MyE28 How Has a Built-In Photo Uploader
When posting, note the "Uploader" tab below the editor. Use it to upload photos, copy the BBCodes that link to said photos to the clipboard, and paste them into the editor.
See this thread for more details.
Yah, thats how the Rat's bad parts mostly come apart. I keep the most horrific in a well in right side of the dash. Latest new part is a 12$ center support bearing. Chinese, but with a Spicer bearing molded in.We shall see . I had the old one out when I did the clutch in '12. I'm not expecting too much grief. The Rat shares several of the E 28 stuff. It has a 4.0 Cologne V6 that would give a 535i a run in a straight line. The 4.0 push rod 6 is banked at 60. If I have the story right 60' is equivalent to an in line. The efi is Bosch and uses a MAF. I grok it . Even better, the engine runs great. Or at least, it has so far. :laugh:
I replaced the worn control arms, tie rods and sway links in the front of the 130i with Lemforder. Wasn't a bad job, had it done in an hour and a bit on the garage floor. Next up is the rear end, and then thrash time.
SPF2006
Post by SPF2006 »
Figured out how to get the X3 home (with family aboard) with only third and fifth gears available after something failed in the shifter linkage assembly (I suspect a plastic bushing or connector just fell apart).
Actually I shouldn't complain as this is the only thing, aside from preventive maintenance (cooling system rebuild, etc.), we've had to do to the vehicle since buying it ~3 years ago with 100K on the clock. And the six speed gear box is the nicest I personally have ever used. Second vehicle this failure has happened to, though.
Finally got the Rat's rear shaft back in with a new CSB The 2 joints , I had to mess with were in fine shape. It was just a matter of 10 bolts The new bearing and carrier took a beating during install, but the final result is a big improvement. I chirped 2nd gear and it no longer beats on the floor. :laugh:
a wrote:...and it no longer beats on the floor. :laugh:
And here I thought it was only BMWs that did that. :laugh: Speaking of, my E36 needs attention on that score and soon. At 210K the ultimate commute machine is starting to need a little attention.
Pulled the Galaxie ('59) out of storage and cleaned it up to drive to an 80's Prom Party. Yeah - big nerds. And yeah, it's a 50's car driving to an 80's party, but it's the car Jen drove through high school, so it fit her mood.
Anyhow, the inspection is expired and one turn signal bulb is bad, and the damn power steering belt is squealing like a pig. I replaced the bulb so it will pass inspection. Belt looked like hell so I got a new one, but it still squealed. Look in the PS reservoir and the fluid is a little low, really dirty, and quite frothy. Aidan and I swapped 2 quarts in, one half-quart at a time and the pump stopped fighting the belt.
Once again, the primary noise from the car comes from the Smithy's. Sweet.
yodman
Post by yodman »
Picked up this Beetle Turbo DSG to accompany my Golf SportWagen as a daily for the girlfriend. Traded up from a Dodge Dart GT. Saved money on the loan. Made us both happy. She's a 'Bug nut, and next we will get an aircooled.
Post by slammin_e28 »
I got some Depos for the 318ti. Muhgawd it's nice to be able to see at night.
....and I've found my next car.
That's all for now.
SPF2006
Post by SPF2006 »
slammin_e28 wrote:I got some Depos for the 318ti. Muhgawd it's nice to be able to see at night.
That's all for now.
I need to get around to doing same on ours, it's pretty dim.
yodman wrote:Picked up this Beetle Turbo DSG to accompany my Golf SportWagen as a daily for the girlfriend. Traded up from a Dodge Dart GT. Saved money on the loan. Made us both happy. She's a 'Bug nut, and next we will get an aircooled.
As someone who was waaaaay into aircooled VWs once upon a time, I'd love to drive one again. I was even thinking about just today. I don't think I'd want to own one, and really wouldn't want to daily one, but I'd love to take a drive in one again to see if it was like I remembered. :D
That's all for now.
Yeah, aren't E36 headlights great? :brickwall: I just threw in some +100 bulbs in mine but I still need to buff the lenses again then clearcoat them. Ever wish you could just remove the individual high and low beams and install brand new H1/H4s in say a standard size, like maybe 5.75. For cheap. What a concept, I wonder if we'll ever see it. :roll:
And BTW, your pics don't work for me, all I get is the word image.
Hopefully that fixed the pics....had them in a private gallery :/
Hooked up the city lights last night.
I liiiike it.
Also got a 5sp ZHP shift knob because the plastic thing in there was horrible.
That's all for now. Tomorrow I pick up the new car. ;) :cool:
Gelatinous
Post by Gelatinous »
I've been tracing the circuit on my intellitronix universal digital dash since the speedometer input failed. I think the input conditioning circuit bit the dust. Also found out the hard way that digikey.com is not flat rate shipping, nor is it next day delivery like digikey.ca... I'm going to miss that now that I'm in the US,
John in VA
Post by John in VA »
Mike W. wrote:Yeah, aren't E36 headlights great? :brickwall:
Have you considered Euro units with glass lenses?
No, for one thing they're expensive and I'm cheap. Mine are actually fairly easy to buff out, which does make a difference, but even if I had new ones I doubt they would match the budget 5.75 sealed beam H1/H4 replacements from Classic Garage. Plus the plan is to sell it in the not too distant future. Not that everything always goes according to plan, but that's another story. :laugh:
I located a used M 20 timing belt tensioner. It is going to get re-purposed as a tensioner for the Rat's front E-brake cable. :cool:
Not my car, but yesterday one of the wife's friends stopped by for a visit (brought me a bottle of neue wine as a belated b-day gift!) and discovered she had a very flat tire when she was leaving. She's driving a leased Ford something-or-other station wagon-type car; I offered to help fix it, but found that there's no spare tire, just a Continental Tire ContiMobility Kit, which is essentially a little compressor with a bottle of sealant that attaches to it to get a flat temporarily sealed & reinflated.
Unfortunately, the flat was due to her hitting a curb that left a nice 1/2" gash next to the bead; an oncoming car on a narrow street squeezed her over far enough to hit the curb. It's possible to just roll over most curbs around here, but she was lucky(?) and found one of the few that bite when you hit them! The gash was big enough that the sealant couldn't do the job, and air came out as fast as the pump pushed it in, so she had to let the car sit until the lease company could send someone over to fit a spare on the thing. Makes me appreciative of the full-size spares in the BMWs.
Rocked down to Electric Avenue...
And then I took it higher...
And then I took in for its smog test.
Karl Grau wrote: And then I took in for its smog test.
And... and did it pass? :cool: Actually the state has revised things once again so on 2000+ cars, they pretty much pass if the check engine light isn't on since all they do is plug into the OBDII port.
Still it pissed me off last time I was in with the old wagon, I'm ready to pay and asking if it passed or not and nobody even knew. :evil: I know they may not have a whole lot of emotional investment in me, but maybe fake it a little bit? I mean I was a customer there for a reason. Last time there I guess.
Gelatinous
I've been driving the Samurai for most of the week. Have had to drive the wife to work since she buggered her car up good.
She smacked a curb, flattened two tires and bent a wheel. Also bent the tie rod & end. At this point I discovered the wheel bearing is also going.
Ended up replacing 3 tires and two wheels so that she's have matching on each axle and a spare finally.
It's going to need both wheel bearings, both tie rods (&ends) and an alignment now. I wish this was stuff I could do, but it's too big of a job for to be allowed in the apartment complex parking lot. I also need to pick up special tools to remove the inner tie rod from the steering rack if I want to do it. Which I don't really right now as the weather is very crummy here in Everett (stupid typhoon remnants).
djazz
Post by djazz »
Ummm, so what do I do now?
Snapped doing front brakes on the truck- 21mm caliper bracket bolt using 3ft cheaper pipe.
djazz
Post by djazz »
Step two- Fail. Time for new sockets.
That's odd, I've never seen a flex handle break there. You must have had the cheater too close to the end, otherwise it would have broken at the pivot point like I've broken them. :roll: In an earlier, poorer era I've been known to weld broken sockets. :laugh: So that's always an option, but an impact would probably be a better one.
djazz
Post by djazz »
Surprised me too. The pipe was up close to the socket but not all the way up. Now the bolt is rounded so I'm heading out to find something that will hold better.
The bar is from Great Neck and the socket is from Gearhead.
41magfan
Post by 41magfan »
trans service on the 2015 Silverado (63k miles ) typical pain in the butt AT service even on a lift. Then changed the oil in Dad's lawn tractor
Rwhockey29
Post by Rwhockey29 »
change the oil in this bad boy:
225,000 miles and still going strong. also been working on some drawers for the rear of it:
Power window issues on the E36, the cool roll it down half an inch to let the frameless window door close, then roll it back up takes it's toll. Bimmerforums best and brightest assured me it was the regulator. Turned out to be the motor, or part of the drive mechanism inside it which I was able to scavenge from the motor I replaced because it didn't work due to the auto up/down function failing. So a cheap, no cost repair at least. Plus an oil change and tire rotation.
Still needs a vanos rebuild to restore missing MPG and pep, plus a driveshaft before it bangs itself thru the floor. Surprisingly at $.046 a mile for M and R it's just a tick higher than the 00 E39 was. Still, cheap to run either one.
Lined 'em up prepping for TexFest departure.
foamy
Post by foamy »
did some work tot he grandmothers van fixed some of the shades in the back got the tv working again replaced a few bulbs repaired the electric bed and got the vent selector working again.
