then roadworthy.
Posted: Jun 17, 2011 11:33 PM
Got 'r done, DD status Monday.
Posted: Jun 18, 2011 4:20 AM
by CoyoteStarfish
3 pedal mod, blew some minds at my local BMW fixit shop. Too bad she still looks like a wreck. One step at a time I guess.. :roll:
