BMW 535i turbo -86
Re: BMW 535i turbo -86
finally =) m5 e34 -95 rear brakes
had some problems with the starter so i bought a new one from a m70
81618434_1838929136251537_3476499335728857088_n by Gunay selmanovski, on Flickr
82149119_699156327280180_7418253228589973504_n by Gunay selmanovski, on Flickr
81854004_853961295057696_2701512619340070912_n by Gunay selmanovski, on Flickr
81936488_2698226786937590_5517925651186712576_n by Gunay selmanovski, on Flickr
Please elaborate how you did the rear calipers.
You say E39 M5 is same calipers as E34, but not the carriers? So what combo carrier/caliper did you end up using on your set up?
I've been looking for the E34 rear carriers for ages while calipers collecting dust...
Jan E-28 wrote:Please elaborate how you did the rear calipers.
i found a set o rear -95 brakes in germany so i bought it right away
now my m5 e39 calipers goins to collecting dust also
the e90 335d carrier fit perfectly but like you said the guide pins is to much apartJan E-28 wrote:Please elaborate how you did the rear calipers.
82003742_306573513627501_6855082805907423232_n by Gunay selmanovski, on Flickr
also the brakepads are touching the discs
81535824_495378771145797_5398629605940658176_n by Gunay selmanovski, on Flickr
82059826_524499495085183_1095826915203219456_n by Gunay selmanovski, on Flickr
the left one is m5 e39 carrier
82987993_583590155538593_4188124568558239744_n by Gunay selmanovski, on Flickr
Re: BMW 535i turbo -86 *brake job*
But do the E39 caliper fit the E90 pins?
Wonder if that match could work on the 328x20 if you only found the right pads?
total restored ///M brakes =)
82016129_487058952192232_4872263883298963456_n by Gunay selmanovski, on Flickr
82921993_2650301475045965_8168391033730629632_n by Gunay selmanovski, on Flickr
perfection
82387416_776828816163176_3341002046777065472_n by Gunay selmanovski, on Flickr
82335340_2202936410012260_3891727870438932480_n by Gunay selmanovski, on Flickr
82551905_593128861262625_7144071759182954496_n by Gunay selmanovski, on Flickr
83264700_587847665098249_6963640505200541696_n by Gunay selmanovski, on Flickr
bought temporary wheels, RC090
82282303_165308811486050_621910534316359680_n by Gunay selmanovski, on Flickr
82291868_1702332529903654_4319218661333139456_n by Gunay selmanovski, on Flickr
so i took a small ride =)
87797892_878004705992893_4349961650690850816_n by Gunay selmanovski, on Flickr
87934050_837766163365548_7687310033213718528_n by Gunay selmanovski, on Flickr
88069613_492369068059515_4169664661681078272_n by Gunay selmanovski, on Flickr
bought a bit better tires for the futuras
Michelin pilot sport
87612565_2650986458360338_8342978542325202944_n by Gunay selmanovski, on Flickr
then i did a moonroof conversion =)
87902913_2260437944261010_3974795510060941312_n by Gunay selmanovski, on Flickr
brand new slides for the inner roof
87176257_568278530563137_6839539907673718784_n by Gunay selmanovski, on Flickr
video-1583009146 by Gunay selmanovski, on Flickr
"stock" =)
101702358_2628112397509872_5448806355945127936_n by Gunay selmanovski, on Flickr
102618292_282662766203356_7383048884903215104_n by Gunay selmanovski, on Flickr
pictures is 15 years apart =)
Untitled by Gunay selmanovski, on Flickr
102444092_320391225617023_7521151664846307250_n by Gunay selmanovski, on Flickr
Hi
My jaw dropped reading your build thread.
I also want to convert to a steering rack.
Any advise on doing it?
What exactly did you do you link the rack with the column? Could a double u-joint work in the engine bay?
What exactly did you do for tierods?
What clearance issues dit you have? The power steering lines on the rack itself?
What did you do for power steering lines (feed and return)? No issues with the power brakes?
sorry, everything is custom build so i dont have any measurementsZeurs wrote: Oct 11, 2020 10:14 AM Hi
the car have passed the inspection and registered with turbo so now the car is street legal with only 365hp
congrats.I kind of like the chromeline design.
i noticed that you flipped the position of the tierods and that you used spacers for that.
Are those off the shelve parts? i have seen vw beetle/golf tierod inserts or some made for jeep.
Are those the ones that you used?
Zeurs wrote: Nov 22, 2020 5:06 PM i noticed that you flipped the position of the tierods and that you used spacers for that.
i flipped the tierods so i can have less bumpsteer
and the spacers is for better steering geomitry
Whats happened to my car?
nothing
just decide to fit a bigger engine and bigger turbo =)
(yes i will repaint the block)
309339060_848791389453110_4959338588172334800_n by Gunay selmanovski, on Flickr
309056089_2002399349949588_4753122052125950376_n by Gunay selmanovski, on Flickr
309405825_767914817624768_6501107912118436909_n by Gunay selmanovski, on Flickr
309706962_1761572944211584_4119655827656989483_n by Gunay selmanovski, on Flickr
309585519_473360581490970_7701491176673736624_n (1) by Gunay selmanovski, on Flickr
308892432_1405319189995894_3011589127439340908_n by Gunay selmanovski, on Flickr
309544874_864092238294058_6186370271421786590_n by Gunay selmanovski, on Flickr
nothing
Wow that’s a serious upgrade
modify a m88 valvecover to fit on s38 head
272920768_1055910435050176_5608100256579640855_n by Gunay selmanovski, on Flickr
291630005_675508524136856_3616251443194176365_n by Gunay selmanovski, on Flickr
310317007_1483058552105788_7709273762864201590_n by Gunay selmanovski, on Flickr
Re: my monster BMW 535i turbo -86
M106 wrote: Nov 20, 2016 1:13 PMRHD e46 purple tagbkbimmer wrote:Very nice, what is the steering rack from?
I am trying to do this in my e28 that is RHD. I tried to follow your working but I got lost (new to this). What inner arms, are you using? What was the most labour intensive?
Nice Car
