Well, it may have been since before this thread was started in '09 that I regularly drove my E28, but I actually did something, I guess I'll add to it.
Over the past couple of weeks I've disassembled the suspension to send the Bilsteins off to be rebuilt and taken the strut housings to a welding shop to get the sway bar brackets welded up and boxed in (one had ripped apart from the stiff swaybar).
Today I ordered tires from Tire Rack, put Zymol conditioner on the leather, replaced the front lower control arms (easy when the suspension is already apart), finished installing the new silicone coupling between the turbo and intercooler (old one actually had a hole in it), found a nasty fuel leak in the vicinity of the cold start injector which disappeared when I took things apart to find it , replaced a broken vacuum hose, and installed a fuel pressure gauge.
Not 10 minutes ago I finished installing the hubcentric rings and FINALLY got the 16" style 29s mounted. They look damned good , I'm very happy. Also I went ahead and tightened the steering box lash by 1/8th of a turn. It already feels much better, I will update the other thread with road results.
Those two simple things really felt like a pit stop more than anything, it took all of 30 minutes from wheels up to wheels down. I think it may be down to the fact that EVERYTHING is easier with air tools. I don't think I'm even going to take a leak without bringing my impact to do up my fly.
worked on it all day.
Got the driver's Monaco in. With FOUR bolts, not two, catty-corner...
Rotated tires. Fronts are thrashed. I've got about 2 thousand miles to figure out what the hell is going on and fix it before I have to buy new tires.
Checked brakes, got rid of the rake, and actually put some thought into the lowering. She's lower and level now.
Installed the rear strut brace. Man, I can actually FEEL the ass now!
Adjusted the throttle cable, and pulled the AC compressor, FINALLY.
Bought some VR1 today.
Next week, I'm out of town, and will rebuild my crap Euro console, since I just got my euro lighter panel and 'bin' from Blunt so quickly. I have to re-carpet it, and build a new storage section.
I added more duct tape (black at least) to the hose that is getting worn by the fan under hard acceleration. I usually get a month or two out of each application. While the tape was out, I repaired my sport seat bolsters and even corrected that "brake liner" light that has been plaguing me since last October. It's now covered really, really well.
Power steering pump was leaking but all is well now. I snipped the belt and we no longer leave a trail around town.
Don't judge. . .you've done worse.
Duct tape? Try something like this... http://www.rescuetape.com/ It's tougher, and doesn't leave sticky crap behind when you go to replace it.oldskool wrote:I added more duct tape (black at least) to the hose that is getting worn by the fan under hard acceleration. I usually get a month or two out of each application...
Those can be jumped. Just twist the two wires together at the hub.oldskool wrote:I added more duct tape (black at least) to the hose that is getting worn by the fan under hard acceleration. I usually get a month or two out of each application. While the tape was out, I repaired my sport seat bolsters and even corrected that "brake liner" light that has been plaguing me since last October. It's now covered really, really well.
I like this one.davintosh wrote:Duct tape? Try something like this... http://www.rescuetape.com/ It's tougher, and doesn't leave sticky crap behind when you go to replace it.oldskool wrote:I added more duct tape (black at least) to the hose that is getting worn by the fan under hard acceleration. I usually get a month or two out of each application...
I wonder if it could also be used as temporary solder in an ecu?• Use it as an emergency fan belt!
The DC93 officially became my daily driver today.
Replaced the front and rear sway bar links, rear sway bar bushings. Can't make up my mind on the best UCAB bushing solution, I really want the precision of Moosehead UCAB's. Found out my driver's side output shaft seal started to leak and the driveshaft u-joints have too much play-ordered BMW parts for diff reseal and driveshaft. Holy crap the M5 diff mount is $248! Is 535i mount just as good?
Finally got my range display calibrated correctly, 4.5l >light on.
Washed, vacuumed, Rain-x'd the glass, and gave her the first coat of wax since buying her. Paint still looks good for a 4/87 year old car! A long list remains.... Woohoo!
Re: The DC93 officially became my daily driver today.
Is this the correct part number, 33 17 1 130 900?S38Mike wrote:Holy crap the M5 diff mount is $248! Is 535i mount just as good?
Email Steve@Blunttech.comS38Mike wrote:Holy crap the M5 diff mount is $248! Is 535i mount just as good?
diff mount
Will do, thanks. Yes that is the correct number, BTW.
- Location: Everett, WA -- previously Victoria BC, Canada
Middle-son was complaining that after starting the car the brake warning light wasn't going out when he pressed the brake pedal, so we went out to check things out. Sure enough the right-side brake light wasn't lighting when the brake pedal was pressed. The warning system does serve a purpose!
I twisted the bulb socket around a little, and voilà, it was working again. But it tells me that I need to go in again and clean up the contacts a bit better.
So, yeah, the system does seem to serve a purpose, but did it get him to actually look at the light hisself or did he just tell you that the check light wasn't going out? Honestly sounds like something he could have tackled if he's driving the car.davintosh wrote:Middle-son was complaining that after starting the car the brake warning light wasn't going out when he pressed the brake pedal, so we went out to check things out. Sure enough the right-side brake light wasn't lighting when the brake pedal was pressed. The warning system does serve a purpose!
Just sayin'.
