Page 73 of 178
Posted: Dec 29, 2011 11:12 AM
by rmiddendorf
Mike W. wrote:wkohler wrote:Run out of fuel o I-10. Ugh.
It took 16.3 gallons.
16.3
Wow, I can tell you have a working in tank pump
You were also driving for quite a while with the light on.
And I say that as someone who has been known to do that himself.
Where is that light? Anyone have a picture of it lit? My in tank pump is likely not working so I always have to fill-er-up at 1/4. I just remember it being a cool light but haven't seen it since my mom's 535i...
Posted: Dec 29, 2011 1:49 PM
16.3
The light never came on. Tank said it was just under full. In-tank pump was replaced last year. I guess the whole sender is bad.
Posted: Dec 30, 2011 6:59 PM
by Cheesy
Gave it a good cleaning yesterday, and lamented the loss of clear coat this year on my roof, hood, and trunk. She still looks good, but I hate the beat down look.
Today, put on a new (from the yard) driver's B-pillar cover. A decent replacement passenger rear door seal from the yard went on too. New headlight bulbs went in. Changed the engine oil and filter, air filter, and put new rotors and pads on the back end brakes. All in all, a good bonding day with my car.
Posted: Dec 31, 2011 9:09 PM
by davintosh
Pulled the bus wheel off of the steering column & replaced it with the sport wheel; much nicer! Then we lubed up the passenger door window mechanism and put on the black/tan combo door panel in place of the all tan one. Looking good!
Posted: Jan 01, 2012 8:31 AM
by Mr_Squishy
Prepped and painted the rockers with Wurth Stoneguard.
Painted the replacement "is" air dam that has been sitting in garage repaired for 3 months... Need to mount it today.
Finished the euro lights and got them installed and adjusted.
Son was home to help. We had a pretty busy week here
Posted: Jan 01, 2012 9:14 AM
by Mab1957
Tore down spare sports seat for a good frame to
fix the slop and recover a set for the M5 with the kit from Jim's Upholstery in San Diego.
Posted: Jan 01, 2012 4:26 PM
by vinceg101
Took advantage of our extremely warm (+/-80 degrees) and dry weather and washed both the Honda and black 535i. Can't say they didn't need it.
Getting ready to install the new keyless entry system.
Posted: Jan 02, 2012 3:21 PM
by twin55
Replaced the burnt out bulbs in the power window switches.
Posted: Jan 02, 2012 4:43 PM
by e28stian
Bolted a new shiny set of stainless headers to the loud side of the engine.
Posted: Jan 02, 2012 5:52 PM
by cawb352
Replace the throttle cable, one problem fixed, found two more.
Posted: Jan 02, 2012 5:58 PM
by Karl Grau
I added a USB charging port for either my Ipod or Droid. I'm not sure I'll keep it in this same location but it will do for now.
Posted: Jan 02, 2012 7:45 PM
by Das_Prachtstrasse
Compression tested it. Well, 4 of the cylinders at least. Can't get the comp testers attachment into the last two, so im gunna have to think up another way of doing it. Numbers are good so far, fingers crossed this isn't the cause of my missfire.
Posted: Jan 03, 2012 9:13 PM
by no2tracks
Changed the filter and oil, and reclamped the power steering fluid cooler coupler that was leaking.
Posted: Jan 04, 2012 8:50 PM
by a
I changed the oil and filter. I filled with 2 qts 20w 50, 2 qts 5w30 and 12 oz of Marvel Mystery Oil . The pipes have parted somewhere between the cat and the resonator. Made for a buzzy commute to work. I hope to ramp it tomorrow afternoon to have a look.
Posted: Jan 06, 2012 12:22 AM
by twin55
Posted: Jan 06, 2012 5:17 PM
by jhall
Took a couple of pics of the '88's progress. My almost finished trunk after some rust cleanup and paint. Also a quick rocker panel shot after some surface rust cleanup, POR15, undercoating and flat black.
Posted: Jan 06, 2012 5:28 PM
by Karl Grau
Wow, that looks great!
Posted: Jan 07, 2012 12:54 AM
by smootch
Clean, very clean. More pics?
Posted: Jan 07, 2012 2:04 AM
Color me impressed. Do you by chance have any before photos?
Posted: Jan 07, 2012 8:11 AM
by jhall
Probably not as dramatic a change as you guys were thinking but the trunk was still pretty dingy before. I took all the spots of rust down to bare metal before covering. The rockers were fairly clean, just some areas of worn paint and some gouges in the stone guard. I did have some spots of surface rust to clean up also but again nothing major. I'll start a thread in the pictures section once I get some more things done. Thanks for the words though, its motivation to go do some more work...
Posted: Jan 07, 2012 2:10 PM
by foamy
installed the new trunk latch and did an oil change.
Posted: Jan 07, 2012 6:52 PM
by briansmith
Finished the PS pump change on the american boat car in time to remove the car from the garage bay, insert e28, and remove e28 PS pump. Although it's only 6:50pm, it'll be tomorrow before the new pump gets installed, since I'm wiped out from the other car, and I do have beer requiring installation as well.
Posted: Jan 07, 2012 8:00 PM
Drove it.
Posted: Jan 08, 2012 8:20 PM
by a
Replaced the rotten resonator and patched the holes in the pipes going to the muffler. Then I noticed the muffler was bad. I wrapped it with a piece of galvanized 8" duct and secured it with about 40 tek screws. Major PITA, but the result is quiet. The exhaust was so loud that I couldnt hear the radio. Thursday, I fixed the interior lights. The wire had rotted in the foot well. I spent a half hour finding the circuit diagram . Then started at the connector to the left light. No continuity. Then I noticed a bulge in the wire jacket with a green smear on it. I had to do the same repair to every Grand Wag I had. As usual, the BmW version was much easier to fix.
Posted: Jan 09, 2012 11:18 AM
by oldskool
Replaced that rubber grommet that had disintegrated around my antennae so now I have one less place for water to get in trunk. I also fixed a horrible shimmy that had developed by dropping off a trunk full of New Year's bottles at the recycler.
Posted: Jan 10, 2012 12:29 AM
New clutch hydraulic cylinders went into the E28 ///M.
Posted: Jan 10, 2012 12:32 AM
by fiver diver
New bearings all around, and new coated Balo rotors and Jurid pads, with fresh ATE gold fluid. Also new water pump.
Quite the undertaking with only hand tools......
Posted: Jan 10, 2012 9:26 AM
by Brad D.
I stared at it for a bit as I pulled out of the driveway in my e39.
Posted: Jan 10, 2012 7:02 PM
by dolomiti
new battery, title transfer, new license plates, 100 mph on freeway.
Posted: Jan 10, 2012 7:05 PM
Accidentally put 22 gallons of fuel in it.
