OEM Windshields Now Available Through BMW
Re: OEM Windshields Now Available Through BMW
Wow, not a great way to start the day. Was it the original windshield?
Not sure. It's BMW glass but I have no idea if it's the original.
Update 2/28/24:
-I just called a Vancouver BC dealer and they say there are no OEM windshields in the system in Canada or in Germany. (I know a few pages back there was a recommendation to call Canada.)
-I also called one Washington and one California dealer and they said there were none available either.
-I called EuroGlass in Redmond, WA (they did a Sekurit for my E39 M5) and they have access to Pilkington and Fuyao windshields. They will get me a quote this week (apparently, they were already prepping a quote for another E28 M5 right now?!?!?).
FinSport
FinSport
Good news as I need new one as well.FinSport wrote: Feb 28, 2024 7:51 PM Update 2/28/24:
FinSport
Is the consensus Fuyao is the best available glass.
Is the e28 M5 glass more expensive? Is that a thing? Just curious.
Fuyao isn't bad. Pilkington is better if available but that's probably the rub.
Pilkington is known to not fit right. Top corner radius is too loose and as a result leaks can happen.turbodan wrote: Feb 28, 2024 11:38 PM Fuyao isn't bad. Pilkington is better if available but that's probably the rub.
If you have to go Pilkington, add some extra material between the glass and the gasket (we used some ~10ga insulated wire).
My last OE glass fit exactly the same way. Brand-new in a box with brand-new gasket. I was working at a dealership at the time and hand-carried it from our parts-department to the body-shop that was painting my 535is. This is not the first time. I've noticed it since the E12 days.cek wrote: Feb 29, 2024 4:39 PMPilkington is known to not fit right. Top corner radius is too loose and as a result leaks can happen.turbodan wrote: Feb 28, 2024 11:38 PM Fuyao isn't bad. Pilkington is better if available but that's probably the rub.
You don't think Pilkington copied the exact dimensions before starting production? They are, after all, an OEM for BMW. Maybe BMW got it wrong decades ago and has been passing it along ever since?
I think the gasket may be a factor too. The new gaskets from BMW aren't formed right and the upper corners are the main problem area. Or at least that was the case with mine. When I installed my new BMW windshield a couple years ago, I used a new gasket and really had to fight it to keep the corners from coming up short and leaving a gap. It's like there's a forward curl permanently formed into the material that wants to keep it from laying nicely over the corner. Even now, when I replace the locking strips I have to force them into the corners to spread the gasket over the gap -- and this is with the St. Gobains glass. The original gasket was formed perfectly and if I had it to over again I would have reused it. IMO the mantra when doing a windshield replacement should be to save the metal trim strip and save the original gasket. Because the new BMW replacements are awful.
Reading through all of your experiences is terrifying me! I have a new OEM windshield with new gaskets scheduled to go in Monday by an installer the shop that's painted my car has used for eons. I plan to be there to watch the install. Do you all recommend I just sit back and be quiet, or would offering tidbits of advice that you have shared here be a better approach?
My installer took hours - said it takes patience. I agree. Don't hover. Offer a soda? Or perhaps, a daughter? YMMV.
Good luck,
John McA
Good luck,
John McA
I wouldn't recommend any kind of nagging. Hope for the best, it is what it is.Mdreamer wrote: Mar 02, 2024 9:52 PM Reading through all of your experiences is terrifying me! I have a new OEM windshield with new gaskets scheduled to go in Monday by an installer the shop that's painted my car has used for eons. I plan to be there to watch the install. Do you all recommend I just sit back and be quiet, or would offering tidbits of advice that you have shared here be a better approach?
You're in a difficult position. Nobody that knows what they're doing, or even thinks they know what they're doing, wants to be told what to do. IMO it's an invitation to disaster to hover. Maybe at most say something about, "I hear these are a pain to install and clean up all the goo afterwards" but even that is treading on thin water. However, you can always go in after them and squeeze in the 3M sealant and it should be just fine. See if there's a gap that looks empty, get the 3M sealant if necessary and go in a few days later. Pull the lockstrip if you really want to do it right, and be prepared to do a messy cleanup later. I'm speaking specifically of that pass upper corner, hopefully they're good enough that you don't have to worry about the rest of it.Mdreamer wrote: Mar 02, 2024 9:52 PM Reading through all of your experiences is terrifying me! I have a new OEM windshield with new gaskets scheduled to go in Monday by an installer the shop that's painted my car has used for eons. I plan to be there to watch the install. Do you all recommend I just sit back and be quiet, or would offering tidbits of advice that you have shared here be a better approach?
Nothing says you can't add sealant to the whole thing, but hopefully that won't be necessary.
I dont know why people make such a fuss over this. The whole process is very simple and only takes a few minutes.
1. fit the the lower trim piece to the rubber seal.
2. fit the rubber seal and lower trim to the windscreen
2. insert a 1/8" diameter cord into the rubber seal lip. Start on a side near the top corner, continue all the way round the screen, ovelapping the cord past the original starting point and finish on the opossite side near the top corner.
3. lift the screen and lay it in position against the body work flange.
4. pull the cord down one side, but stop before the corner.
5. pull the cord down the other side and around the corner to about halfway
6. back to the oiginal side, pull the sting round the corner, across the bottom, up the side, across the top, down the side and meet up with the other end of the string.
7. Job done.
The important thing to note is that you start at the sides, which holds the whole thing in place.
You will need to lubricate using washing up liquid and water in a spray bottle.
7. Job done.
Thanks for the clear instructions.JohnH wrote: Mar 03, 2024 8:15 AM I dont know why people make such a fuss over this. The whole process is very simple and only takes a few minutes.
7. Job done.
Pretty rude of you to assume everyone else is as smart, skilled, or capable as you though.
I've done it 4+ times now and it's never been that easy.
Without wishing to rude, that dosent show you in a particularly good light
I originally had a shop do the install on my windshield because I figured it was best to let the pros handle it. They used the rope method and ended up breaking it (a true heartbreaker since I had gone to great lengths to source OEM glass from Schmiedmann in Denmark). To cut a long story very short, I wound up doing the install myself using the tedious non-rope method. I considered roping it in but was wary based on the failure of the first install. Plus it seemed like it had the potential to snag the headliner along the upper edge and get it bunched up under the gasket. So I opted to do it the other way where you install the gasket first and then finagle the glass into the gasket with a bone tool. I practiced it once by installing the old original windshield (which the shop had been able to remove intact) to make sure I had the procedure down. Then a few weeks later when the new BMW glass arrived, I repeated the install. Both times it was a PITA in the upper corners but do-able with some effort. I do think it would have been easier with a cooperative gasket (i.e. the original). I will add that before I did the install I spoke with three different "old school" glass guys around town to get any tips they might have, and all three recommended the non-rope method.
would you mind posting a step by step non-rope procedure you followed for those of us that have never attempted it before?
It's been four years and I can't remember all the details, but here's a video that I found helpful. It shows the whole process in time lapse:
https://www.youtube.com/watch?v=fWx2FH7hWUw
I would suggest using a spray bottle with slightly soapy water to help lubricate things. Use the soapy water liberally. It really helps the glass slide against the gasket.
You'll also want to use 3M non-hardening sealer in the gasket. There seems to be some debate over where exactly to put it. I put a thick bead in the bottom groove where the glass fits in before installing the glass. Then with the glass in place I squeezed some under the gasket down the sides. I didn't put any along the top or between the gasket and the body, only between the gasket and the glass, and I've had no leaks (that I'm aware of). When I did my practice installation I didn't use any sealer and it did leak.
The main thing is to go slow and don't force anything. There's definitely some technique involved but you just have to do it and get a feel for it. By the time you're done you'll be good at it.
Some people recommend pre-installing the metal trim strip along the base of the windshield before installing the glass. That's probably good advice. I didn't do it that way but it was definitely fiddly to install it afterwards.
Heres the official method from the blue book;
Straightforward, simple and fast. No strain is put on the glass.
You have to ask yourself, how did they do it on the production line. It had to be quick with no breakages.
The offical method is probably for two people doing it, which does make it really easy.
The last two times I did it, I was by my self and it wasnt that bad. The only harder bit is lifting the glass and laying it in the bodywork opening. Now sitting in the car, press the glass gently with a foot long piece of wood to spread the load along the side edge, and pull the string with your other hand. follow the procedure I outlined above. You may need to place some spacers at the bottom of the screen to stop it sliding down.
These are the only tools I used during the whole process;
The next step is to use sealant.
Take the tube of sealant and cut a small bit off the end of the nozzle. You only need a small hole for step one, which is to squeeze the sealant between the glass and the seal, next, step two, cut a little bit more off the end to make a slightly larger hole and squeeze it all around between the seal and bodywork. Be very generous on the top corners and across the bottom.
The final step is to fit the locking strip, make sure that you force the strip into the top corners as you insert the strip.
Thanks for taking the time to post.
About to embark on this myself. What are y’all using to clean old sealant?JohnH wrote: Mar 04, 2024 12:29 AM Heres the official method from the blue book;
Thanks for posting this. About to embark on this myself. What do you use to clean old sealant off? 3m adhesive remover?
"What do you use to clean old sealant off? 3m adhesive remover?"
To be honest, I cant remember, but I would have been IPA or White Spirit as I have a lot of that knocking about. I did use the white "tool" shown in the picture above to pick away at it. It can take some time to do and I can understand an old professional preferring to use a new gasket, rather than spend the time as it would have been cheaper overall.
You are also going to use it to clean off the excess new sealant. Test it on a hidden bit of paint work to make sure it dosent attack the paint/clear coat.
The good thing about spending a bit of time cleaning the old seal, is that you exercise it a bit which helps to soften it up.
Edit: I did use more than half a tube of sealant, so there is a bit of excess to clean off.
I used 3M adhesive remover to clean off excess sealant.
Speaking of sealant, the 3M 08509 Glazing and Bedding Compound is coming up as unavailable on Amazon and out of stock at NAPA and Autozone. Looks like it might trickier to source than it used to be.
I believe the kids refer to this as... the shit! Of course there are less costly sources than this...
https://www.wurthusa.com/Chemical-Prod ... p/08909381
I highly recommend it. It is precisely what you want to clean the paint without the possibility of damaging it. I am not a Wurth salesman nor do I benefit financially from this recommendation...
garageboy wrote: Mar 06, 2024 5:44 PM I believe the kids refer to this as... the shit! Of course there are less costly sources than this...
Some googling lead me to some muscle car forums and found people had success with this https://www.amazon.com/C-R-Laurence-CRL ... B000KZWKE4. The description reads as the same purpose. Non curing. I ordered it with some 3m auto adhesive remover as well. Ordered a Fuyao windshield locally tooHayekFan wrote: Mar 06, 2024 1:02 PM I used 3M adhesive remover to clean off excess sealant.
That does look like the right kind of stuff. Good to know it's available.
Nobody says that anymore. The kids refer to it as...sick. Or SICK! if it's really good.
