Mr_Squishy
Post by Mr_Squishy »
Replaced the o-ring in the brake booster. Ahh the joys of putting that spring in :shock:
Of course that was proceeded by replacing the brake bomb which was almost enjoyable compared to the spring.
Also cleaned and painted one mildly rust euro bucket. Number two next weekend. Lights by Christmas :D
Loaded the M528i up with 3 engines, and am now awaiting the scrappy to arrive.
On the golden poo, vacuum leak hunting.
Nothin, but I praised us over on TTAC
gfoto
Post by gfoto »
Measured a 14MPG for my 518i.... there was a leak in the cold start injector but is this enough to give me such a crappy mileage???? :evil: :evil: :evil: :evil:
Post by rmiddendorf »
gfoto wrote:Measured a 14MPG for my 518i.... there was a leak in the cold start injector but is this enough to give me such a crappy mileage???? :evil: :evil: :evil: :evil:
I would think so. It has probably also cooked your catalytic converter if your car has one.
gfoto
Post by gfoto »
1st Good think it doesn't ;)
2nd Why? The tube is not connected to the injector at all so there is no extra fuel going in...? Am I missing sth please explain... :roll:
gfoto wrote:1st Good think it doesn't ;)
What sort of shape are the spark plugs, wires, cap and rotor in? Also the air filter . Do you smell fuel?
twin55
Post by twin55 »
Changed both UCAs and heater fan motor.
Well if you disconnected the tube on the cold start injector then it shouldn't make a difference. If it was connected and leaking excess fuel into the intake manifold (I don't know where the injector is on your engine but its on the intake manifold on the M30) then the car would be running rich dumping excess fuel into the exhaust. If the tube is disconnected from the cold start injector then I don't know why you're running rich. You could also have leaky individual fuel injectors for each cylinder but "a" brings up good points as well.
foamy
Post by foamy »
had to rig the trunk shut because the latch finally completely went bad and will not latch at all.
foamy wrote:had to rig the trunk shut because the latch finally completely went bad and will not latch at all.
Yah, 'tis the season.Temp drop brings it on. Is the button sticky or is something broken? The spring gets weak and the grease turns to a rock. I have had luck taking the button apart, buffing the old grease off the chrome sleeve. Then I grease it up and re-assemble. Be careful there are small bits.
All I did was to drive B6II to get blood taken for my quarterly exam. The resonator sounds like it is leaking around the gazinta
foamy
Post by foamy »
its just broken the latch part in there does not lock down anymore. im going to get one from the yard when i go for the electrical stuff i need.
Road Trip
Post by Road Trip »
Replaced turn signal/highbeam/obc arm assembly yesterday!! I was having problems with my highbeams randomly coming on during colder temperatures.
I thought this was going to be about a 7/10 for difficulty, but as it turns out I'd give it a 2/10. Very easy job. Thanks to a well designed steering column!! I sourced a mint condition replacement from a BMW wrecker on the island here for $35.
Now to replace the exhaust... :D
Saturday I hung my muffler by with 2 zip ties and a piece of underground 10 gauge copper wire. Seems to be holding up ok.
shagrath wrote:Saturday I hung my muffler by with 2 zip ties and a piece of underground 10 gauge copper wire. Seems to be holding up ok.
Ummm anyone else think the zip ties may be a fire hazard? Anyone?
There's not enough heat generated to do any harm, especially at the tail pipe. Also if anything they would melt. The wire is the best security for the moment, and the strongest.
amirk999
Post by amirk999 »
took out the front driver seat. Removed all of the memory module crap (seat was from an E32). Rewired fuse 4 to the new seats and cigarette lighter.
Road Trip
Post by Road Trip »
Replaced rusty exhaust with great condition aftermarket exhaust from a 533i. New gasket, bolts and ready to go. I hate the sound of exhaust leaks... Up next: timing belt and waterpump.
euro635gas
Post by euro635gas »
Radiator. Top hose broke right off as I pulled up to my garage.
Nice timing
Bought a pair of Sports for the rear. $199.00 with no tax and free shipping from Bavauto of all places. Who would have thunk it? :shock:
Run out of fuel o I-10. Ugh.
It took 16.3 gallons.
Karl Grau wrote:Bought a pair of Sports for the rear. $199.00 with no tax and free shipping from Bavauto of all places. Who would have thunk it? :shock:
Hmmm... Their prices for e32 Bilstein Sports is pretty decent too. When did that happen? And to think, the wife was asking just this morning what I'd really like for Christmas. :up:
wkohler wrote:Run out of fuel o I-10. Ugh.
My son mentioned one night that the eta was close to empty so we went & filled up. It took 15.9 gallons. I was like :shock: but he could've made it to school & back once. Maybe. ;)
davintosh wrote:Their prices for e32 Bilstein Sports is pretty decent too. When did that happen?
I dunno. For some reason I Googled the part number under 'shopping' and Bav came up cheapest. Last time I bought Billys, it was a tie between TireRack and AutohauzAZ.
davintosh wrote:And to think, the wife was asking just this morning what I'd really like for Christmas.
Well you have been extra good this year. ;)
I had a childhood friend over for lunch and, since its a legacy of my mom's 85 535i, I uncovered him and showed Bandit off to my friend. After reconnecting the battery I started Bandit to run him for a bit to circulate the fluids. Running the same- although a little more white smoke in the beginning (first few minutes) than I remember before and the coolant was a little lower than I remember. I hope its not headgasket time but we'll see. And the coolant temperature gauge wasn't working this time. Its hit or miss. Thankfully there is a great member here who is sending me a cluster that will (fingers crossed) hopefully solve that problem.
grey ghost
Post by grey ghost »
Passenger side subframe bushing.
The driver's side has not yet begun to clunk yet.....
But I have it on hand for when it does, which I'm sure will be soon.....
I have no idea why someone would only do one subframe bushing. It's like replacing one tire when the others are 20 years old, but still have decent tread.
wkohler wrote:I have no idea why someone would only do one subframe bushing. It's like replacing one tire when the others are 20 years old, but still have decent tread.
We do things differently here on the East Coast.
If you want to visit I'll put you up at my place anytime. My neighbor Brad Wesley can be a pest sometimes I must warn you.
grey ghost
I'm not being lazy, I'm just getting ready to battle a part that needs to break to be "easier" to remove, that hasn't broken yet.
Road Trip
Post by Road Trip »
Successful timing belt/tensioner/waterpump replacement last week. :banana:
16.3 :shock: Wow, I can tell you have a working in tank pump :laugh: You were also driving for quite a while with the light on. :laugh: And I say that as someone who has been known to do that himself.
