Page 8 of 15
Posted: Feb 27, 2012 4:39 PM
by DieselBoost
im getting pissed of with my ve6
I want more lift to cam plate with less steeper profile... cummins plate is too steep for idi engine...
there is two different cam plates for bmw
mechanical ip has 1.8mm lift
electrical ip has 2.0mm lift
vw d24 engine has 2.2mm lift in ip
but i wan more more more....
and im considering rocken-tech 14mm rotorhead for bad day...
Yeah hell! ladies & gentlemen lets blow our engines!!!
Posted: Feb 28, 2012 3:40 AM
by Alleslowbuged
Hi,
i fully agree, the DI camplates are to steep for IDI engines, at least if you realy goes for high rpm. In my AAZ i have destroyed 2 sets of nozzle with a 10er piston, before i came to that conclusion.
In an AAZ they only could used with a 9er piston, which is equal to 12er piston and idi camplate.
For the M21 in my mind a TDS camplate with a 2.1 mm lift and a 12er piston should be captable enough, but 2.2. should be even better.
Are you sure about the 1.8 mm for the stock camplate, i thought it was only 1.5 mm.
Best Regard
Posted: Feb 28, 2012 3:46 AM
by Alleslowbuged
Hi,
here is a pic with the internals from the Iveco pump, where my 12er piston is from. You can see the camplate which was installed there. I thought a moment for using it , but was not brave enough for put it in.
Best regards
Posted: Feb 28, 2012 2:25 PM
by DieselBoost
actually i got new information.... this may change everything about my engine performance...
Posted: Feb 28, 2012 4:09 PM
by Alleslowbuged
sound good, what are the news?
Posted: Feb 28, 2012 4:16 PM
by DieselBoost
is iveco direct injected... and how much cam plate has lift...
what comes to my new information... im not allowed to speak about it... not yet...
Posted: Mar 02, 2012 2:07 PM
by Alleslowbuged
Hi,
did you not build your engine by yourselves, that somebody forbit you to speak about?
Regard the Iveco pump, honestly i did not have any informations. I have bought the pump at ebay just because of that magical "2" in the part number.
The pressure retention valves was very courios and had have some type of additionally non return valve with, so together with the very high lift cameplate i would assume that it was for DI engine. I can not remeber what was the camplate lift in detail but think it was something between 3.5 and 4.0 mm
Best Regards
Alleslowbuged
Posted: Mar 02, 2012 3:53 PM
by DieselBoost
my engines are built by me... but we have some secrets about perfomance... and these guys who are invented these specialties do not want that everyone knows about their mods
it is like in racing....
Posted: Mar 14, 2012 5:40 PM
by DieselBoost
Holy shit my new starter arrived... tomorrow we will see some soot clouds
usually we burn head gaskets from my car.... this time it seems that author burned his own head gasket...
maybe time for little break down
im building two cars at the same time...
Posted: Mar 23, 2012 11:03 PM
by DieselBoost
Ok my friend described my work as wrestle of the jacob
3 days with one fu**ing starter...
now i has hybrid starter with frame and stator from diesel 2.2kw starter + planetary gear.... but bendix etc is from 1.1kw gasoline engine... it has little bit smaller clutch and gear wheel... so it work fine with 240mm gasoline engine flywheel...
but the best news are that my 524td started today... and it runs very good... attlast
Posted: Mar 25, 2012 7:26 AM
by Alleslowbuged
Hi,
why are you running a gasoline flywheel and can your clutch handle the torque. I have the E39 525TDS Ø240mm flywheel (two masses) and clutch, which is a plug and play swap, but the clutch is not captable for my torque figures. Did you have stock Ø240 mm clutch ore some heavy duty parts?
Good work, that you engine is running again.
Best Regards
Alleslowbuged
Posted: Mar 25, 2012 4:42 PM
by DieselBoost
Alleslowbuged wrote:Hi,
Best Regards
Alleslowbuged
I has 240mm solid flywheel from e28 528i with 240mm sachs racing m5 setup + stock plate.... it is very stiff setup... it can easily take 500nm
my friend has that 228mm m3 setup with stock plate and still no clutch problems...
Posted: Mar 25, 2012 10:40 PM
by DieselBoost
i booked up my car for bmw club finnland dyno day
so soon we can see what my car does...
second thought... why the fuck im awake in this time... clock is something about 5.37 in the morning... im going to work at 9.00
okay... i slept whole yesterday and i woke up at 22.30 in evening
Posted: Mar 26, 2012 2:18 PM
by Alleslowbuged
DieselBoost wrote:i booked up my car for bmw club finnland dyno day
Posted: Mar 27, 2012 8:42 AM
by DieselBoost
I has new video of starting of my 524td
Still little bit air problems in fuel... caused old fuel filter hand pump...
valve clearances are not adjusted precisely... so some sound can be heard...
http://youtu.be/EE9HWfufOYc
Posted: Mar 28, 2012 5:53 PM
by DieselBoost
so... this is real money wasting... so stupid... this people doesnt know how much value parts of that engine has...
http://www.youtube.com/watch?v=cP7p90BsHEg
Posted: Mar 29, 2012 5:02 AM
by CoyoteStarfish
That is awful. But I'm very surprised at how long the engine survived the torture.
Posted: Mar 29, 2012 8:02 AM
by Frybrid 524td
Wow. What a fucking shithead.
Posted: Mar 30, 2012 1:01 AM
by winfred
not the first one i have seen in a snuff film
Posted: Mar 31, 2012 11:29 AM
by DieselBoost
First short driving test completed at last night... without turbo
Today tasks...
-Fitting for the downpipe
-Valve clearances
-head stud retightening
-some electrical problems solving
Posted: Apr 01, 2012 12:47 AM
by DieselBoost
ok...
Valve clearances checked and studs tightened + valve cover sealed...
only job for engine is boostpipe for my turbo...
after that other tasks...
-changing springs
-refurbishing brakes
-one small welding
-few electrical issues
Posted: Apr 15, 2012 9:33 AM
by Alleslowbuged
nothing new?
Posted: Apr 15, 2012 6:03 PM
by DieselBoost
Alleslowbuged wrote:nothing new?
Yes...
12mm 12.9 studs...
brakes & springs done...
still few electrical issues...
last week i had other stuff to make so next week i will continue my car...
Posted: Apr 24, 2012 1:27 PM
by Alleslowbuged
I have broke my headgasket last week and send you a PM, would be nice if could answer me as soon as possible.
Best Regards
Alleslowbuged
Posted: Apr 25, 2012 4:41 PM
by DieselBoost
Argh... dyno day is closing 19.5
still manhole in floor
electric issues etc
oil leak from bottom
after that inspection and i hope that my will pass it...
i need big inspiration to do this...
now my work day is with my own car tasks about 13h everyday!
Posted: May 13, 2012 8:58 PM
by DieselBoost
Okay... my car is finally ready for inspection...
Posted: May 14, 2012 5:08 PM
by Alleslowbuged
DieselBoost wrote:Okay... my car is finally ready for inspection...
5 days until dyno?
Best Regards
Posted: May 15, 2012 4:40 PM
by DieselBoost
Alleslowbuged wrote:DieselBoost wrote:Okay... my car is finally ready for inspection...
5 days until dyno?
Best Regards
Yep.... terrible hurry... still waiting my better exhaust manifold from machining
Posted: May 19, 2012 11:18 AM
by DieselBoost
my car is inspected now and road leagal again...
dyno was today... but i didnt have exhaust manifold, so i wasnt there...
well i will book another dyno for my car....
Posted: Jun 02, 2012 3:27 AM
by Alleslowbuged
Hi,
how can you inspect the car and get it road legal without an exhaust manifold? Is your car running in the moment, i mean did you drive it? However do have a new dyno date, i would really love to see the power and torque curves from your car.
My engine is still hashed, i have allready get my new mls headgasket with slightly bigger water ports, my camshaft is back from regrinding, but the head is still at the engine shop to get it plane and change the valve position to compensate the camshaft reginding.
I will also swap from mechanical water pump and visco fan to electrical pump and fan with digital controller, without a thermostat.
I hope to put it all together in 2 - 3 weeks.
Best Regard
